Testing core - for midimon
Howdy,
Have started to make midimon.
This is the second thread I have started. The other is for another time when I learn more about this stuff. Some newbie questions I asked were why is J5 different from the schematic (ans: J5A is first half  and J5B is the second half. You can use which ever J5 you like - they all go back to the respective same points on the PIC). Also I asked which Vs and Vd I should use on the new J5A and J5B because there were multiples (ans: Use any as there is only one Vs (ground) and Vd (+5 volts)).
I have started a wiki to try and document what I have done to date. This may only help total newbies. It is here: http://www.midibox.org/dokuwiki/doku.php?id=martinsomerville and is far from complete - feel free to add to it. Also as you will see, I am still lacking basic knowledge on midibox and electronics.
I bought a couple of R4D PIC18F452 core kits with bootloader (V1.2B) and mios (1.9F) already installed (ID 000...) from smash.
The first core I uploaded the application setup.hex file. It seemed to work fine but the buttons didn't work (refer to picture below on bread board).
I built a second kit to see if it happened again and it did - worked fine (when playing the midi keyboard on mios studio the lcd responded with the midi data) but no buttons.
I followed the http://www.ucapps.de/howto_debug_midi.html page and tested my 2nd core. A couple of components I don't think I did that well (maybe a second or two seconds longer than 3. Ha 4 or 5 seconds) - the chrystal and the diode. possibly others but I did a better job than my 1st attempt.
{text added 081210}
From stryds post below (« Reply #2 on: 2008-12-07 at 14:13 ») it looks like I should not have done these tests because my application uploaded fine. These tests from the link above should only be done if having trouble specifically with the midi.
{text added 081210 end}
I just did all the tests to see what they were. I am not sure I needed to do them all.
Results: (sorry for format. Cut and pasted from excel)
mios studio midi monitor in
on startup 00000000018062 ms | Sysex message: F0 00 00 7E 40 00 01 F7
test prog 1 - kit from smash
test core1 - kit from smash
test core2 - have MBHP_CORE 3 so not a problem
test core4 - testing Vdd. 5V everywhere (well 4.9 to 5). Couldn't find J12. Back of midi out measures 5V at 2 locations. . It's the 2nd and 4th pins that show 5V (looking from top of board with cables out to the right).
test core5 all (4.9 to 5). No J3 and no resistor between pin 12 of IC as shown in http://www.ucapps.de/howtodebug/mbhp_core_extract_measuring_gnd.gif . Aside: noted that there is no resistance between the two legs of C1 and C8 that are closest together. Maybe this is how it should be.
test core6 - midi - done with smash
test core7 - matches smash direction on board
test core8 - red red brown gold at midi out and in
test core9 - yep all connected
test core10 - no random data. There is a resistance of about 1275 ohms across pin 25 ( Tx) and 26 (Rx)
test core 11 - not sid
TEST OUT 1
{delete added 081210}
<del> (Viewing from the top with midi cable exiting to right, I count the pins 1 to 5) I don't get a flicker with the led {edited 081210 from lead} (tried all combos I think as well as 2 and 4 /  4 and 2). The only time I get light is if I connect the anode leg to pin 2 or 4 and connect the cathode (short) leg to 3. In this case it just glows consistent.One thing that strikes as odd is the orientation of the J12 in the schematic. If I am looking at my board from above (midi ports facing to the right) and I check the resistance between the 2nd fin from the top of the midi out I would expect this to join M0 of J11 and have a resistance of 220 ohms. But it's the 2nd fin from the bottom that is connected to J11 MO. ?? The delete thingies didn't seem to work, maybe only wiki syntax.
</del>
{delete added 081210 end}
{text added 081210}
Have since figured out. By 'rear' on the midi diagrams, it indicates a view opposite to the flat side where the midi cable connects to. So the view seen when the midi plug's flat female side (side midi cable connects) is flat on the table. When the plug is rotated back to having the faces vertical, when viewed from the outside (opposite to the 'rear' side view) the 5 pins form an arc that is an unsmiley face (or a monobrow), ie an arc drawn from 9 o'clock to 12 oclock to 3'oclock. This is clear to me now but I was confused for a while. Smash TV's midi plug are upside down (well they have to be to connect to PCB). Conventions in oz are 3rd angle which is to say a right side view would flip the side/view of the "imaginery box" up at the top right edge of the box.  The image matched what I had on the smash board and what I knew as conventions for diagrams so was confused (which is what I am sure I have done for everyone else with this explanation - ha. Will fix up later). Anyway to cut short when being shown a view it seems that it is opened up from an "imaginery hinge" from the bottom of the "imaginery box". And in the case for Smash midi plugs, this will mean that it is the reverse to what you expect because it is upside down (ie smiley face from the outside) compared to diagram. Also found the numbering system on the back of the plug. Looking at from the rear (opposite to flat female face side) the numbering is .. need to check when I get home.
test out 2 - looks like it is grounded in core_v3
test pc1 - ports look good to me
test pc2 - attach code for uploading the midimon hex file. If I understand what a byte is, there seems to be one more byte at the monitor in than the monitor out. Also is it strange that the out is bigger.
Midi monitor in (from mios studio):
00000007162265 ms | Sysex message: F0 00 00 7E 40 00 0F 7A F7
00000007162671 ms | Sysex message: F0 00 00 7E 40 00 0F 60 F7
00000007163062 ms | Sysex message: F0 00 00 7E 40 00 0F 40 F7
00000007163468 ms | Sysex message: F0 00 00 7E 40 00 0F 18 F7
00000007163875 ms | Sysex message: F0 00 00 7E 40 00 0F 2F F7
00000007164281 ms | Sysex message: F0 00 00 7E 40 00 0F 59 F7
00000007164671 ms | Sysex message: F0 00 00 7E 40 00 0F 63 F7
00000007165078 ms | Sysex message: F0 00 00 7E 40 00 0F 55 F7
00000007165484 ms | Sysex message: F0 00 00 7E 40 00 0F 4F F7
00000007165875 ms | Sysex message: F0 00 00 7E 40 00 0F 00 F7
00000007166296 ms | Sysex message: F0 00 00 7E 40 00 0F 2C F7
00000007166703 ms | Sysex message: F0 00 00 7E 40 00 0F 15 F7
00000007167093 ms | Sysex message: F0 00 00 7E 40 00 0F 1F F7
00000007167515 ms | Sysex message: F0 00 00 7E 40 00 0F 7F F7
00000007167921 ms | Sysex message: F0 00 00 7E 40 00 0F 68 F7
00000007168328 ms | Sysex message: F0 00 00 7E 40 00 0F 16 F7
00000007168734 ms | Sysex message: F0 00 00 7E 40 00 0F 2A F7
00000007169140 ms | Sysex message: F0 00 00 7E 40 00 0F 4D F7
00000007169531 ms | Sysex message: F0 00 00 7E 40 00 0F 50 F7
00000007169953 ms | Sysex message: F0 00 00 7E 40 00 0F 2B F7
00000007170343 ms | Sysex message: F0 00 00 7E 40 00 0F 26 F7
00000007170843 ms | Sysex message: F0 00 00 7E 40 00 0F 22 F7
00000007171234 ms | Sysex message: F0 00 00 7E 40 00 0F 48 F7
00000007171625 ms | Sysex message: F0 00 00 7E 40 00 0F 43 F7
00000007172031 ms | Sysex message: F0 00 00 7E 40 00 0F 56 F7
00000007172421 ms | Sysex message: F0 00 00 7E 40 00 0F 53 F7
00000007172812 ms | Sysex message: F0 00 00 7E 40 00 0F 58 F7
00000007173218 ms | Sysex message: F0 00 00 7E 40 00 0F 22 F7
00000007173609 ms | Sysex message: F0 00 00 7E 40 00 0F 57 F7
00000007175921 ms | Sysex message: F0 00 00 7E 40 00 01 F7
Midi monitor out code (from mios studio):
