Ok so I have the core built and my first AIN. I hooked up a pot to the AIN to verify that I am getting midi into my computer however nothing is coming through.
1) When I load the MIDI-OX the SYSX hex values are F0 00 00 7E 40 00 01 F7
2) I have verified across Vs to Vd is 5V both on the AIN and Core
3) And also verified that when I turn the knob the voltage changes across the pot
4) I also have confirmed using another midi device that the MIDI-OX is detecting midi signals
Is there anything I am missing?
You shoud not be using MIDI-Ox, you need to use MIOS Studio. Search for posts by me about mios studio, sort by most recently posted, and near the top and you'll find instructions. Try that and see how you go :)
Oh... what app is it?
This was uploading a pre-defined ini file called midibox64_generic
TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT
00029040  2  3    F0  Buffer:    8 Bytes  System Exclusive
SYSX: F0 00 00 7E 40 00 01 F7
0002DC12  MOX  3    F0  Buffer:  256 Bytes  System Exclusive
SYSX: F0 00 00 7E 43 04 00 30 00 00 7F 30 01 00 7F 30 02 00
SYSX: 7F 30 03 00 7F 30 04 00 7F 30 05 00 7F 30 06 00 7F 30
SYSX: 07 00 7F 30 08 00 7F 30 09 00 7F 30 0A 00 7F 30 0B 00
SYSX: 7F 30 0C 00 7F 30 0D 00 7F 30 0E 00 7F 30 0F 00 7F 30
SYSX: 10 00 7F 30 11 00 7F 30 12 00 7F 30 13 00 7F 30 14 00
SYSX: 7F 30 15 00 7F 30 16 00 7F 30 17 00 7F 30 18 00 7F 30
SYSX: 19 00 7F 30 1A 00 7F 30 1B 00 7F 30 1C 00 7F 30 1D 00
SYSX: 7F 30 1E 00 7F 30 1F 00 7F 30 20 00 7F 30 21 00 7F 30
SYSX: 22 00 7F 30 23 00 7F 30 24 00 7F 30 25 00 7F 30 26 00
SYSX: 7F 30 27 00 7F 30 28 00 7F 30 29 00 7F 30 2A 00 7F 30
SYSX: 2B 00 7F 30 2C 00 7F 30 2D 00 7F 30 2E 00 7F 30 2F 00
SYSX: 7F 30 30 00 7F 30 31 00 7F 30 32 00 7F 30 33 00 7F 30
SYSX: 34 00 7F 30 35 00 7F 30 36 00 7F 30 37 00 7F 30 38 00
SYSX: 7F 30 39 00 7F 30 3A 00 7F 30 3B 00 7F 30 3C 00 7F 30
SYSX: 3D 00 7F 30
0002DC4F  MOX  3    F0  Buffer:    9 Bytes  System Exclusive
SYSX: 3E 00 7F 30 3F 00 7F 60 F7
0002DCC8  MOX  3    F0  Buffer:  256 Bytes  System Exclusive
SYSX: F0 00 00 7E 43 04 01 30 40 7F 00 30 41 7F 00 30 42 7F
SYSX: 00 30 43 7F 00 30 44 7F 00 30 45 7F 00 30 46 7F 00 30
SYSX: 47 7F 00 30 48 7F 00 30 49 7F 00 30 4A 7F 00 30 4B 7F
SYSX: 00 30 4C 7F 00 30 4D 7F 00 30 4E 7F 00 30 4F 7F 00 30
SYSX: 50 7F 00 30 51 7F 00 30 52 7F 00 30 53 7F 00 30 54 7F
SYSX: 00 30 55 7F 00 30 56 7F 00 30 57 7F 00 30 60 7F 00 30
SYSX: 61 7F 00 30 62 7F 00 30 63 7F 00 30 64 7F 00 30 65 7F
SYSX: 00 30 66 7F 00 30 67 7F 00 30 68 7F 00 30 69 7F 00 30
SYSX: 6A 7F 00 30 6B 7F 00 30 6C 7F 00 30 6D 7F 00 30 6E 7F
SYSX: 00 30 6F 7F 00 30 70 7F 00 30 71 7F 00 30 72 7F 00 30
SYSX: 73 7F 00 30 74 7F 00 30 75 7F 00 30 76 7F 00 30 77 7F
SYSX: 00 30 78 7F 00 30 79 7F 00 30 7A 7F 00 30 7B 7F 00 30
SYSX: 7C 7F 00 30 7D 7F 00 30 7E 7F 00 30 7F 7F 00 30 58 7F
SYSX: 00 30 59 7F 00 30 5A 7F 00 30 5B 7F 00 30 5C 7F 00 30
SYSX: 5D 7F 00 30
0002DD04  MOX  3    F0  Buffer:    9 Bytes  System Exclusive
SYSX: 5E 7F 00 30 5F 7F 00 5F F7
0002DD7F  MOX  3    F0  Buffer:  256 Bytes  System Exclusive
SYSX: F0 00 00 7E 43 04 02 00 00 00 00 00 00 00 00 00 00 00
SYSX: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SYSX: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0F
