This N°9 Posted October 24, 2008 Report Share Posted October 24, 2008 hi all,I have a strange problem (or question) concerning the pin-numberingof DOUT's.I builded a testing board to test IO pins. The DIN works fine, PIN-numbering as expected.I use 10wire ribbon cables and DIL headers with smashTV's PCB's, one DIN and one DOUTboard are connected to the core.I wrote a simple program that just displays the DIN-pin (pressed button) and switchesthe pin with the same number DOUT. The strange thing is, that the DOUT registersseem to have swapped LSB/MSB:DOUT 0 -> DOUT 7DOUT 1 -> DOUT 6..DOUT 7 -> DOUT 1..DOUT 8 -> DOUT 15..DOUT 15 -> DOUT 8I checked the wiring back and forth, even checked the datasheet of the stuffed registers (SN74HC595N),where the outputs are numbered A-H, and the forwardoutput is H'. nothing explains this behaviour. my only explanation is, that the registers seem to assign thebits from H-A, not to A-H, which looks very strange tome.has somebody experienced something similar? or anyexplanation? I could handle this in software, butI would like to know what is going down there.wiring is:LED 0 -> J3::D0LED 1 -> J3::D1...LED 8 -> J4::D0etc.DIN::J1 -> DOUT::J1 -> CORE::J8/J9 (10wire ribbon cable, DIL headers)thanks in advance,this Quote Link to comment Share on other sites More sharing options...
cimo Posted October 25, 2008 Report Share Posted October 25, 2008 74hc165 and 74hc595 have a different I/Os pinoutiirc:DIN - DOUT0 - 01 - 12 - 23 - 34 - 75 - 66 - 57 - 4but i am not sure atm, i ll check it outSimoneEDIT: sorry i see you have smashtv boards where you can see the pins numbering, just ignore my posting EDIT2: sorry again (at least for being so imprecise) but now i reckon something, when i built my first board with douts and the pinout of the DOUT was not consistent so that it looked like this:DOUT - DOUT(ICpins)-(MIOSpins)0 - 01 - 12 - 23 - 34 - 75 - 66 - 57 - 4 Quote Link to comment Share on other sites More sharing options...
TK. Posted October 25, 2008 Report Share Posted October 25, 2008 Thats normal - while DINs are scanned in backward direction (last bit received last), DOUTs are scanned in forward direction (last bit sent first).Therefore the bit correlation is swapped on DOUTs.If you would follow the programmers section, you would know, that I was close to decide to change the order in MIOS32:http://www.midibox.org/forum/index.php/topic,12141.msg100435.html#msg100435But finally decided to keep it compatible with PIC based MIOS, as most application would have to reverse the pins anyhow - e.g. to transfer DIN register values to DOUT register values:http://www.midibox.org/forum/index.php/topic,12141.msg101954.html#msg101954Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
cimo Posted October 25, 2008 Report Share Posted October 25, 2008 thanks TKi was trying to find an old thread where you were clarifying that to me, but couldn t find it. Quote Link to comment Share on other sites More sharing options...
This N°9 Posted October 25, 2008 Author Report Share Posted October 25, 2008 Thats normal - while DINs are scanned in backward direction (last bit received last), DOUTs are scanned in forward direction (last bit sent first).I'am glad to read this.I now had a look at the datasheets of the SN74HC165 / 595, to get clear what ishappening on hardware and software level (maybe someone else finds this info usefull):in the sheets the IN/OUT pins are A-H, this reflects D0-D7 (smashTV boards / circuit layouts), O 0-O7 / I0-I7 (circuit layouts)DIN chain hardware-level: CORE <- R1::qH <- R1::H <- R1 <- R1::G ..... R2::qH <- R2::H etc.so the first bit read is DIN1::I7, I suppose this goes to the MSB on software level.DOUT chain hardware-level: CORE -> R1::SER -> R1::A -> R1::B -> R1::C ..... R2::SER -> R2::A etc.so the first bit pushed out goes to DOUTlast::D7, the last pushed bit goes to DOUT1::D0what I don't understand is what is happening on software level. Suppose the Byte is pushed outLSB -> MSB (right to left), and the input stream goes to MSB - > LSB (left to right)?...(last bit received last).... (last bit sent first).....and PIN 0 is always reflected @LSB (SRGet/SRSet)? Quite confusing. If somebody can give me the answers, I will put this infos toa table that gives a clear overview for others with the same questions.I attached the two datasheets.SN74HC595.pdfSN74HC165.pdfSN74HC595.pdfSN74HC165.pdf Quote Link to comment Share on other sites More sharing options...