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0C 00 00 20 43 7B 63 1F 05 4B 5E 19 78 2D 7D 71 4F 42 7B 6F 0C 7C 17 6E 78 67 61 42 77 46 3E 0D 7F 3C 33 70 71 7B 63 1F 06 77 5E 19 78 37 5D 71 4F 43 49 6F 0C 7C 19 0E 78 67 61 47 77 46 3E 0C 27 3C 33 70 63 3B 63 1F 04 03 5E 19 78 20 3D 71 4F 42 05 6F 0C 7C 10 3E 78 67 61 51 77 46 3E 0C 7F 3C 33 70 42 3B 63 1F 04 17 5E 19 78 21 5D 71 4F 40 24 00 00 00 02 20 00 00 00 12 00 00 00 01 10 00 00 00 09 00 00 00 00 48 00 00 00 04 40 00 00 00 24 00 00 00 1F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 78 7A F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0C 20 00 20 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 78 60 F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0C 40 00 20 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 78 40 F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0C 60 00 20 09 00 02 20 00 48 00 12 00 04 40 01 10 00 24 00 08 03 4F 0E 60 5B 60 01 07 20 1D 41 37 40 40 0E 09 3B 02 7F 05 17 58 1C 78 00 5D 41 6F 40 20 0E 01 5B 44 70 70 11 5C 00 07 2F 1D 41 37 40 13 6C 0D 3C 15 0E 60 77 60 53 76 06 5E 01 03 28 21 14 51 3B 02 6F 06 62 48 10 42 29 5D 41 7F 40 2F 6C 11 3C 00 00 76 7B 58 16 78 00 21 6D 77 30 2D 70 09 00 04 2E 60 6B 60 26 76 07 7E 01 10 00 33 6C 0D 3C 0A 3E 60 7F 60 0D 77 47 3E 01 10 02 05 6C 0B 3C 02 08 00 48 00 59 77 47 7E 05 1F 3C 3D 70 09 00 02 20 07 07 58 1E 78 2E 1D 41 77 40 06 50 30 7B 63 6F 04 23 5E 1C 78 02 6D 6F 40 2B 31 34 05 3B 03 5F 00 2D 21 7A 05 36 16 40 17 30 3B 70 42 3B 63 4F 00 48 00 12 00 16 7D 41 57 42 19 6F 0E 3C 02 20 00 48 00 07 07 30 2D 60 1B 3B 20 0E 49 05 40 35 00 3C 17 12 08 00 77 09 14 2B 70 0E 4B 05 40 33 47 20 60 07 05 65 42 21 10 02 00 50 07 42 70 0B 50 40 12 03 37 21 07 0E 41 53 40 0B 01 44 02 20 00 18 F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0D 00 00 20 63 3B 02 6F 00 11 5D 72 6F 41 02 4D 45 10 02 0E 7F 42 62 20 07 7C 1D 65 76 06 3E 01 43 20 32 6A 09 00 03 05 00 0D 5C 12 00 31 5D 41 37 40 30 14 6C 29 00 10 70 0D 5C 12 00 3D 5D 41 4F 40 06 6E 01 54 03 01 40 64 24 03 60 06 1E 01 10 00 33 30 07 76 03 1B 10 43 30 19 5A 04 3B 01 4D 58 25 58 0C 6E 02 3D 40 66 74 14 6C 06 37 41 2E 60 33 3E 0B 36 02 20 00 66 20 00 07 05 1A 01 4C 48 02 0E 08 74 03 19 20 08 1C 0E 68 06 32 60 18 38 17 50 0C 66 00 40 70 23 20 19 4D 01 21 60 2E 40 33 1C 03 03 40 2D 00 66 3C 07 07 01 2D 6C 36 7C 08 6E 02 54 00 36 72 47 5E 1A 78 0D 3D 71 7F 40 01 6E 20 7C 01 00 70 19 5D 6B 35 01 45 6F 6E 5C 24 00 00 00 28 02 48 0C 16 40 37 50 0A 11 7E 60 06 6E 00 43 4D 0E 60 5B 60 20 77 11 3E 00 00 05 00 51 6C 49 5B 75 00 6F 31 5F 5F 1F 61 30 1B 38 04 0E 34 3B 02 6F 01 03 5C 41 78 00 00 14 02 47 32 26 6F 54 01 6D 46 7E 7C 7F 05 40 6D 60 00 39 51 6C 0B 3C 02 20 00 2F F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0D 20 00 20 01 42 79 0E 60 5B 61 08 06 11 01 42 10 30 22 0C 0F 42 79 0E 60 5B 61 01 06 33 61 49 10 32 0C 0C 66 03 14 40 65 00 19 0F 06 20 01 48 20 32 10 0C 70 03 16 10 66 08 19 30 06 2E 01 4F 78 31 7E 0C 5F 43 1B 70 67 3C 19 77 06 3E 61 4F 68 33 7C 0C 67 43 1F 10 67 7C 19 7F 06 3F 61 4F 78 33 7E 0C 00 3B 02 6F 00 00 02 11 1C 41 61 3C 47 30 2D 70 03 74 00 6D 00 17 20 04 68 04 5A 01 0E 40 35 50 15 74 02 1C 07 23 7E 24 76 05 5E 01 16 03 51 7F 3F 42 64 4E 60 5B 60 13 60 3A 1F 77 78 2C 49 6C 0B 3C 04 0D 00 47 01 68 7F 49 1D 41 37 40 27 40 74 3F 6F 70 59 13 58 16 78 05 5A 01 0E 03 51 7F 12 3B 02 6F 00 00 02 00 07 04 75 50 16 40 26 35 3F 02 64 4E 60 5B 60 13 60 3A 1F 77 78 2C 49 6C 0B 3C 00 4D 00 47 01 68 7F 49 1D 41 37 40 11 6F 0B 3C 00 54 72 3D 4C 66 10 08 04 02 01 00 0A 4E 37 5D 0C 52 01 00 40 20 10 01 28 15 23 0D 50 20 10 08 04 02 00 0D 06 43 11 48 04 02 01 00 40 20 04 54 0E 26 38 59 F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0D 40 00 20 17 10 6D 06 73 1C 40 09 21 5A 0D 65 03 49 66 72 17 08 01 15 03 25 68 63 34 10 4D 66 21 00 10 4D 32 5D 0C 14 2B 59 68 20 10 00 00 11 0A 44 1E 0B 00 43 72 0E 60 5B 60 7C 07 25 1D 41 37 43 28 0E 7B 1B 46 50 77 5D 5C 00 00 44 27 10 38 2C 14 0D 79 54 1E 62 30 00 1D 77 11 02 20 0F 2A 42 39 6C 0B 3C 00 00 08 44 72 07 05 72 1D 41 37 40 0F 50 03 34 00 5D 00 3F 20 20 68 09 3A 02 4E 40 5B 50 09 30 1D 0F 79 7F 30 20 07 25 1D 41 37 40 27 40 74 3F 72 2E 60 5B 60 2A 68 04 58 0E 47 7E 25 6C 0B 3C 04 00 74 53 58 16 78 16 61 69 27 30 2D 70 09 70 1D 0F 7C 4B 58 16 78 17 21 69 27 30 2D 70 0C 34 02 3C 07 23 7E 01 07 64 5D 41 37 40 25 50 09 70 1D 0F 7C 4B 58 16 78 03 3A 01 1E 03 51 7F 49 3B 02 6F 00 23 20 12 60 3A 1F 79 47 30 2D 70 09 70 1D 0F 7C 63 58 16 78 04 40 01 0E 03 51 7F 4C 3B 02 6F 00 4B 01 68 7F 66 1D 41 37 40 27 40 74 3F 73 0E 78 5B 60 04 06 42 01 6F 19 13 6C 6E 1B 43 5E 42 00 63 F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0D 60 00 20 7B 5B 40 30 74 73 5E 16 78 0B 25 52 68 01 46 23 19 00 0C 42 69 48 00 64 11 4C 40 06 29 34 64 00 33 0B 26 20 03 18 46 32 00 19 65 53 10 01 4E 23 19 00 0C 12 69 48 00 61 11 4C 40 06 11 34 64 00 31 4B 26 10 03 0C 46 31 00 19 05 53 08 01 48 23 18 40 0C 52 69 44 00 66 16 4C 20 06 31 0C 62 00 33 4B 26 10 03 1C 46 31 00 18 25 53 08 01 42 23 18 40 0C 22 69 44 00 43 2F 4C 00 04 19 0C 60 00 22 17 66 00 02 10 46 30 00 11 2B 73 00 01 0C 5F 18 00 08 62 19 40 00 47 2F 4C 00 04 39 0C 60 00 20 57 66 00 02 04 46 30 00 10 4B 73 00 01 06 5F 18 40 08 32 19 44 00 44 2F 4C 20 04 21 0C 62 00 22 57 66 10 02 19 3E 31 00 11 44 33 08 01 0E 5F 18 40 08 72 19 44 00 41 2F 4C 20 04 09 0C 62 00 21 17 66 10 02 0D 3E 32 00 10 64 33 10 01 08 5F 19 00 08 42 19 48 00 45 2F 4C 40 04 32 7C 64 00 23 08 66 20 02 1D 3E 32 00 11 64 33 10 01 02 5F 19 00 08 12 19 48 00 42 2F 4C 40 04 1A 7C 66 00 21 48 66 30 00 55 F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0E 00 00 20 22 17 66 30 02 10 46 33 00 11 2B 73 18 01 0C 5F 19 40 08 62 19 4C 00 47 2F 4C 60 04 39 0C 66 00 20 57 66 30 02 04 46 33 00 10 4B 73 18 01 06 5F 1A 00 08 32 19 50 00 44 2F 4D 00 04 21 0C 68 00 22 57 66 40 02 19 3E 34 00 11 44 33 20 01 0E 5F 1A 00 08 72 19 50 00 41 2F 4D 00 04 09 0C 68 00 21 17 66 40 02 0D 3E 35 00 10 64 33 28 01 08 5F 1A 40 08 42 19 54 00 45 2F 4D 20 04 32 7C 6A 00 23 08 66 50 02 1D 3E 35 00 11 64 33 28 01 02 5F 1A 40 08 12 19 54 00 42 2F 4D 20 04 1A 7C 6C 00 21 48 66 60 02 11 3E 36 00 11 04 33 30 01 0A 5F 1B 00 08 65 79 58 00 46 11 4D 40 04 3A 7C 6C 00 23 48 66 60 02 05 3E 36 00 10 24 33 30 01 04 5F 1B 00 08 35 79 5C 00 43 11 4D 60 04 22 7C 6E 00 22 08 66 70 02 15 3E 37 00 11 4B 73 38 01 0C 23 1B 40 08 75 79 5C 00 47 11 4D 60 04 0A 7C 6E 00 20 48 66 70 02 09 3E 37 00 10 6B 73 40 01 06 23 1C 00 08 45 79 60 00 44 11 4E 00 04 2A 7C 70 00 23 17 67 00 00 4F F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0E 20 00 20 23 08 67 00 02 1D 3E 38 00 03 61 60 00 04 28 6F 09 00 01 70 70 00 02 15 37 44 40 00 00 04 28 51 6C 29 02 40 38 00 02 15 28 76 14 41 28 1C 00 01 0A 14 3B 0A 20 04 1C 03 37 06 01 66 07 30 2D 70 00 00 22 55 0E 62 48 01 07 00 6D 61 48 39 41 6C 0B 3C 02 20 00 00 02 31 35 4C 4D 33 1B 2C 68 6B 18 1A 62 20 00 0D 5C 00 00 7E 01 60 1B 00 6F 50 01 6F 46 06 59 41 23 7D 07 76 16 0F 68 38 06 0F 64 3B 02 6F 00 0B 20 08 68 02 5A 0F 10 38 06 62 01 34 06 02 59 07 20 30 35 47 7A 00 1E 00 6B 70 7C 75 60 3B 01 56 1F 58 48 00 66 03 33 3C 6A 51 01 42 60 60 6F 4F 1E 34 78 0D 26 1E 41 40 06 0B 19 5B 66 53 48 3C 16 35 37 4D 47 1F 00 2C 6A 13 1B 0E 21 70 59 59 5E 35 60 0C 5E 03 36 00 63 70 01 34 00 00 58 48 00 01 07 3F 61 31 10 00 06 50 7C 02 40 4E 00 0D 21 7A 05 03 7C 0F 26 5C 68 2B 0B 43 46 46 2F 4B 2E 34 35 4C 65 30 18 38 66 65 76 75 66 36 59 48 57 58 58 0C 25 3E 46 5C 68 6B 19 5A 66 26 58 00 F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0E 40 00 20 18 5A 7C 3D 38 00 02 38 35 4E 2D 3D 00 38 74 6F 03 43 47 36 78 48 00 00 00 4E 05 21 10 00 00 01 1D 01 5B 0A 01 6C 0C 3A 28 4E 62 10 3F 07 20 0E 1D 1B 60 70 71 6D 5E 38 60 0E 3E 03 43 28 24 00 28 03 5E 66 71 68 1D 77 37 0E 38 0E 47 7F 6C 26 00 03 5E 72 10 24 01 75 28 04 40 00 00 04 04 03 02 41 40 70 40 28 16 0C 06 43 62 01 08 48 28 15 0B 05 63 11 50 6C 38 1E 0F 48 04 12 19 10 4A 26 14 0A 25 22 59 34 5C 2F 18 0C 46 33 21 54 6E 38 1C 4E 47 43 69 78 7E 41 21 10 68 44 32 1D 10 49 25 53 09 54 72 41 22 52 29 55 2A 65 3A 61 34 5B 2E 17 2B 76 03 05 44 64 32 59 4C 76 4B 29 56 6C 37 1B 6E 07 0B 4D 68 75 3B 1E 0F 17 53 6D 7A 7E 3F 60 10 28 1C 12 0B 07 44 22 31 28 64 36 1D 0F 48 64 52 39 24 5A 2F 18 4C 66 73 49 6C 7A 41 21 51 28 74 5A 35 1E 51 2A 55 6B 15 5A 7D 42 63 32 5A 2D 36 6B 3D 66 75 3B 5E 2F 57 7C 06 07 07 44 62 71 59 0C 4E 2B 17 4D 67 33 7A 0D 16 4F 29 55 6B 76 1B 1D 50 2C F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0E 60 00 20 6E 37 3B 6D 7F 07 45 63 72 39 5C 7E 47 27 57 6C 76 7B 5E 0F 0F 4B 67 75 7B 3D 7F 0F 57 6F 79 7D 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 70 00 04 42 6B 11 1A 64 36 59 11 56 20 35 44 40 00 1B 3B 70 0E 01 58 06 7D 00 00 02 03 28 3C 21 23 47 00 41 3F 1C 74 00 3B 71 01 56 20 28 7D 61 7D 45 43 6E 0E 04 43 79 0E 60 5B 60 08 68 02 3A 00 56 40 17 50 06 34 02 2D 00 57 20 18 