Harmany Posted June 12, 2008 Report Posted June 12, 2008 I am concidering buying some rather expensive hardware (for me). To justify it I'll have to have supiriour midi control....The first thing I will try is a PAD Machine:- 16 Big Pads + Internal LED- 32 Small Pads + Internal LED- 32 Rotary Encoders + LED RingIdeally all the pads are touch sensitive....... (does that cost more inputs or is it the signal the pad sendswhich makes it touch sensitive ?)I think I can use midibox 64e for this right ? I am still not sure exactly how many LED/LEDRINGS I can useon the 64e. Is a Ledring just one led, but depending on input voltage differnt will light up ?
cimo Posted June 12, 2008 Report Posted June 12, 2008 hi welcome, thumbs up, etc etcconsidering the equation (rather expensive hardware) < (time you spend reading ucapps.de) = truethen you ll automagically get all the answer you need plus a bunch of new friends plus a working Midiboxas a starting point be aware that so many touch sensitive pads need a properly built design to avoid cross talking and suchGood luckSimone
stryd_one Posted June 12, 2008 Report Posted June 12, 2008 Welcome aboard dude...Touch sensitive or velocity sensitive?
Harmany Posted June 12, 2008 Author Report Posted June 12, 2008 thanks for the welcome :)I meant to say Velocity sensitive! The idea is that a soft trigger will do effect fade-in, or small delay, ..I'd have the big pad for triggering a pattern/clip/... the small pads will trigger "sub stories", the rotator handlesvelocity for that part. Also, if someone can say if my mind is clear on the virtual pots/paging features:- I can create several pages- each pages holds its state in memory and receives feedback (even though another page is selected!!)(please tell me this is so :)
stryd_one Posted June 12, 2008 Report Posted June 12, 2008 (please tell me this is so :)It is :)velocity sensitivity is tricky though.... I won't restart the theoreticising here, have a search and you'll find some good theories of how to do it... I don't think anyone's done it yet, though!BTW there was a dozen or more empty lines in your post, just thought I should let you know I removed them, in case you were wondering why I edited you :)
julienvoirin Posted June 13, 2008 Report Posted June 13, 2008 julestriko has developped a "pad keyboard" with velocity AND aftertouch (MPC style !!) maybe you could ask him later when you will have to do the .asm of the application.obvious your project is very interesting, cimo is right, if you are newbee you will spend to much time on ucapps ; moreover you will have to code and it is complicated. Buying a kaosspad or a MPD + a Remote zero SL seems a better solution.
Harmany Posted June 15, 2008 Author Report Posted June 15, 2008 I guess the smart thing todo is leave the touch-sensitive stuff for a later project!
unrise_lyrical Posted June 15, 2008 Report Posted June 15, 2008 if you want really decent pads, go for an M-Audio Axiom....they are absolutely awesome. Velocity Sensative...plus you can easily swap them around so them send CC data instead....its a suprisingly intuitive way of controlling midi data....very good for...mm...whats a good word...hehe...transducing? human emotion.......
cimo Posted June 15, 2008 Report Posted June 15, 2008 ah! velocity sensitive.. check the different pads projects at edrum.info but as i said before avoiding crosstalking and calibration can be hellSimone
Enth Posted June 17, 2008 Report Posted June 17, 2008 Might be slightly relevant for info, or then not ::)http://tomscarff.tripod.com/8way_drm2/8way_drm2_1.htm