SYSX: 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 47 11 00
SYSX: 00 00 00 00 04 47 65 6E 65 72 69 63 20 42 61 6E 6B 20
SYSX: 20 20 20 02 00 00 00 01 00 02 00 03 00 04 00 05 00 06
SYSX: 00 07 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SYSX: 00 00 00 00
0002DDBB  MOX  3    F0  Buffer:    9 Bytes  System Exclusive
SYSX: 00 00 00 00 00 00 00 33 F7
0002DE34  MOX  3    F0  Buffer:  256 Bytes  System Exclusive
SYSX: F0 00 00 7E 43 04 03 00 00 00 00 00 00 00 00 00 00 00
SYSX: 00 00 00 00
0002DE71  MOX  3    F0  Buffer:    9 Bytes  System Exclusive
SYSX: 00 00 00 00 00 00 00 7D F7
0002DEEA  MOX  3    F0  Buffer:  256 Bytes  System Exclusive
SYSX: F0 00 00 7E 43 04 04 62 43 43 20 23 20 30 20 20 20 20
SYSX: 20 20 20 20 20 62 43 43 20 23 20 31 20 20 20 20 20 20
SYSX: 20 20 20 62 43 43 20 23 20 32 20 20 20 20 20 20 20 20
SYSX: 20 62 43 43 20 23 20 33 20 20 20 20 20 20 20 20 20 62
SYSX: 43 43 20 23 20 34 20 20 20 20 20 20 20 20 20 62 43 43
SYSX: 20 23 20 35 20 20 20 20 20 20 20 20 20 62 43 43 20 23
SYSX: 20 36 20 20 20 20 20 20 20 20 20 62 43 43 20 23 20 37
SYSX: 20 20 20 20 20 20 20 20 20 62 43 43 20 23 20 38 20 20
SYSX: 20 20 20 20 20 20 20 62 43 43 20 23 20 39 20 20 20 20
SYSX: 20 20 20 20 20 62 43 43 20 23 31 30 20 20 20 20 20 20
SYSX: 20 20 20 62 43 43 20 23 31 31 20 20 20 20 20 20 20 20
SYSX: 20 62 43 43 20 23 31 32 20 20 20 20 20 20 20 20 20 62
SYSX: 43 43 20 23 31 33 20 20 20 20 20 20 20 20 20 62 43 43
SYSX: 20 23 31 34 20 20 20 20 20 20 20 20 20 62 43 43 20 23
SYSX: 31 35 20 20
0002DF26  MOX  3    F0  Buffer:    9 Bytes  System Exclusive
SYSX: 20 20 20 20 20 20 20 2A F7
0002DF9F  MOX  3    F0  Buffer:  256 Bytes  System Exclusive
SYSX: F0 00 00 7E 43 04 05 62 43 43 20 23 31 36 20 20 20 20
SYSX: 20 20 20 20 20 62 43 43 20 23 31 37 20 20 20 20 20 20
SYSX: 20 20 20 62 43 43 20 23 31 38 20 20 20 20 20 20 20 20
SYSX: 20 62 43 43 20 23 31 39 20 20 20 20 20 20 20 20 20 62
SYSX: 43 43 20 23 32 30 20 20 20 20 20 20 20 20 20 62 43 43
SYSX: 20 23 32 31 20 20 20 20 20 20 20 20 20 62 43 43 20 23
SYSX: 32 32 20 20 20 20 20 20 20 20 20 62 43 43 20 23 32 33
SYSX: 20 20 20 20 20 20 20 20 20 62 43 43 20 23 32 34 20 20
SYSX: 20 20 20 20 20 20 20 62 43 43 20 23 32 35 20 20 20 20
SYSX: 20 20 20 20 20 62 43 43 20 23 32 36 20 20 20 20 20 20
SYSX: 20 20 20 62 43 43 20 23 32 37 20 20 20 20 20 20 20 20
SYSX: 20 62 43 43 20 23 32 38 20 20 20 20 20 20 20 20 20 62
SYSX: 43 43 20 23 32 39 20 20 20 20 20 20 20 20 20 62 43 43
SYSX: 20 23 33 30 20 20 20 20 20 20 20 20 20 62 43 43 20 23
SYSX: 33 31 20 20
0002DFDC  MOX  3    F0  Buffer:    9 Bytes  System Exclusive
SYSX: 20 20 20 20 20 20 20 61 F7
0002E055  MOX  3    F0  Buffer:  256 Bytes  System Exclusive
SYSX: F0 00 00 7E 43 04 06 62 43 43 20 23 33 32 20 20 20 20
SYSX: 20 20 20 20 20 62 43 43 20 23 33 33 20 20 20 20 20 20
SYSX: 20 20 20 62 43 43 20 23 33 34 20 20 20 20 20 20 20 20
SYSX: 20 62 43 43 20 23 33 35 20 20 20 20 20 20 20 20 20 62
SYSX: 43 43 20 23 33 36 20 20 20 20 20 20 20 20 20 62 43 43
SYSX: 20 23 33 37 20 20 20 20 20 20 20 20 20 62 43 43 20 23
SYSX: 33 38 20 20 20 20 20 20 20 20 20 62 43 43 20 23 33 39