68 06 7A 0F 00 38 0F 50 3F 43 40 5D 03 7C 1C 03 68 00 21 60 0E 40 02 0E 01 58 40 2D 01 00 56 12 68 08 0D 31 06 40 06 50 10 5B 64 56 7F 63 2E 03 28 08 4D 72 33 3F 69 57 01 54 04 36 79 1D 5F 70 6B 40 6A 02 23 3C 50 6F 01 34 00 00 58 48 00 01 07 3F 61 31 10 00 40 6B 10 23 7F 0D 39 01 56 03 1C 01 61 3C 47 30 2D 70 03 74 01 1D 00 2B 20 0B 68 03 1A 00 76 40 1F 50 08 34 06 3D 40 15 F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0F 00 00 20 14 03 41 7D 01 20 1C 1A 68 09 61 60 5E 40 4E 0E 0B 34 05 2D 41 18 1C 06 68 09 41 61 0E 40 4A 0E 01 34 04 50 70 37 20 10 77 08 3E 0E 0B 3B 60 0E 73 45 40 35 00 3C 17 67 09 00 6A 0B 00 2C 00 0A 67 78 39 4D 38 43 5C 21 78 38 2D 60 78 3B 4E 16 01 4E 1E 00 5F 1C 24 03 28 3C 01 37 00 2B 01 61 12 70 04 1F 01 1B 00 22 78 09 78 02 1F 40 51 40 12 3C 17 1D 39 10 56 17 07 08 37 31 40 38 43 3D 0E 43 44 46 28 48 00 24 35 48 65 33 58 38 46 65 09 00 04 36 59 08 56 3B 07 08 4C 51 10 00 44 6B 10 4A 23 70 59 05 5E 12 00 01 6D 20 33 38 14 0E 03 17 00 3E 18 19 5C 07 15 3E 5A 71 10 01 20 2A 28 14 0C 56 70 77 58 1F 78 00 78 0E 77 7C 09 40 77 3F 60 5C 07 3B 7E 66 35 04 10 01 10 00 21 28 03 34 00 35 07 60 14 51 70 00 6A 0F 70 29 1D 60 7C 03 40 36 01 2F 20 03 57 00 7A 00 1E 01 23 70 29 1A 0A 22 50 08 1C 52 32 00 3A 05 13 3B 5E 0E 28 59 07 6D 02 45 21 71 05 04 17 03 57 01 26 28 07 42 6A 36 70 1F F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0F 20 00 20 00 3B 4A 4F 00 0F 01 6B 7F 54 2A 00 38 2F 11 6C 0B 3C 00 7D 00 1F 20 07 68 01 7A 00 3E 40 0F 50 03 74 00 7D 01 1B 20 09 68 05 1A 00 3E 40 05 50 00 74 00 0D 00 11 54 05 35 14 4D 2B 46 5D 24 04 0D 38 2A 1C 00 0F 60 00 77 15 1E 05 1A 43 56 50 02 1B 40 56 72 49 55 2C 6B 54 4A 0F 70 3C 1B 61 28 70 00 3F 00 03 5C 54 78 14 60 40 78 2F 57 4F 02 3C 00 10 7F 2F 1E 05 78 14 4D 29 66 5C 24 00 01 54 15 7E 60 77 60 24 70 00 00 12 0A 44 3E 0B 25 3B 03 6F 00 1A 1C 07 60 12 1E 00 36 01 0F 70 11 14 29 2E 60 7B 60 06 47 01 78 04 37 40 0D 40 22 7C 04 35 0A 2B 58 1E 78 01 51 60 3E 01 09 70 03 30 08 3F 01 11 22 4A 76 07 5E 00 3E 01 05 70 03 30 08 1F 00 42 18 10 4D 04 10 21 10 00 07 40 05 3C 00 35 05 33 58 1C 78 0C 7C 00 00 04 63 40 01 7C 06 22 4E 62 68 03 15 3D 1D 41 37 40 08 38 07 42 69 06 70 11 20 0F 05 51 6D 60 19 60 1E 0B 23 1B 40 35 00 3C 17 00 04 51 2D 64 42 40 15 61 08 03 49 06 70 7F F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0F 40 00 20 23 54 00 6E 08 40 1C 47 37 11 4A 00 17 04 20 0E 23 1B 42 00 72 11 5C 00 00 4C 65 10 78 2E 00 09 21 5B 46 42 49 67 3E 07 28 36 16 41 00 39 04 6E 03 30 08 1F 00 42 14 10 4E 04 10 20 56 00 07 70 09 00 00 0E 74 03 60 65 28 00 61 5F 1A 43 52 26 7A 14 1D 22 10 48 00 10 60 01 5E 02 3E 60 21 16 74 2C 02 08 31 03 30 10 4C 3A 16 01 04 20 20 50 03 06 5B 0A 20 42 00 12 00 00 01 60 1B 08 03 50 02 74 00 10 70 0D 44 01 68 02 3A 01 10 00 09 30 09 00 0C 62 57 70 1C 66 30 19 4D 61 04 00 24 00 02 2C 02 20 03 19 21 58 52 19 40 61 04 00 24 00 01 03 42 2E 78 6B 60 03 07 04 5D 71 57 41 4E 2A 33 54 0F 70 5E 62 68 10 40 04 40 01 05 48 77 58 08 28 02 20 00 42 20 66 28 14 0B 46 2B 38 06 0E 32 1B 4C 45 00 42 68 05 68 10 01 5F 1A 42 11 6C 0B 3C 00 4D 00 0D 5C 00 07 2B 5D 41 37 42 5F 6C 0F 7C 0C 50 37 7C 1D 58 50 19 2D 61 05 70 0B 50 08 2E 40 3D 03 10 0D 68 71 00 5A 06 21 3B 4B 57 33 14 02 5E 00 68 F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0F 60 00 20 33 6B 42 20 00 38 1C 10 5E 13 41 61 05 69 1C 0E 44 3B 02 6F 02 6C 1D 14 76 05 5E 02 68 3A 29 6C 0B 3C 0C 65 04 4B 58 16 78 17 21 69 27 30 2D 70 09 00 02 09 10 42 54 05 68 00 01 68 47 30 2D 70 31 7B 04 1F 00 42 58 05 68 00 01 68 47 30 2D 70 4C 3B 04 1F 00 48 00 00 07 00 6D 64 00 38 08 6E 0A 03 40 56 72 50 1D 28 77 45 5E 01 6F 30 3F 70 77 33 62 1F 07 3B 1E 12 78 3B 59 71 1F 40 22 50 05 78 02 1D 01 00 5A 7C 10 0F 0D 66 79 01 4A 76 32 5B 4E 43 71 00 40 20 10 08 04 07 20 3B 6C 6E 1F 43 5E 76 70 50 1D 1C 77 45 5E 01 05 18 2B 50 08 54 1E 00 5D 40 14 11 70 44 2A 00 78 2C 02 0F 48 3B 02 6F 03 70 1D 14 76 05 5E 01 12 41 79 59 10 03 52 4E 60 5B 60 13 28 24 5D 41 37 41 67 51 77 43 42 16 23 3B 22 11 28 03 61 3C 47 30 2D 70 0C 74 04 3D 01 57 20 4D 68 18 5A 07 16 42 05 50 49 74 1C 3D 07 4F 20 03 68 44 7A 12 1E 44 67 51 21 74 2A 3D 0A 18 60 7C 10 1A 2D 67 23 15 64 6E 30 5B 04 06 28 16 F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 10 00 00 20 39 1C 4D 77 11 00 41 72 07 3D 4D 63 78 3B 6E 6E 0A 03 53 4E 78 5B 60 46 18 5F 04 04 6A 51 06 20 0A 03 5E 66 72 00 1D 77 37 02 01 69 67 30 2D 70 09 14 13 0E 60 5B 60 0A 07 29 1A 14 31 49 78 20 29 5B 6D 66 39 01 20 6F 39 48 00 03 20 3B 6C 6E 20 03 5E 76 70 34 1D 1C 76 05 5E 01 1A 42 31 6C 0B 3C 04 00 74 53 58 16 78 04 4A 09 47 30 2D 70 01 03 51 3D 0A 18 66 7C 10 14 6D 76 73 1C 40 53 32 5B 04 00 03 18 1D 76 37 10 01 6F 3B 38 1A 0E 4E 3B 02 6F 00 49 21 12 76 05 5E 00 20 39 71 51 23 0D 0F 42 03 55 5C 64 32 59 4D 16 73 15 48 20 10 08 04 02 01 00 41 0C 07 3D 4D 64 00 3B 6E 6E 0A 03 53 4E 78 5B 60 46 1A 5F 04 07 2B 39 48 65 33 1A 2D 66 2B 10 40 20 10 08 04 02 01 02 5C 0E 7B 1B 48 00 77 5D 5C 14 07 27 1D 71 37 41 0C 36 3E 08 0A 47 2B 39 4A 20 29 19 2E 17 2B 15 66 74 10 08 04 02 06 40 1D 76 37 10 01 6F 3B 38 28 0E 4E 3B 62 6F 02 4D 70 7C 00 08 07 45 1B 65 66 45 3C 08 0C 57 40 2A F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 10 20 00 20 38 1A 2E 26 2B 10 7C 20 00 3C 41 6F 33 39 00 0E 7B 5B 40 30 74 73 58 16 78 19 2A 05 00 60 07 60 08 43 53 4E 78 5B 60 01 07 01 4D 60 07 39 29 70 29 41 01 70 58 1D 5C 06 15 01 6A 0E 5A 43 60 0A 02 78 00 70 20 3C 16 07 37 01 55 0F 36 5C 12 0E 03 18 02 4D 00 21 54 07 28 3A 6A 09 47 30 2D 70 03 4A 01 70 58 1D 5C 08 15 02 05 20 31 3B 6B 57 10 03 52 4E 60 5B 60 08 15 04 01 60 43 13 73 57 09 00 0A 35 07 60 1E 0F 05 41 6D 60 40 38 0C 6E 03 54 1D 35 04 63 58 16 78 01 65 00 78 2C 0E 6E 03 0B 5E 7D 39 38 1D 14 77 45 5E 04 31 61 78 20 26 52 28 44 49 01 06 6C 37 58 6D 32 01 00 40 20 10 08 12 60 77 59 5C 41 07 3D 6D 61 20 3A 39 6F 0B 3C 08 63 4B 70 40 4D 24 51 09 12 02 51 52 63 35 48 04 02 01 00 40 20 10 2E 01 6F 33 39 02 0E 7B 5B 42 40 74 73 5E 16 78 11 48 17 61 01 1A 49 22 12 24 05 1B 51 42 72 3A 08 04 02 01 00 40 20 6D 03 5E 66 72 04 1D 77 37 05 01 69 67 3C 2D 70 23 10 4F 42 00 4D F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 10 40 00 20 26 52 28 44 49 01 06 6F 37 1D 0D 16 73 55 4A 20 10 08 1F 40 77 59 5C 41 07 3D 6D 61 20 3A 39 6F 0B 3C 08 64 1B 70 40 4D 24 51 09 12 02 4D 68 6F 38 08 04 02 01 00 40 20 10 07 41 6F 33 39 04 0E 7B 5B 42 40 74 73 5E 16 78 11 48 47 61 01 6A 6E 32 19 2C 66 4B 39 4A 64 10 08 04 02 01 00 40 20 20 03 5E 66 72 08 1D 77 37 05 01 69 67 3C 2D 70 23 11 2F 42 02 05 46 74 34 5D 4C 52 02 4D 4A 6E 39 59 24 02 01 00 40 62 07 3D 4D 64 10 3B 6E 6E 0A 03 53 4E 78 5B 60 46 23 1F 04 04 6A 25 08 49 10 14 4C 57 1B 15 68 20 10 08 04 02 01 02 08 0E 7B 1B 48 20 77 5D 5C 14 07 27 1D 71 37 40 25 6C 0D 7C 02 35 03 3B 20 08 06 5F 41 6F 33 39 08 0E 7B 5B 5E 35 07 58 4D 74 28 3D 64 20 40 3A 39 6F 0B 3C 09 05 04 3B 58 21 78 11 6A 08 77 30 43 70 23 14 11 6E 61 07 60 45 28 24 1D 42 0F 40 5C 0E 49 7B 04 1F 02 11 21 0E 76 08 3E 04 1A 42 21 6C 10 7C 05 60 74 4F 58 21 78 10 4A 08 77 30 43 70 20 54 12 0E 60 50 F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 10 60 00 20 10 7C 00 30 71 6F 30 1C 76 07 3E 09 17 30 2D 70 05 36 08 20 70 27 30 50 07 01 7B 04 68 38 0B 50 74 2E 00 2D 04 3B 5E 16 78 08 01 69 27 3C 2D 70 26 55 08 33 51 00 00 2A 07 3D 4D 64 18 3B 6E 6E 02 43 53 4E 60 5B 60 48 28 06 1B 04 3A 40 2D 58 1D 03 42 7D 42 19 20 12 6C 11 2A 01 06 60 74 0E 08 76 08 45 00 33 30 43 28 02 5B 03 50 38 17 58 21 14 00 6D 42 05 20 04 6C 01 01 60 3E 43 51 38 6C 75 71 6E 78 5B 60 20 07 25 1D 71 37 40 14 6E 10 03 52 4E 60 5B 60 0A 17 3E 7A 71 10 00 21 34 1F 34 04 00 6F 51 20 06 06 6A 41 6F 33 39 06 0E 7B 5B 5E 35 07 58 4D 74 28 3D 64 20 28 3A 39 6F 0B 3C 00 10 00 00 00 00 00 00 40 00 00 00 00 00 01 40 00 00 00 00 00 03 00 40 00 00 00 00 06 02 00 00 00 00 00 0C 06 00 00 00 00 00 18 0C 02 00 00 00 00 30 18 08 00 00 00 00 60 30 18 00 00 00 01 40 60 30 08 00 00 03 01 40 60 20 00 00 06 03 01 40 60 10 00 0C 06 03 01 40 40 00 18 0C 06 03 01 40 00 30 18 2B F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 11 00 00 20 01 40 60 30 08 0C 06 03 01 40 60 20 33 39 7C 0E 7B 1B 49 00 77 5D 5D 2A 76 05 5E 00 32 40 40 0D 7A 14 12 4E 60 5B 61 7C 07 3D 4D 67 60 3B 6E 6E 55 3B 62 6F 00 42 68 12 00 0F 41 6F 33 39 08 0E 7B 5B 