TK. Posted October 25, 2008 Report Share Posted October 25, 2008 There is a DIN/DOUT table in the wiki - I would propose to improve itBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
This N°9 Posted October 25, 2008 Author Report Share Posted October 25, 2008 ok, I'll do this update on the wiki.@TKjust for my understanding: what you do on software level is that you haveall the bytes in a array from 0 to x and push them out from LSB x to MSB 0,and you read them (DIN) from MSB 0 to LSB x, right? this makes sensein view of the resulting swap-effect. what I was missing was a fat hint on this effect, for example on the very entrypage of the DOUT module. I built the hardware before I could test it (missing plugs),and so I now had to change all the wiring to correct the effect.I'll do this info update on the wiki, and maybe if it's done someone who has writeaccess adds a good visible hint on the DOUT page on ucapps.de.thanks for the help,this Quote Link to comment Share on other sites More sharing options...
TK. Posted October 25, 2008 Report Share Posted October 25, 2008 just for my understanding: what you do on software level is that you haveall the bytes in a array from 0 to x and push them out from LSB x to MSB 0,and you read them (DIN) from MSB 0 to LSB x, right? this makes sensein view of the resulting swap-effect. Yes - and it's an intented "effect" to simplify the handling at application side.Simple example: MIOS_DOUT_SRSet(0, MIOS_DIN_SRGet(0));works without reversing the pin positions.and maybe if it's done someone who has writeaccess adds a good visible hint on the DOUT page on ucapps.de.Please give me a phrasing which is good enough, so that nobody who creates an own PCB overlooks the reversed DOUT pin mapping. I will insert it into the schematics.Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
This N°9 Posted October 27, 2008 Author Report Share Posted October 27, 2008 Yes - and it's an intented "effect" to simplify the handling at application side.ok, I understand. It makes sense to have the MSB represent the highest PIN value on both DIN and DOUT.But if the bits would be pushed out left-to-right (MSB first) instead of right-to-left, the SR 0 would be the last register in the chain physically.This way the D0 - D7 taging would match the pin-number on software side, also the MSB-LSB story and the order of the bytes in the array would stay the same. J3 - J6 on the schematics/boards do not imply so strongthat this reflects the order of the single registers on software level, and plugs are changed more quickly than single wires.I think the IC's have this setup because one normally sends data left-to-right and also receives it left to right(sending the first bit/byte of a file first, and also receive it first).sorry to be so picky, it's just a proposition. compatibility problems: maybe a MIOS-flag for theorientation of the push-out? Please give me a phrasing which is good enough, so that nobody who creates an own PCB overlooks the reversed DOUT pin mapping. I will insert it into the schematics.ok, as soon as I have some time I'll do this. right now I'am occupied with the MIDI-mapperhardware/software. I'll document this project anyway, so I'll do the DIN/DOUT table updatethen. Quote Link to comment Share on other sites More sharing options...