SYSX: 20 20 20 20 20 20 20 20 20 62 43 43 20 23 34 30 20 20
SYSX: 20 20 20 20 20 20 20 62 43 43 20 23 34 31 20 20 20 20
SYSX: 20 20 20 20 20 62 43 43 20 23 34 32 20 20 20 20 20 20
SYSX: 20 20 20 62 43 43 20 23 34 33 20 20 20 20 20 20 20 20
SYSX: 20 62 43 43 20 23 34 34 20 20 20 20 20 20 20 20 20 62
SYSX: 43 43 20 23 34 35 20 20 20 20 20 20 20 20 20 62 43 43
SYSX: 20 23 34 36 20 20 20 20 20 20 20 20 20 62 43 43 20 23
SYSX: 34 37 20 20
0002E093  MOX  3    F0  Buffer:    9 Bytes  System Exclusive
SYSX: 20 20 20 20 20 20 20 4A F7
0002E10C  MOX  3    F0  Buffer:  256 Bytes  System Exclusive
SYSX: F0 00 00 7E 43 04 07 62 43 43 20 23 34 38 20 20 20 20
SYSX: 20 20 20 20 20 62 43 43 20 23 34 39 20 20 20 20 20 20
SYSX: 20 20 20 62 43 43 20 23 35 30 20 20 20 20 20 20 20 20
SYSX: 20 62 43 43 20 23 35 31 20 20 20 20 20 20 20 20 20 62
SYSX: 43 43 20 23 35 32 20 20 20 20 20 20 20 20 20 62 43 43
SYSX: 20 23 35 33 20 20 20 20 20 20 20 20 20 62 43 43 20 23
SYSX: 35 34 20 20 20 20 20 20 20 20 20 62 43 43 20 23 35 35
SYSX: 20 20 20 20 20 20 20 20 20 62 43 43 20 23 35 36 20 20
SYSX: 20 20 20 20 20 20 20 62 43 43 20 23 35 37 20 20 20 20
SYSX: 20 20 20 20 20 62 43 43 20 23 35 38 20 20 20 20 20 20
SYSX: 20 20 20 62 43 43 20 23 35 39 20 20 20 20 20 20 20 20
SYSX: 20 62 43 43 20 23 36 30 20 20 20 20 20 20 20 20 20 62
SYSX: 43 43 20 23 36 31 20 20 20 20 20 20 20 20 20 62 43 43
SYSX: 20 23 36 32 20 20 20 20 20 20 20 20 20 62 43 43 20 23
SYSX: 36 33 20 20
0002E148  MOX  3    F0  Buffer:    9 Bytes  System Exclusive
SYSX: 20 20 20 20 20 20 20 33 F7
OK my first attempt using the MIOS studio failed with the file http://www.ucapps.de/mios/midibox64_v2_4a.zip file
http://bp0.blogger.com/_ZdR1AjzO6Bk/SIHysW-sNUI/AAAAAAAAAA0/JpQsUTYTKqY/s1600-h/untitled.JPG
I turned off the PIC and tryed again and stuff uploaded. I am now getting random midi notes (which is good, since i dont have the unused pins grounded).
I also found that the MIOS studio crashed. Likely due to an overload of midievents coming from the PIC. I confirmed this in MIDI-OX and I am getting lotsa random events.
Will report back later with more findings
Did you configure it for your hardware?
Next time please just copy and paste the text log here - I copy and paste it elsewhere and it makes it quick for me to troubleshoot. I can only see some of what's happening there, but the unexpected upload requests suggest that your box is constantly rebooting.
Well Iwouldn't say it's good. You need to fix that before you start trying to make software work. Do that first. Your firmware won't work on broken hardware, and that's what you've got right now.
ok will try tomorrow, going camping!
alright, so i grounded the unused pins, and voila, was able to get some midi data.
i even went as far as testing it out in ableton and it worked. will post some pics soon.
for now i just have a single pot connected. i tried using a Panasonic 10K Fader but the PIC keeps reseting.
Also the layout for the board, some pots are missing.
Oh no! what did you change?
didnt change anything. simply substituted the pot for the fader and the pic would reset. the fader might be damaged ill have to try another one.