5C 6E 78 5B 60 00 00 00 00 00 00 00 00 00 00 04 02 01 00 40 20 10 00 00 02 41 20 50 28 14 0A 00 00 01 28 54 2A 15 0A 45 20 00 00 00 08 06 03 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 21 18 2D 66 59 01 1A 53 21 13 2D 76 22 5D 50 65 32 5B 08 27 13 15 42 74 34 08 04 04 1B 51 64 6C 17 08 04 03 1A 19 5E 6F 3A 10 6E 47 13 31 20 6F 39 1D 0A 46 4B 35 4A 44 30 5D 0C 12 02 35 26 42 2B 1B 6D 47 2B 35 4A 20 10 10 4C 16 63 05 5C 63 32 48 08 37 23 49 58 2E 10 08 07 15 03 05 5C 6F 39 18 2D 56 0A 15 70 70 39 0B 44 02 01 01 0C 78 11 4C 24 04 6A 4D 04 46 3C 08 66 22 02 35 26 42 21 5D 0E 26 61 38 40 31 1A 10 6E 47 13 30 5C 20 18 4D 28 37 20 26 F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 11 20 00 20 39 1B 05 62 01 44 6C 43 3A 1C 4D 42 71 00 62 37 21 5D 0E 26 61 38 40 31 1C 10 6E 47 13 30 5C 20 18 4E 28 37 23 49 58 2E 10 0C 46 04 1B 51 64 6C 17 08 06 23 0A 0D 68 72 36 0B 44 03 11 49 06 74 39 1B 05 62 01 48 66 43 3A 1C 4D 42 71 00 64 34 21 5D 0E 26 61 38 40 32 1A 50 6E 47 13 30 5C 20 19 0D 48 37 23 49 58 2E 10 0C 46 74 1B 51 64 6C 17 08 06 23 42 0D 68 72 36 0B 44 03 11 65 06 74 39 1B 05 62 01 4C 60 43 3A 1C 4D 42 71 00 66 31 21 18 2D 66 59 01 18 53 21 13 2D 76 21 00 40 4C 29 50 48 27 13 15 42 74 26 14 68 24 1B 51 64 6C 17 08 06 33 2A 19 5E 6F 3A 0B 49 45 1A 09 20 6F 39 1D 0C 14 62 4D 04 44 30 5D 0C 12 02 31 26 42 2B 1B 6D 42 71 01 18 53 21 10 4C 16 61 38 40 4C 29 50 48 37 23 49 58 2E 10 0D 06 15 03 05 5C 2E 10 13 0A 34 12 15 70 70 39 0B 49 45 1A 09 0C 78 11 4C 24 04 62 4D 04 46 3C 08 66 22 02 31 26 42 21 5D 0E 26 61 38 40 34 1B 10 6E 47 13 30 5C 20 1A 0D 68 37 20 22 F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 11 40 00 20 39 1B 05 62 01 50 70 43 3A 1C 4D 42 71 00 68 39 21 5D 0E 26 61 38 40 35 18 10 6E 47 13 30 5C 20 1A 4C 28 37 23 49 58 2E 10 0D 26 24 1B 51 64 6C 17 08 06 53 1A 0D 68 72 36 0B 44 03 29 51 06 74 39 1B 05 62 01 54 6A 43 3A 1C 4D 42 71 00 6A 36 21 5D 0E 26 61 38 40 35 1B 50 6E 47 13 30 5C 20 1A 4E 08 37 23 49 58 2E 10 0D 27 14 1B 51 64 6C 17 08 06 63 02 0D 68 72 36 0B 44 03 31 45 06 74 39 1B 05 62 01 58 64 43 3A 1C 4D 42 71 00 6C 33 29 5D 2E 37 23 05 52 6E 10 14 0D 77 13 50 5C 20 27 53 4A 37 2B 4D 68 65 37 1D 25 65 1B 3D 4C 74 28 19 2C 42 72 31 4A 67 30 5D 0D 75 1B 5D 10 6F 36 19 06 22 01 00 40 43 3A 1C 4D 42 71 00 6E 30 24 18 2E 26 6B 3D 5C 69 31 54 4C 56 63 15 42 73 32 48 08 17 23 51 42 63 35 48 04 04 1B 55 68 4F 33 19 44 02 02 0D 68 72 36 0B 44 03 39 55 06 74 39 1B 05 62 01 5C 6C 43 3A 1C 4D 42 71 00 6E 37 21 5D 0E 26 61 38 40 37 1C 10 6E 47 13 30 5C 20 1B 4E 28 37 20 48 F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 11 60 00 20 39 1B 05 62 01 60 60 43 3A 1C 4D 42 71 00 70 31 21 5D 0E 26 61 38 40 38 19 10 6E 47 13 30 5C 20 1C 0C 68 37 23 49 58 2E 10 0E 06 44 1B 51 64 6C 17 08 07 03 2A 0D 68 72 36 0B 44 03 41 59 06 74 39 1B 05 62 01 60 6E 43 3A 1C 4D 42 71 00 70 38 21 5D 0E 26 61 38 40 38 1C 50 6E 47 13 30 5C 20 1C 4C 0A 26 2B 59 4A 72 31 08 04 05 23 49 4A 6D 37 5B 0D 72 02 0D 50 6F 39 1D 2E 32 01 01 06 65 36 19 2E 37 23 14 40 50 34 18 2E 36 2B 48 40 20 22 18 2E 46 09 01 12 6E 31 51 0C 17 23 04 40 44 32 58 69 65 12 41 1C 20 26 14 68 24 72 49 20 4E 10 13 2A 34 12 49 20 4E 10 13 0A 34 11 01 24 50 27 08 09 55 1A 08 40 43 3A 1C 4D 42 71 44 60 32 21 5D 0E 26 61 38 62 30 19 50 6E 47 13 30 5C 31 18 0D 08 37 23 49 58 2E 18 4C 06 54 1B 51 64 6C 17 0C 26 03 32 0D 68 72 36 0B 46 13 01 5D 06 74 39 1B 05 63 09 40 70 43 3A 1C 4D 42 71 44 60 39 21 5D 0E 26 61 38 62 31 18 10 6E 47 13 30 5C 31 18 4C 28 37 20 43 F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 12 00 00 20 39 1B 05 63 09 44 64 43 3A 1C 4D 42 71 44 62 33 21 5D 0E 26 61 38 62 31 1A 10 6E 47 13 30 5C 31 18 4D 28 37 23 49 58 2E 18 4C 26 64 1B 51 64 6C 17 0C 26 13 3A 0D 68 72 36 0B 46 13 09 61 06 74 39 1B 05 63 09 44 72 53 37 5D 2D 66 22 3D 4C 66 29 19 2E 36 2B 51 02 6C 36 13 0D 76 1B 05 58 20 10 08 09 66 7B 51 4A 73 27 59 4C 64 7B 35 5C 69 10 13 6C 66 32 3D 5A 6E 34 48 09 76 71 01 1A 6F 37 1B 64 04 7B 38 40 50 37 5B 0F 12 02 3D 5C 20 0E 00 20 02 03 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1F 4F 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 7C 7E 00 1F 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0F 67 70 01 7C 00 3F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 56 F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 12 20 00 20 00 00 0F 67 70 01 7C 00 3F 00 0F 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7E 3F 00 0F 60 03 78 00 7E 00 1F 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 73 78 00 7E 00 1F 40 07 70 01 7C 00 3F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3F 1F 40 07 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 79 7C 00 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 01 7C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1F 4F 60 03 78 00 7E 00 1F 40 07 70 01 7C 00 3F 00 0F 60 03 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 7C 7E 00 1F 40 07 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 00 00 00 00 00 00 00 00 00 00 00 00 00 0F 67 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 01 7C 00 3F 00 0F 60 00 00 00 00 00 00 00 00 00 53 F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 12 40 00 20 00 00 0F 67 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 01 7C 00 3F 00 0F 60 03 78 00 00 00 00 00 00 00 00 00 7E 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 00 00 00 00 00 00 07 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 00 00 00 00 00 3F 1F 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18 00 00 00 00 03 79 7C 00 3F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 40 00 00 00 00 1F 4F 60 03 78 00 7E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C 00 00 00 00 01 7C 7E 00 1F 40 07 70 01 7C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 0F 67 70 01 7C 00 3F 00 0F 60 03 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 00 00 58 F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 12 60 00 20 00 00 0F 67 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 00 00 00 00 7E 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 01 7C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 07 73 78 00 7E 00 1F 40 07 70 01 7C 00 3F 00 0F 60 03 78 00 00 00 00 00 00 00 00 00 00 00 00 03 00 00 00 00 00 3F 1F 40 07 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 00 00 00 00 00 00 00 00 00 00 18 00 00 00 00 03 79 7C 00 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 01 7C 00 3F 00 0F 60 00 00 00 00 00 00 00 01 40 00 00 00 00 1F 4F 60 03 78 00 7E 00 1F 40 07 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 1F 40 00 00 00 00 00 0C 00 00 00 00 01 7C 7E 00 1F 40 07 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 01 7C 00 3F 00 00 00 00 60 00 00 00 00 0F 67 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 06 00 00 00 22 F7
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 13 00 00 20 00 00 1F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 78 57 F7
test in 1 - ok
test in 2
{crossout added 081210}
<del> as above. View from top. Midi cable entering from the right. Going to name the pins from bottom to top, 1 to 5. Put the black lead from COM onto pin 4 and the red pin on 2 as I think this would match the negative and positve as it should. But I get a negative voltage of 0.71. Also it connects to the opposite optocoupler leg as I expect. I see the diagrams show "rear view" and I am guessing this explains it but I don't what rear view means. It could mean either directions to me.
</del>
{text added 081210}
see above under TEST OUT 1 notes. Understand now.
{text added end 081210}
test in 3 - yep worked. Lit and then flickered as received sysex files. Had to change from smart mode as it didn't work after the initial send as mentioned in test in 3 (pic won't receive the data with LED connected)
test in 4 - didn't do as led lit in the test in 3
test in 5 - "TEST IN5: If this doesn't help you to detect the error, continue with the next step..". This isn't that clear to me. Should it read .. "if test 4 didn't help continue with this step 5, otherwise move onto step 6" ??
test in 6 - should I be doing test 6 if test3 worked? Is it if 3 worked then go to 6? (this step). Test 6 worked
test in 7 - Open - about 5V. Closed - about 40mV.