TK. Posted October 27, 2008 Report Share Posted October 27, 2008 sorry to be so picky, it's just a proposition. compatibility problems: maybe a MIOS-flag for theorientation of the push-out? There are 4 possible ways to handle the shifting (SR bit orientation, SR chain orientation), ca. 8 years ago I selected one which matches best with my own MIDIbox HW, meanwhile 1000s of MIDIboxes exist which are using correct DOUT wiring. Now you request a software flag for more flexibility as a workaround for incorrect wiring at your side. The software flag would affect the performance of all existing MIDIboxes. And it would lead to a higher memory consumption of MIOS, so that other features would have to be removed (as MIOS already allocates most of the "system" area in flash).Instead, I would propose one of following solutions:fix your DOUT wiring and help to improve documentationmodify the bit order in mios_srio.inc and build your private MIOS version, so that no HW change is requiredadd the flexibility inside your application - it's the most simple solution for both - programmers and users - and it doesn't waste memory at MIOS side (which is very very limited - I can't repeat this often enough. Fortunately it has been relaxed dramatically with the MIOS32 approach (-> modular kernel) - but please don't mix the new possibilities with the old PIC MIOS approach (-> static kernel)!)Best Regards, Thorsten.P.S.: the disadvantage of your idea: DOUT SR assignments have to be adapted whenever the number of SRs in the chain is changed via MIOS_SRIO_NumberSet() - this doesn't really make sense. Quote Link to comment Share on other sites More sharing options...
This N°9 Posted October 27, 2008 Author Report Share Posted October 27, 2008 fix your DOUT wiring and help to improve documentationmy wiring is already fixed. I'll do the doc improvement when I finishedthe midi-mapper and write documentation to it.Now you request a software flag for more flexibility as a workaround for incorrect wiring at your side.no, I don't request a flag for my private use. It was just a proposition to avoid others running into the sameconfusion, it was more a proposition for the new ARM based MIOS.P.S.: the disadvantage of your idea: DOUT SR assignments have to be adapted whenever the number of SRs in the chain is changed via MIOS_SRIO_NumberSet() -ok, this is a strong argument. I give up :-)besides, I don't want to fall on your nerves..thanks for help & info,this Quote Link to comment Share on other sites More sharing options...
doc Posted October 28, 2008 Report Share Posted October 28, 2008 besides, I don't want to fall on your nerves.. :D :D Quote Link to comment Share on other sites More sharing options...
This N°9 Posted October 29, 2008 Author Report Share Posted October 29, 2008 What's this "real life" everybody is talking about? ... and where can I download it?I propose this one (german):http://www.reset.ch/ Quote Link to comment Share on other sites More sharing options...
nILS Posted October 29, 2008 Report Share Posted October 29, 2008 http://www.dasinternetabschalten.de:-) Quote Link to comment Share on other sites More sharing options...
This N°9 Posted November 23, 2008 Author Report Share Posted November 23, 2008 ok, now I updated the DIN / DOUT pin table on the wiki:http://www.midibox.org/dokuwiki/doku.php?id=din_dout_pintable@TK:Please give me a phrasing which is good enough, so that nobody who creates an own PCB overlooks the reversed DOUT pin mapping. I will insert it into the schematics.I propose this one:"Please Note: in contrast to DIN boards, hardware pins are swapped for each SR.Pin D7/O7 reflects the lowest, D0/O0 the highest software-pin-value for each SR." Quote Link to comment Share on other sites More sharing options...
stryd_one Posted November 23, 2008 Report Share Posted November 23, 2008 Excellent work, this :)Just, next time... use the preview button before saving, so there aren't 9 saves in the revision history ;) Quote Link to comment Share on other sites More sharing options...
This N°9 Posted November 24, 2008 Author Report Share Posted November 24, 2008 Just, next time... use the preview button before saving, so there aren't 9 saves in the revision historyyes, I know.. this is because the table got kind of "radioactive", means it looked different every time I looked at it.. the spacer lines had not as many cells as thecontent lines. anyway, I removed the spacer lines totally now, because the SR numgives enough visible structure to the table.second I mixed up DOUT's DIN's on the first revisions, and had to correct that afterwards :) Quote Link to comment Share on other sites More sharing options...
stryd_one Posted November 24, 2008 Report Share Posted November 24, 2008 the spacer lines had not as many cells as thecontent lines. anyway, I removed the spacer lines totally now, Don't forget the playground area when you're playing with unfamiliar syntax.Why are you still doing that annoying trimming with your text? Quote Link to comment Share on other sites More sharing options...
