Guest rebelrob Posted September 3, 2002 Posted September 3, 2002 G'day,I'm just about to etch a PCB for the MIDIBox plus.I have decided to use Dave Wheelers PCB layout as it seems like the simplest to make, and the track spacing is good, aswell as the pad sizes (as im etching it myself)My question is if anyone has had any issues using this board? Also, where does the VCC and ground wires from each pot goto on this board?Thanks in advanced.Rob
Guest rebelrob Posted September 4, 2002 Posted September 4, 2002 Sorry ignore the question asking about the VCC connections, I realise now how to connect them.There is an error on the 74HC00 where pins9,10,12,13 should be grounded. (at the moment they are floating inputs..)Rob