..continued below
4060_IMGP1654_jpgde92b63e2f1b0b0d089fedc
test inout 8 -  seems ok - see below:
00000000049203 ms | Sysex message: F0 00 00 7E 40 00 02 0C 00 00 20 43 7B 63 1F 05 4B 5E 19 78 2D 7D 71 4F 42 7B 6F 0C 7C 17 6E 78 67 61 42 77 46 3E 0D 7F 3C 33 70 71 7B 63 1F 06 77 5E 19 78 37 5D 71 4F 43 49 6F 0C 7C 19 0E 78 67 61 47 77 46 3E 0C 27 3C 33 70 63 3B 63 1F 04 03 5E 19 78 20 3D 71 4F 42 05 6F 0C 7C 10 3E 78 67 61 51 77 46 3E 0C 7F 3C 33 70 42 3B 63 1F 04 17 5E 19 78 21 5D 71 4F 40 24 00 00 00 02 20 00 00 00 12 00 00 00 01 10 00 00 00 09 00 00 00 00 48 00 00 00 04 40 00 00 00 24 00 00 00 1F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 78 7A F7
00000000049625 ms | Sysex message: F0 00 00 7E 40 00 02 0C 20 00 20 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 78 60 F7
00000000050031 ms | Sysex message: F0 00 00 7E 40 00 02 0C 40 00 20 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 78 40 F7
00000000050437 ms | Sysex message: F0 00 00 7E 40 00 02 0C 60 00 20 09 00 02 20 00 48 00 12 00 04 40 01 10 00 24 00 08 03 4F 0E 60 5B 60 01 07 20 1D 41 37 40 40 0E 09 3B 02 7F 05 17 58 1C 78 00 5D 41 6F 40 20 0E 01 5B 44 70 70 11 5C 00 07 2F 1D 41 37 40 13 6C 0D 3C 15 0E 60 77 60 53 76 06 5E 01 03 28 21 14 51 3B 02 6F 06 62 48 10 42 29 5D 41 7F 40 2F 6C 11 3C 00 00 76 7B 58 16 78 00 21 6D 77 30 2D 70 09 00 04 2E 60 6B 60 26 76 07 7E 01 10 00 33 6C 0D 3C 0A 3E 60 7F 60 0D 77 47 3E 01 10 02 05 6C 0B 3C 02 08 00 48 00 59 77 47 7E 05 1F 3C 3D 70 09 00 02 20 07 07 58 1E 78 2E 1D 41 77 40 06 50 30 7B 63 6F 04 23 5E 1C 78 02 6D 6F 40 2B 31 34 05 3B 03 5F 00 2D 21 7A 05 36 16 40 17 30 3B 70 42 3B 63 4F 00 48 00 12 00 16 7D 41 57 42 19 6F 0E 3C 02 20 00 48 00 07 07 30 2D 60 1B 3B 20 0E 49 05 40 35 00 3C 17 12 08 00 77 09 14 2B 70 0E 4B 05 40 33 47 20 60 07 05 65 42 21 10 02 00 50 07 42 70 0B 50 40 12 03 37 21 07 0E 41 53 40 0B 01 44 02 20 00 18 F7
00000000050843 ms | Sysex message: F0 00 00 7E 40 00 02 0D 00 00 20 63 3B 02 6F 00 11 5D 72 6F 41 02 4D 45 10 02 0E 7F 42 62 20 07 7C 1D 65 76 06 3E 01 43 20 32 6A 09 00 03 05 00 0D 5C 12 00 31 5D 41 37 40 30 14 6C 29 00 10 70 0D 5C 12 00 3D 5D 41 4F 40 06 6E 01 54 03 01 40 64 24 03 60 06 1E 01 10 00 33 30 07 76 03 1B 10 43 30 19 5A 04 3B 01 4D 58 25 58 0C 6E 02 3D 40 66 74 14 6C 06 37 41 2E 60 33 3E 0B 36 02 20 00 66 20 00 07 05 1A 01 4C 48 02 0E 08 74 03 19 20 08 1C 0E 68 06 32 60 18 38 17 50 0C 66 00 40 70 23 20 19 4D 01 21 60 2E 40 33 1C 03 03 40 2D 00 66 3C 07 07 01 2D 6C 36 7C 08 6E 02 54 00 36 72 47 5E 1A 78 0D 3D 71 7F 40 01 6E 20 7C 01 00 70 19 5D 6B 35 01 45 6F 6E 5C 24 00 00 00 28 02 48 0C 16 40 37 50 0A 11 7E 60 06 6E 00 43 4D 0E 60 5B 60 20 77 11 3E 00 00 05 00 51 6C 49 5B 75 00 6F 31 5F 5F 1F 61 30 1B 38 04 0E 34 3B 02 6F 01 03 5C 41 78 00 00 14 02 47 32 26 6F 54 01 6D 46 7E 7C 7F 05 40 6D 60 00 39 51 6C 0B 3C 02 20 00 2F F7
00000000051265 ms | Sysex message: F0 00 00 7E 40 00 02 0D 20 00 20 01 42 79 0E 60 5B 61 08 06 11 01 42 10 30 22 0C 0F 42 79 0E 60 5B 61 01 06 33 61 49 10 32 0C 0C 66 03 14 40 65 00 19 0F 06 20 01 48 20 32 10 0C 70 03 16 10 66 08 19 30 06 2E 01 4F 78 31 7E 0C 5F 43 1B 70 67 3C 19 77 06 3E 61 4F 68 33 7C 0C 67 43 1F 10 67 7C 19 7F 06 3F 61 4F 78 33 7E 0C 00 3B 02 6F 00 00 02 11 1C 41 61 3C 47 30 2D 70 03 74 00 6D 00 17 20 04 68 04 5A 01 0E 40 35 50 15 74 02 1C 07 23 7E 24 76 05 5E 01 16 03 51 7F 3F 42 64 4E 60 5B 60 13 60 3A 1F 77 78 2C 49 6C 0B 3C 04 0D 00 47 01 68 7F 49 1D 41 37 40 27 40 74 3F 6F 70 59 13 58 16 78 05 5A 01 0E 03 51 7F 12 3B 02 6F 00 00 02 00 07 04 75 50 16 40 26 35 3F 02 64 4E 60 5B 60 13 60 3A 1F 77 78 2C 49 6C 0B 3C 00 4D 00 47 01 68 7F 49 1D 41 37 40 11 6F 0B 3C 00 54 72 3D 4C 66 10 08 04 02 01 00 0A 4E 37 5D 0C 52 01 00 40 20 10 01 28 15 23 0D 50 20 10 08 04 02 00 0D 06 43 11 48 04 02 01 00 40 20 04 54 0E 26 38 59 F7
00000000051656 ms | Sysex message: F0 00 00 7E 40 00 02 0D 40 00 20 17 10 6D 06 73 1C 40 09 21 5A 0D 65 03 49 66 72 17 08 01 15 03 25 68 63 34 10 4D 66 21 00 10 4D 32 5D 0C 14 2B 59 68 20 10 00 00 11 0A 44 1E 0B 00 43 72 0E 60 5B 60 7C 07 25 1D 41 37 43 28 0E 7B 1B 46 50 77 5D 5C 00 00 44 27 10 38 2C 14 0D 79 54 1E 62 30 00 1D 77 11 02 20 0F 2A 42 39 6C 0B 3C 00 00 08 44 72 07 05 72 1D 41 37 40 0F 50 03 34 00 5D 00 3F 20 20 68 09 3A 02 4E 40 5B 50 09 30 1D 0F 79 7F 30 20 07 25 1D 41 37 40 27 40 74 3F 72 2E 60 5B 60 2A 68 04 58 0E 47 7E 25 6C 0B 3C 04 00 74 53 58 16 78 16 61 69 27 30 2D 70 09 70 1D 0F 7C 4B 58 16 78 17 21 69 27 30 2D 70 0C 34 02 3C 07 23 7E 01 07 64 5D 41 37 40 25 50 09 70 1D 0F 7C 4B 58 16 78 03 3A 01 1E 03 51 7F 49 3B 02 6F 00 23 20 12 60 3A 1F 79 47 30 2D 70 09 70 1D 0F 7C 63 58 16 78 04 40 01 0E 03 51 7F 4C 3B 02 6F 00 4B 01 68 7F 66 1D 41 37 40 27 40 74 3F 73 0E 78 5B 60 04 06 42 01 6F 19 13 6C 6E 1B 43 5E 42 00 63 F7
00000000052078 ms | Sysex message: F0 00 00 7E 40 00 02 0D 60 00 20 7B 5B 40 30 74 73 5E 16 78 0B 25 52 68 01 46 23 19 00 0C 42 69 48 00 64 11 4C 40 06 29 34 64 00 33 0B 26 20 03 18 46 32 00 19 65 53 10 01 4E 23 19 00 0C 12 69 48 00 61 11 4C 40 06 11 34 64 00 31 4B 26 10 03 0C 46 31 00 19 05 53 08 01 48 23 18 40 0C 52 69 44 00 66 16 4C 20 06 31 0C 62 00 33 4B 26 10 03 1C 46 31 00 18 25 53 08 01 42 23 18 40 0C 22 69 44 00 43 2F 4C 00 04 19 0C 60 00 22 17 66 00 02 10 46 30 00 11 2B 73 00 01 0C 5F 18 00 08 62 19 40 00 47 2F 4C 00 04 39 0C 60 00 20 57 66 00 02 04 46 30 00 10 4B 73 00 01 06 5F 18 40 08 32 19 44 00 44 2F 4C 20 04 21 0C 62 00 22 57 66 10 02 19 3E 31 00 11 44 33 08 01 0E 5F 18 40 08 72 19 44 00 41 2F 4C 20 04 09 0C 62 00 21 17 66 10 02 0D 3E 32 00 10 64 33 10 01 08 5F 19 00 08 42 19 48 00 45 2F 4C 40 04 32 7C 64 00 23 08 66 20 02 1D 3E 32 00 11 64 33 10 01 02 5F 19 00 08 12 19 48 00 42 2F 4C 40 04 1A 7C 66 00 21 48 66 30 00 55 F7
00000000052468 ms | Sysex message: F0 00 00 7E 40 00 02 0E 00 00 20 22 17 66 30 02 10 46 33 00 11 2B 73 18 01 0C 5F 19 40 08 62 19 4C 00 47 2F 4C 60 04 39 0C 66 00 20 57 66 30 02 04 46 33 00 10 4B 73 18 01 06 5F 1A 00 08 32 19 50 00 44 2F 4D 00 04 21 0C 68 00 22 57 66 40 02 19 3E 34 00 11 44 33 20 01 0E 5F 1A 00 08 72 19 50 00 41 2F 4D 00 04 09 0C 68 00 21 17 66 40 02 0D 3E 35 00 10 64 33 28 01 08 5F 1A 40 08 42 19 54 00 45 2F 4D 20 04 32 7C 6A 00 23 08 66 50 02 1D 3E 35 00 11 64 33 28 01 02 5F 1A 40 08 12 19 54 00 42 2F 4D 20 04 1A 7C 6C 00 21 48 66 60 02 11 3E 36 00 11 04 33 30 01 0A 5F 1B 00 08 65 79 58 00 46 11 4D 40 04 3A 7C 6C 00 23 48 66 60 02 05 3E 36 00 10 24 33 30 01 04 5F 1B 00 08 35 79 5C 00 43 11 4D 60 04 22 7C 6E 00 22 08 66 70 02 15 3E 37 00 11 4B 73 38 01 0C 23 1B 40 08 75 79 5C 00 47 11 4D 60 04 0A 7C 6E 00 20 48 66 70 02 09 3E 37 00 10 6B 73 40 01 06 23 1C 00 08 45 79 60 00 44 11 4E 00 04 2A 7C 70 00 23 17 67 00 00 4F F7
00000000052890 ms | Sysex message: F0 00 00 7E 40 00 02 0E 20 00 20 23 08 67 00 02 1D 3E 38 00 03 61 60 00 04 28 6F 09 00 01 70 70 00 02 15 37 44 40 00 00 04 28 51 6C 29 02 40 38 00 02 15 28 76 14 41 28 1C 00 01 0A 14 3B 0A 20 04 1C 03 37 06 01 66 07 30 2D 70 00 00 22 55 0E 62 48 01 07 00 6D 61 48 39 41 6C 0B 3C 02 20 00 00 02 31 35 4C 4D 33 1B 2C 68 6B 18 1A 62 20 00 0D 5C 00 00 7E 01 60 1B 00 6F 50 01 6F 46 06 59 41 23 7D 07 76 16 0F 68 38 06 0F 64 3B 02 6F 00 0B 20 08 68 02 5A 0F 10 38 06 62 01 34 06 02 59 07 20 30 35 47 7A 00 1E 00 6B 70 7C 75 60 3B 01 56 1F 58 48 00 66 03 33 3C 6A 51 01 42 60 60 6F 4F 1E 34 78 0D 26 1E 41 40 06 0B 19 5B 66 53 48 3C 16 35 37 4D 47 1F 00 2C 6A 13 1B 0E 21 70 59 59 5E 35 60 0C 5E 03 36 00 63 70 01 34 00 00 58 48 00 01 07 3F 61 31 10 00 06 50 7C 02 40 4E 00 0D 21 7A 05 03 7C 0F 26 5C 68 2B 0B 43 46 46 2F 4B 2E 34 35 4C 65 30 18 38 66 65 76 75 66 36 59 48 57 58 58 0C 25 3E 46 5C 68 6B 19 5A 66 26 58 00 F7