This N°9 Posted November 24, 2008 Author Report Share Posted November 24, 2008 Why are you still doing that annoying trimming with your text?please be more specificDon't forget the playground area when you're playing with unfamiliar syntax.I can't forget what I don't know.. ;) just found it..besides this was not a not-knowing-the-syntax-related thing. check the difference:|||||||||||||it's not a nuclear reactor, it's just a wiki.. :D Quote Link to comment Share on other sites More sharing options...
nILS Posted November 24, 2008 Report Share Posted November 24, 2008 I think stryd is referingto the manually addedline breaks, that you tend to add for no goodreason ;-) Quote Link to comment Share on other sites More sharing options...
stryd_one Posted November 24, 2008 Report Share Posted November 24, 2008 please be more specificCompare this: Your posts have the ends of the linescut off so that the paragraph does not reach the end of the text boxand scroll to the next line like it shouldit makes it difficult to quote you becausei have to delete the unnecessary linereturnsto this:Your posts have the ends of the lines cut off so that the paragraph does not reach the end of the text box and scroll to the next line like it shouldit makes it difficult to quote you because i have to delete the unnecessary line returnsI can't forget what I don't know.. ;) just found it..It's linked at the top of the page when you edit ;)besides this was not a not-knowing-the-syntax-related thingActually, it is - the tables are supposed to behave that way. Have a play in the playground, You'll see itYou don't have to add all those spaces in there. The column will fit the longest entry, which in this case, is the header of the column. I've fixed that for you, you may want to tidy up a little more.While I'm at it, you've commited the cardinal sin of wiki doco today - updated a page without checking for dupes. http://www.midibox.org/dokuwiki/doku.php?id=dout_module&do=backlinkFix those backlinksOr... better still, get rid of this strangely named page, http://www.midibox.org/dokuwiki/doku.php?id=dout_module_digital_outputput it's content on the dout_module page, and don't forget to fix the backlinks to the removed pageOrr... even better than all those..... don't work on old wiki doco - get involved in the overhaul, make your edits in the new pages.it's not a nuclear reactor, it's just a wiki.. :DStill can be confusing though :) Quote Link to comment Share on other sites More sharing options...
This N°9 Posted November 24, 2008 Author Report Share Posted November 24, 2008 While I'm at it, you've commited the cardinal sin of wiki doco today - updated a page without checking for dupes. hm... ok, to be honest, I never worked with docuwiki before, so before I screw it up even more: how did this happen? I can only remember that I- edited the page "din_dout_pintable"- added a comment to "dout_module"how and when did I create "dout_module_digital_output" ??? tell me a bit more about dupes.Orr... even better than all those..... don't work on old wiki doco - get involved in the overhaul, make your edits in the new pages.I musthavemissedthis.where?besides, the strange random table-loosing-border behaviour seem to be a result of empty rows (<tr></tr>) generated. I will try to remove them on my next try. Quote Link to comment Share on other sites More sharing options...
This N°9 Posted November 24, 2008 Author Report Share Posted November 24, 2008 I think this dupe story was not my fault, some "moebius" seems to have created this page:2006/05/01 15:16 Show differences to current revisions dout_module_digital_output – created moebius Quote Link to comment Share on other sites More sharing options...
This N°9 Posted November 24, 2008 Author Report Share Posted November 24, 2008 ok, I'am fixing the stuff, but I found other (old) sind, for ex. on the page index_test, which links back to the dout_module_digital_out - page: * [[LCD Module (Liquid Crystal Display)|LCD Module]] - Liquid Crystal Display * [[AOUT Module (Analog Out)|AOUT Module]] - Analog Out to output Voltages (for Controls)looks like the other link on page "mbhp", THIS is a bad sytax!I don't like to be blamed for stuff that other before me screwed up!! :)UPDATE: also fixed links / dupes for aout_module_analog_out -> aout_module; on mbhp, LCD-link-to-nowhere -> lcd Quote Link to comment Share on other sites More sharing options...
This N°9 Posted November 24, 2008 Author Report Share Posted November 24, 2008 guess I found the door to the new wiki:http://www.midibox.org/dokuwiki/doku.php?id=new_wiki_layout Quote Link to comment Share on other sites More sharing options...