00000000053296 ms | Sysex message: F0 00 00 7E 40 00 02 0E 40 00 20 18 5A 7C 3D 38 00 02 38 35 4E 2D 3D 00 38 74 6F 03 43 47 36 78 48 00 00 00 4E 05 21 10 00 00 01 1D 01 5B 0A 01 6C 0C 3A 28 4E 62 10 3F 07 20 0E 1D 1B 60 70 71 6D 5E 38 60 0E 3E 03 43 28 24 00 28 03 5E 66 71 68 1D 77 37 0E 38 0E 47 7F 6C 26 00 03 5E 72 10 24 01 75 28 04 40 00 00 04 04 03 02 41 40 70 40 28 16 0C 06 43 62 01 08 48 28 15 0B 05 63 11 50 6C 38 1E 0F 48 04 12 19 10 4A 26 14 0A 25 22 59 34 5C 2F 18 0C 46 33 21 54 6E 38 1C 4E 47 43 69 78 7E 41 21 10 68 44 32 1D 10 49 25 53 09 54 72 41 22 52 29 55 2A 65 3A 61 34 5B 2E 17 2B 76 03 05 44 64 32 59 4C 76 4B 29 56 6C 37 1B 6E 07 0B 4D 68 75 3B 1E 0F 17 53 6D 7A 7E 3F 60 10 28 1C 12 0B 07 44 22 31 28 64 36 1D 0F 48 64 52 39 24 5A 2F 18 4C 66 73 49 6C 7A 41 21 51 28 74 5A 35 1E 51 2A 55 6B 15 5A 7D 42 63 32 5A 2D 36 6B 3D 66 75 3B 5E 2F 57 7C 06 07 07 44 62 71 59 0C 4E 2B 17 4D 67 33 7A 0D 16 4F 29 55 6B 76 1B 1D 50 2C F7
00000000053703 ms | Sysex message: F0 00 00 7E 40 00 02 0E 60 00 20 6E 37 3B 6D 7F 07 45 63 72 39 5C 7E 47 27 57 6C 76 7B 5E 0F 0F 4B 67 75 7B 3D 7F 0F 57 6F 79 7D 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 70 00 04 42 6B 11 1A 64 36 59 11 56 20 35 44 40 00 1B 3B 70 0E 01 58 06 7D 00 00 02 03 28 3C 21 23 47 00 41 3F 1C 74 00 3B 71 01 56 20 28 7D 61 7D 45 43 6E 0E 04 43 79 0E 60 5B 60 08 68 02 3A 00 56 40 17 50 06 34 02 2D 00 57 20 18 68 06 7A 0F 00 38 0F 50 3F 43 40 5D 03 7C 1C 03 68 00 21 60 0E 40 02 0E 01 58 40 2D 01 00 56 12 68 08 0D 31 06 40 06 50 10 5B 64 56 7F 63 2E 03 28 08 4D 72 33 3F 69 57 01 54 04 36 79 1D 5F 70 6B 40 6A 02 23 3C 50 6F 01 34 00 00 58 48 00 01 07 3F 61 31 10 00 40 6B 10 23 7F 0D 39 01 56 03 1C 01 61 3C 47 30 2D 70 03 74 01 1D 00 2B 20 0B 68 03 1A 00 76 40 1F 50 08 34 06 3D 40 15 F7
00000000054109 ms | Sysex message: F0 00 00 7E 40 00 02 0F 00 00 20 14 03 41 7D 01 20 1C 1A 68 09 61 60 5E 40 4E 0E 0B 34 05 2D 41 18 1C 06 68 09 41 61 0E 40 4A 0E 01 34 04 50 70 37 20 10 77 08 3E 0E 0B 3B 60 0E 73 45 40 35 00 3C 17 67 09 00 6A 0B 00 2C 00 0A 67 78 39 4D 38 43 5C 21 78 38 2D 60 78 3B 4E 16 01 4E 1E 00 5F 1C 24 03 28 3C 01 37 00 2B 01 61 12 70 04 1F 01 1B 00 22 78 09 78 02 1F 40 51 40 12 3C 17 1D 39 10 56 17 07 08 37 31 40 38 43 3D 0E 43 44 46 28 48 00 24 35 48 65 33 58 38 46 65 09 00 04 36 59 08 56 3B 07 08 4C 51 10 00 44 6B 10 4A 23 70 59 05 5E 12 00 01 6D 20 33 38 14 0E 03 17 00 3E 18 19 5C 07 15 3E 5A 71 10 01 20 2A 28 14 0C 56 70 77 58 1F 78 00 78 0E 77 7C 09 40 77 3F 60 5C 07 3B 7E 66 35 04 10 01 10 00 21 28 03 34 00 35 07 60 14 51 70 00 6A 0F 70 29 1D 60 7C 03 40 36 01 2F 20 03 57 00 7A 00 1E 01 23 70 29 1A 0A 22 50 08 1C 52 32 00 3A 05 13 3B 5E 0E 28 59 07 6D 02 45 21 71 05 04 17 03 57 01 26 28 07 42 6A 36 70 1F F7
00000000054531 ms | Sysex message: F0 00 00 7E 40 00 02 0F 20 00 20 00 3B 4A 4F 00 0F 01 6B 7F 54 2A 00 38 2F 11 6C 0B 3C 00 7D 00 1F 20 07 68 01 7A 00 3E 40 0F 50 03 74 00 7D 01 1B 20 09 68 05 1A 00 3E 40 05 50 00 74 00 0D 00 11 54 05 35 14 4D 2B 46 5D 24 04 0D 38 2A 1C 00 0F 60 00 77 15 1E 05 1A 43 56 50 02 1B 40 56 72 49 55 2C 6B 54 4A 0F 70 3C 1B 61 28 70 00 3F 00 03 5C 54 78 14 60 40 78 2F 57 4F 02 3C 00 10 7F 2F 1E 05 78 14 4D 29 66 5C 24 00 01 54 15 7E 60 77 60 24 70 00 00 12 0A 44 3E 0B 25 3B 03 6F 00 1A 1C 07 60 12 1E 00 36 01 0F 70 11 14 29 2E 60 7B 60 06 47 01 78 04 37 40 0D 40 22 7C 04 35 0A 2B 58 1E 78 01 51 60 3E 01 09 70 03 30 08 3F 01 11 22 4A 76 07 5E 00 3E 01 05 70 03 30 08 1F 00 42 18 10 4D 04 10 21 10 00 07 40 05 3C 00 35 05 33 58 1C 78 0C 7C 00 00 04 63 40 01 7C 06 22 4E 62 68 03 15 3D 1D 41 37 40 08 38 07 42 69 06 70 11 20 0F 05 51 6D 60 19 60 1E 0B 23 1B 40 35 00 3C 17 00 04 51 2D 64 42 40 15 61 08 03 49 06 70 7F F7
00000000054921 ms | Sysex message: F0 00 00 7E 40 00 02 0F 40 00 20 23 54 00 6E 08 40 1C 47 37 11 4A 00 17 04 20 0E 23 1B 42 00 72 11 5C 00 00 4C 65 10 78 2E 00 09 21 5B 46 42 49 67 3E 07 28 36 16 41 00 39 04 6E 03 30 08 1F 00 42 14 10 4E 04 10 20 56 00 07 70 09 00 00 0E 74 03 60 65 28 00 61 5F 1A 43 52 26 7A 14 1D 22 10 48 00 10 60 01 5E 02 3E 60 21 16 74 2C 02 08 31 03 30 10 4C 3A 16 01 04 20 20 50 03 06 5B 0A 20 42 00 12 00 00 01 60 1B 08 03 50 02 74 00 10 70 0D 44 01 68 02 3A 01 10 00 09 30 09 00 0C 62 57 70 1C 66 30 19 4D 61 04 00 24 00 02 2C 02 20 03 19 21 58 52 19 40 61 04 00 24 00 01 03 42 2E 78 6B 60 03 07 04 5D 71 57 41 4E 2A 33 54 0F 70 5E 62 68 10 40 04 40 01 05 48 77 58 08 28 02 20 00 42 20 66 28 14 0B 46 2B 38 06 0E 32 1B 4C 45 00 42 68 05 68 10 01 5F 1A 42 11 6C 0B 3C 00 4D 00 0D 5C 00 07 2B 5D 41 37 42 5F 6C 0F 7C 0C 50 37 7C 1D 58 50 19 2D 61 05 70 0B 50 08 2E 40 3D 03 10 0D 68 71 00 5A 06 21 3B 4B 57 33 14 02 5E 00 68 F7
00000000055343 ms | Sysex message: F0 00 00 7E 40 00 02 0F 60 00 20 33 6B 42 20 00 38 1C 10 5E 13 41 61 05 69 1C 0E 44 3B 02 6F 02 6C 1D 14 76 05 5E 02 68 3A 29 6C 0B 3C 0C 65 04 4B 58 16 78 17 21 69 27 30 2D 70 09 00 02 09 10 42 54 05 68 00 01 68 47 30 2D 70 31 7B 04 1F 00 42 58 05 68 00 01 68 47 30 2D 70 4C 3B 04 1F 00 48 00 00 07 00 6D 64 00 38 08 6E 0A 03 40 56 72 50 1D 28 77 45 5E 01 6F 30 3F 70 77 33 62 1F 07 3B 1E 12 78 3B 59 71 1F 40 22 50 05 78 02 1D 01 00 5A 7C 10 0F 0D 66 79 01 4A 76 32 5B 4E 43 71 00 40 20 10 08 04 07 20 3B 6C 6E 1F 43 5E 76 70 50 1D 1C 77 45 5E 01 05 18 2B 50 08 54 1E 00 5D 40 14 11 70 44 2A 00 78 2C 02 0F 48 3B 02 6F 03 70 1D 14 76 05 5E 01 12 41 79 59 10 03 52 4E 60 5B 60 13 28 24 5D 41 37 41 67 51 77 43 42 16 23 3B 22 11 28 03 61 3C 47 30 2D 70 0C 74 04 3D 01 57 20 4D 68 18 5A 07 16 42 05 50 49 74 1C 3D 07 4F 20 03 68 44 7A 12 1E 44 67 51 21 74 2A 3D 0A 18 60 7C 10 1A 2D 67 23 15 64 6E 30 5B 04 06 28 16 F7
00000000055734 ms | Sysex message: F0 00 00 7E 40 00 02 10 00 00 20 39 1C 4D 77 11 00 41 72 07 3D 4D 63 78 3B 6E 6E 0A 03 53 4E 78 5B 60 46 18 5F 04 04 6A 51 06 20 0A 03 5E 66 72 00 1D 77 37 02 01 69 67 30 2D 70 09 14 13 0E 60 5B 60 0A 07 29 1A 14 31 49 78 20 29 5B 6D 66 39 01 20 6F 39 48 00 03 20 3B 6C 6E 20 03 5E 76 70 34 1D 1C 76 05 5E 01 1A 42 31 6C 0B 3C 04 00 74 53 58 16 78 04 4A 09 47 30 2D 70 01 03 51 3D 0A 18 66 7C 10 14 6D 76 73 1C 40 53 32 5B 04 00 03 18 1D 76 37 10 01 6F 3B 38 1A 0E 4E 3B 02 6F 00 49 21 12 76 05 5E 00 20 39 71 51 23 0D 0F 42 03 55 5C 64 32 59 4D 16 73 15 48 20 10 08 04 02 01 00 41 0C 07 3D 4D 64 00 3B 6E 6E 0A 03 53 4E 78 5B 60 46 1A 5F 04 07 2B 39 48 65 33 1A 2D 66 2B 10 40 20 10 08 04 02 01 02 5C 0E 7B 1B 48 00 77 5D 5C 14 07 27 1D 71 37 41 0C 36 3E 08 0A 47 2B 39 4A 20 29 19 2E 17 2B 15 66 74 10 08 04 02 06 40 1D 76 37 10 01 6F 3B 38 28 0E 4E 3B 62 6F 02 4D 70 7C 00 08 07 45 1B 65 66 45 3C 08 0C 57 40 2A F7
00000000056156 ms | Sysex message: F0 00 00 7E 40 00 02 10 20 00 20 38 1A 2E 26 2B 10 7C 20 00 3C 41 6F 33 39 00 0E 7B 5B 40 30 74 73 58 16 78 19 2A 05 00 60 07 60 08 43 53 4E 78 5B 60 01 07 01 4D 60 07 39 29 70 29 41 01 70 58 1D 5C 06 15 01 6A 0E 5A 43 60 0A 02 78 00 70 20 3C 16 07 37 01 55 0F 36 5C 12 0E 03 18 02 4D 00 21 54 07 28 3A 6A 09 47 30 2D 70 03 4A 01 70 58 1D 5C 08 15 02 05 20 31 3B 6B 57 10 03 52 4E 60 5B 60 08 15 04 01 60 43 13 73 57 09 00 0A 35 07 60 1E 0F 05 41 6D 60 40 38 0C 6E 03 54 1D 35 04 63 58 16 78 01 65 00 78 2C 0E 6E 03 0B 5E 7D 39 38 1D 14 77 45 5E 04 31 61 78 20 26 52 28 44 49 01 06 6C 37 58 6D 32 01 00 40 20 10 08 12 60 77 59 5C 41 07 3D 6D 61 20 3A 39 6F 0B 3C 08 63 4B 70 40 4D 24 51 09 12 02 51 52 63 35 48 04 02 01 00 40 20 10 2E 01 6F 33 39 02 0E 7B 5B 42 40 74 73 5E 16 78 11 48 17 61 01 1A 49 22 12 24 05 1B 51 42 72 3A 08 04 02 01 00 40 20 6D 03 5E 66 72 04 1D 77 37 05 01 69 67 3C 2D 70 23 10 4F 42 00 4D F7
00000000056562 ms | Sysex message: F0 00 00 7E 40 00 02 10 40 00 20 26 52 28 44 49 01 06 6F 37 1D 0D 16 73 55 4A 20 10 08 1F 40 77 59 5C 41 07 3D 6D 61 20 3A 39 6F 0B 3C 08 64 1B 70 40 4D 24 51 09 12 02 4D 68 6F 38 08 04 02 01 00 40 20 10 07 41 6F 33 39 04 0E 7B 5B 42 40 74 73 5E 16 78 11 48 47 61 01 6A 6E 32 19 2C 66 4B 39 4A 64 10 08 04 02 01 00 40 20 20 03 5E 66 72 08 1D 77 37 05 01 69 67 3C 2D 70 23 11 2F 42 02 05 46 74 34 5D 4C 52 02 4D 4A 6E 39 59 24 02 01 00 40 62 07 3D 4D 64 10 3B 6E 6E 0A 03 53 4E 78 5B 60 46 23 1F 04 04 6A 25 08 49 10 14 4C 57 1B 15 68 20 10 08 04 02 01 02 08 0E 7B 1B 48 20 77 5D 5C 14 07 27 1D 71 37 40 25 6C 0D 7C 02 35 03 3B 20 08 06 5F 41 6F 33 39 08 0E 7B 5B 5E 35 07 58 4D 74 28 3D 64 20 40 3A 39 6F 0B 3C 09 05 04 3B 58 21 78 11 6A 08 77 30 43 70 23 14 11 6E 61 07 60 45 28 24 1D 42 0F 40 5C 0E 49 7B 04 1F 02 11 21 0E 76 08 3E 04 1A 42 21 6C 10 7C 05 60 74 4F 58 21 78 10 4A 08 77 30 43 70 20 54 12 0E 60 50 F7
00000000056968 ms | Sysex message: F0 00 00 7E 40 00 02 10 60 00 20 10 7C 00 30 71 6F 30 1C 76 07 3E 09 17 30 2D 70 05 36 08 20 70 27 30 50 07 01 7B 04 68 38 0B 50 74 2E 00 2D 04 3B 5E 16 78 08 01 69 27 3C 2D 70 26 55 08 33 51 00 00 2A 07 3D 4D 64 18 3B 6E 6E 02 43 53 4E 60 5B 60 48 28 06 1B 04 3A 40 2D 58 1D 03 42 7D 42 19 20 12 6C 11 2A 01 06 60 74 0E 08 76 08 45 00 33 30 43 28 02 5B 03 50 38 17 58 21 14 00 6D 42 05 20 04 6C 01 01 60 3E 43 51 38 6C 75 71 6E 78 5B 60 20 07 25 1D 71 37 40 14 6E 10 03 52 4E 60 5B 60 0A 17 3E 7A 71 10 00 21 34 1F 34 04 00 6F 51 20 06 06 6A 41 6F 33 39 06 0E 7B 5B 5E 35 07 58 4D 74 28 3D 64 20 28 3A 39 6F 0B 3C 00 10 00 00 00 00 00 00 40 00 00 00 00 00 01 40 00 00 00 00 00 03 00 40 00 00 00 00 06 02 00 00 00 00 00 0C 06 00 00 00 00 00 18 0C 02 00 00 00 00 30 18 08 00 00 00 00 60 30 18 00 00 00 01 40 60 30 08 00 00 03 01 40 60 20 00 00 06 03 01 40 60 10 00 0C 06 03 01 40 40 00 18 0C 06 03 01 40 00 30 18 2B F7
00000000057375 ms | Sysex message: F0 00 00 7E 40 00 02 11 00 00 20 01 40 60 30 08 0C 06 03 01 40 60 20 33 39 7C 0E 7B 1B 49 00 77 5D 5D 2A 76 05 5E 00 32 40 40 0D 7A 14 12 4E 60 5B 61 7C 07 3D 4D 67 60 3B 6E 6E 55 3B 62 6F 00 42 68 12 00 0F 41 6F 33 39 08 0E 7B 5B 5C 6E 78 5B 60 00 00 00 00 00 00 00 00 00 00 04 02 01 00 40 20 10 00 00 02 41 20 50 28 14 0A 00 00 01 28 54 2A 15 0A 45 20 00 00 00 08 06 03 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 21 18 2D 66 59 01 1A 53 21 13 2D 76 22 5D 50 65 32 5B 08 27 13 15 42 74 34 08 04 04 1B 51 64 6C 17 08 04 03 1A 19 5E 6F 3A 10 6E 47 13 31 20 6F 39 1D 0A 46 4B 35 4A 44 30 5D 0C 12 02 35 26 42 2B 1B 6D 47 2B 35 4A 20 10 10 4C 16 63 05 5C 63 32 48 08 37 23 49 58 2E 10 08 07 15 03 05 5C 6F 39 18 2D 56 0A 15 70 70 39 0B 44 02 01 01 0C 78 11 4C 24 04 6A 4D 04 46 3C 08 66 22 02 35 26 42 21 5D 0E 26 61 38 40 31 1A 10 6E 47 13 30 5C 20 18 4D 28 37 20 26 F7
00000000057781 ms | Sysex message: F0 00 00 7E 40 00 02 11 20 00 20 39 1B 05 62 01 44 6C 43 3A 1C 4D 42 71 00 62 37 21 5D 0E 26 61 38 40 31 1C 10 6E 47 13 30 5C 20 18 4E 28 37 23 49 58 2E 10 0C 46 04 1B 51 64 6C 17 08 06 23 0A 0D 68 72 36 0B 44 03 11 49 06 74 39 1B 05 62 01 48 66 43 3A 1C 4D 42 71 00 64 34 21 5D 0E 26 61 38 40 32 1A 50 6E 47 13 30 5C 20 19 0D 48 37 23 49 58 2E 10 0C 46 74 1B 51 64 6C 17 08 06 23 42 0D 68 72 36 0B 44 03 11 65 06 74 39 1B 05 62 01 4C 60 43 3A 1C 4D 42 71 00 66 31 21 18 2D 66 59 01 18 53 21 13 2D 76 21 00 40 4C 29 50 48 27 13 15 42 74 26 14 68 24 1B 51 64 6C 17 08 06 33 2A 19 5E 6F 3A 0B 49 45 1A 09 20 6F 39 1D 0C 14 62 4D 04 44 30 5D 0C 12 02 31 26 42 2B 1B 6D 42 71 01 18 53 21 10 4C 16 61 38 40 4C 29 50 48 37 23 49 58 2E 10 0D 06 15 03 05 5C 2E 10 13 0A 34 12 15 70 70 39 0B 49 45 1A 09 0C 78 11 4C 24 04 62 4D 04 46 3C 08 66 22 02 31 26 42 21 5D 0E 26 61 38 40 34 1B 10 6E 47 13 30 5C 20 1A 0D 68 37 20 22 F7
00000000058187 ms | Sysex message: F0 00 00 7E 40 00 02 11 40 00 20 39 1B 05 62 01 50 70 43 3A 1C 4D 42 71 00 68 39 21 5D 0E 26 61 38 40 35 18 10 6E 47 13 30 5C 20 1A 4C 28 37 23 49 58 2E 10 0D 26 24 1B 51 64 6C 17 08 06 53 1A 0D 68 72 36 0B 44 03 29 51 06 74 39 1B 05 62 01 54 6A 43 3A 1C 4D 42 71 00 6A 36 21 5D 0E 26 61 38 40 35 1B 50 6E 47 13 30 5C 20 1A 4E 08 37 23 49 58 2E 10 0D 27 14 1B 51 64 6C 17 08 06 63 02 0D 68 72 36 0B 44 03 31 45 06 74 39 1B 05 62 01 58 64 43 3A 1C 4D 42 71 00 6C 33 29 5D 2E 37 23 05 52 6E 10 14 0D 77 13 50 5C 20 27 53 4A 37 2B 4D 68 65 37 1D 25 65 1B 3D 4C 74 28 19 2C 42 72 31 4A 67 30 5D 0D 75 1B 5D 10 6F 36 19 06 22 01 00 40 43 3A 1C 4D 42 71 00 6E 30 24 18 2E 26 6B 3D 5C 69 31 54 4C 56 63 15 42 73 32 48 08 17 23 51 42 63 35 48 04 04 1B 55 68 4F 33 19 44 02 02 0D 68 72 36 0B 44 03 39 55 06 74 39 1B 05 62 01 5C 6C 43 3A 1C 4D 42 71 00 6E 37 21 5D 0E 26 61 38 40 37 1C 10 6E 47 13 30 5C 20 1B 4E 28 37 20 48 F7
00000000058593 ms | Sysex message: F0 00 00 7E 40 00 02 11 60 00 20 39 1B 05 62 01 60 60 43 3A 1C 4D 42 71 00 70 31 21 5D 0E 26 61 38 40 38 19 10 6E 47 13 30 5C 20 1C 0C 68 37 23 49 58 2E 10 0E 06 44 1B 51 64 6C 17 08 07 03 2A 0D 68 72 36 0B 44 03 41 59 06 74 39 1B 05 62 01 60 6E 43 3A 1C 4D 42 71 00 70 38 21 5D 0E 26 61 38 40 38 1C 50 6E 47 13 30 5C 20 1C 4C 0A 26 2B 59 4A 72 31 08 04 05 23 49 4A 6D 37 5B 0D 72 02 0D 50 6F 39 1D 2E 32 01 01 06 65 36 19 2E 37 23 14 40 50 34 18 2E 36 2B 48 40 20 22 18 2E 46 09 01 12 6E 31 51 0C 17 23 04 40 44 32 58 69 65 12 41 1C 20 26 14 68 24 72 49 20 4E 10 13 2A 34 12 49 20 4E 10 13 0A 34 11 01 24 50 27 08 09 55 1A 08 40 43 3A 1C 4D 42 71 44 60 32 21 5D 0E 26 61 38 62 30 19 50 6E 47 13 30 5C 31 18 0D 08 37 23 49 58 2E 18 4C 06 54 1B 51 64 6C 17 0C 26 03 32 0D 68 72 36 0B 46 13 01 5D 06 74 39 1B 05 63 09 40 70 43 3A 1C 4D 42 71 44 60 39 21 5D 0E 26 61 38 62 31 18 10 6E 47 13 30 5C 31 18 4C 28 37 20 43 F7
00000000058984 ms | Sysex message: F0 00 00 7E 40 00 02 12 00 00 20 39 1B 05 63 09 44 64 43 3A 1C 4D 42 71 44 62 33 21 5D 0E 26 61 38 62 31 1A 10 6E 47 13 30 5C 31 18 4D 28 37 23 49 58 2E 18 4C 26 64 1B 51 64 6C 17 0C 26 13 3A 0D 68 72 36 0B 46 13 09 61 06 74 39 1B 05 63 09 44 72 53 37 5D 2D 66 22 3D 4C 66 29 19 2E 36 2B 51 02 6C 36 13 0D 76 1B 05 58 20 10 08 09 66 7B 51 4A 73 27 59 4C 64 7B 35 5C 69 10 13 6C 66 32 3D 5A 6E 34 48 09 76 71 01 1A 6F 37 1B 64 04 7B 38 40 50 37 5B 0F 12 02 3D 5C 20 0E 00 20 02 03 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1F 4F 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 7C 7E 00 1F 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0F 67 70 01 7C 00 3F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 56 F7
00000000059546 ms | Sysex message: F0 00 00 7E 40 00 02 12 20 00 20 00 00 0F 67 70 01 7C 00 3F 00 0F 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7E 3F 00 0F 60 03 78 00 7E 00 1F 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 73 78 00 7E 00 1F 40 07 70 01 7C 00 3F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3F 1F 40 07 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 79 7C 00 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 01 7C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1F 4F 60 03 78 00 7E 00 1F 40 07 70 01 7C 00 3F 00 0F 60 03 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 7C 7E 00 1F 40 07 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 00 00 00 00 00 00 00 00 00 00 00 00 00 0F 67 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 01 7C 00 3F 00 0F 60 00 00 00 00 00 00 00 00 00 53 F7
00000000059968 ms | Sysex message: F0 00 00 7E 40 00 02 12 40 00 20 00 00 0F 67 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 01 7C 00 3F 00 0F 60 03 78 00 00 00 00 00 00 00 00 00 7E 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 00 00 00 00 00 00 07 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 00 00 00 00 00 3F 1F 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18 00 00 00 00 03 79 7C 00 3F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 40 00 00 00 00 1F 4F 60 03 78 00 7E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C 00 00 00 00 01 7C 7E 00 1F 40 07 70 01 7C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 0F 67 70 01 7C 00 3F 00 0F 60 03 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 00 00 58 F7
00000000060359 ms | Sysex message: F0 00 00 7E 40 00 02 12 60 00 20 00 00 0F 67 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 00 00 00 00 7E 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 01 7C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 07 73 78 00 7E 00 1F 40 07 70 01 7C 00 3F 00 0F 60 03 78 00 00 00 00 00 00 00 00 00 00 00 00 03 00 00 00 00 00 3F 1F 40 07 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 00 00 00 00 00 00 00 00 00 00 18 00 00 00 00 03 79 7C 00 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 01 7C 00 3F 00 0F 60 00 00 00 00 00 00 00 01 40 00 00 00 00 1F 4F 60 03 78 00 7E 00 1F 40 07 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 1F 40 00 00 00 00 00 0C 00 00 00 00 01 7C 7E 00 1F 40 07 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 01 7C 00 3F 00 00 00 00 60 00 00 00 00 0F 67 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 1F 40 07 70 01 7C 00 3F 00 0F 60 03 78 00 7E 00 06 00 00 00 22 F7
00000000060781 ms | Sysex message: F0 00 00 7E 40 00 02 13 00 00 20 00 00 1F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 78 57 F7
Midi monitor out (from mios studio):
There was the same number of bytes this time.
It's time for me to read more about mios I think.
I figure there is something a little odd going on I think but will try and redo the resistor bread board to double check.
Any comments / suggestions welcome.
thanks
Martin
- I may try and do the tests again in the next week to see if I can duplicate the info
4062_IMGP1651_jpge768e3dabc5a75d91e1dc9f
4064_IMGP1657_jpg8746b3e5bd0a5a7c85b2fc1
hey stryd
I guess for a couple of reasons:
- The resistor bread board I did I am reasonably confident it is ok.
- I kind of read it as testing through midi, not testing the midi only. I thought it may have yielded some results about my core that someone could comment on but I guess it didn't.
- Just to do them to see (figured doing something is better than nothing - probably learned something from the process). I haven't really tried to understand what the tests mean yet.
That's ok. I'll keep searching and trying things.
Think I'll try and build the merger to see if that works. If not - I'll search for more troubleshooting tips/instructions for other parts of the core. If it does, I'll build another resistor array board.
Cheers,
martin
edit:
You say, it uploded successfully and worked fine over midi, but the buttons don't work, correct?
yes. that's correct.
MIDIMERGER MIDI_MERGER
yo, So I went about building the merger. Made the extra board via (i kinda had it a bit mixed - I didn't have the 6 pin ging to the RA4) J4.
So I downloaded the midimerger-V1.5 and check out what options I have
MIDIbox Hardware Platform: MIDI Merger
Copyright 2003-2008 Thorsten Klose (tk@midibox.org)
Licensed for personal non-commercial use only.
All other rights reserved.
Hardware Requirements:
   * Core Module stuffed with PIC16F874, PIC16F877, PIC18F452 or similar
   * a second MIDI In on Port J4 of the Core Module
     (see http://www.ucapps.de/midimerger/midimerger.pdf and
          http://www.ucapps.de/midimerger/midimerger_pic18f.pdf)
Optionally a minimal variant is supported, which gets use of the PIC16F88
      see http://www.ucapps.de/midimerger/midimerger_pic16f88.pdf
Description:
   see http://www.ucapps.de/midimerger.html
Preassembled Firmwares:
   * midimerger_pic18f_with_bootloader.hex
   * midimerger_pic18f_without_bootloader.hex
   * midimerger_pic16f87x.hex
   * midimerger_pic16f88.hex
Reassembling the Firmware:
   see http://www.ucapps.de/howto_tools_gpasm.html
Informations about the Midibox Hardware Platform:
   http://www.ucapps.de/mbhp.html
Contact EMail address: tk@midibox.org
So I figure yeah I want the midimerger with pic18F452 and I don't want the bootloader or mios because I already have it so I choose the  "* midimerger_pic18f_without_bootloader.hex" option - sounds ok midimerger without bootloader for PIC18F452. Now I know that was the wrong choice. "* midimerger_pic18f_without_bootloader.hex" is actually saying that I should use this if my pic18f452 doesn't have the bootloader. aside - doesn't the bootloader need to be burnt? (maybe once it is burnt it can be upgraded - the mios/bootload folder seem to hint at this). Anyway, I chose the wrong one and tried it on both cores.
It didn't work obviously. Sorry details after this a  bit hazy ( I was just trying things. I know - I know - *reader switches off right about now*) I uploaded the midimon and I think it worked out but the LCD had a bit funny characters on it. I tried to upload mios_v1_9f_pic18f452.hex via the the mios_update_v1_9f - boot loader folder with the wait for and didn't. At some point my lcd (4x20) had just black squares across rows 1 and 3. This is what I got every time I tried to install. Starting upload of midimerger_pic18f_with_bootloader.hex
Hex file contains code in MIOS range, forcing reboot!
Tonight I put in my 3rd PIC. Didn't attach LCD and uploaded the midimerger (midimerger_pic18f_with_bootloader.hex). It worked after I fixed up the RA4 thing - so cool. Was triggering my micokorg with mios keyboard and drums - I didn't get into testing the clock from cubase with something else or anything.
Then I thought I'm on a roll here and thought I'd try the midimon and buttons so I disconnected the J4 and attached the LCD and the bottons off J5. LCD still had black squares
Uploaded the setup_default.hex for midimon_V2_0b (pretty sure I did smart) - and no didn't record the input output sorry. Then I tried the midimerger again and it didn't work. I tried uploading manual mode and it didn't work. I then tried to upload the mios_v1_9f_pic18f452.hex a few times (smart and manual, with and without wait. For the wait, I had power disconnected, pressed start and then connected power.)
This is what I got every time I tried to install. Starting upload of mios_v1_9f_pic18f452.hex
Hex file contains code in MIOS range, forcing reboot! (- nothin!)
I figured there was nothing wrong with what I was doing. I was only trying to upload those three things for this 3rd PIC. Effectively just reinstalling windows and programs right?
So I know I gotta test (I got reason to now right stryd :))
I so suck at this. haha
..but I had a brief moment of joy. Like a {text edit 081210} <del>prefect</del> perfect {text edit 081210 end} shot in a round of shite golf.
Noted. I do agree that I should read more.
I post often to help new others that might find themselves in my situation and not just for me. I added wiki links for the midimon, merger  etc. a few nights ago. Nothing much but better than nothing. I am not a leach.
Also it might be helpful to start a new forum section for 'other' official projects such as the midimerger, midimon and clockbox (maybe I am wrong here). I know people do enough already but there doesn't seem to be a bit for them.
Also I'll make an effort not to post.
martin
The hare lost because he was cocky. (take that!!  :P)
hola amigos
Have had a little break and just did some testing today.
Test core 4. PIC3/board2 - All ok except RD1 which was 15mV. This was the same as PIC1/board 1. Also I swapped the PIC1 on board 1 with PIC2. Same - no voltage at RD1.
In my testing a week ago I must have loosened an LCD connection and it came loose at the LCD end without me seeing. It was Rw.
I am thinking this is the cause of my dramas?? Don't know if <edit 081220> not <edit end> having Rw connected would screw up the PIC or other components.
when I connect my PIC3/board2 core I get this message at power on at the midi monitor in on mios studio '00000000013765 ms | Sysex message: F0 00 00 7E 40 00 01 F7'. <edit 081220> seems like bootloader and mios are there as correct message and not repeating every 2 seconds <edit end>
Just think it's weird that the merger seemed to be working and when I connected the LCD and uploaded the midimon hex it screwed up the board (2 variables here unfortunately. 3 including J5 resistor board)
I didn't finish with the testing just now. I guess I will when I come back from xmas break ( will get some reading in for sure - I was hoping to have all this hardware stuff sorted so I can start to play with coding and mios so a little frustrating that I can't get these simple things off the ground. I am learning all the time so all good - even if the slow, hard and expensive way). Figured this 5V failure was pretty crucial and explained simply without extra testing (symptom or problem? mmm thinking symptom) by someone in the know.
So if no help comes my way I think I'll buy some more PIC's and sus out how I can burn the bootloader on them (maybe someone like jaycar can do it for a fee) as I don't have a control clean PIC to test against. Otherwise I'll buy some more stuff from smash
thanks
martin
In a rush:
Don't know if not having Rw connected would screw up the PIC or other components.
No harm would be done there.
There are local dudes who can help with burning PICs ;) but seriously, just get a JDM  when you order them from smash. He's cheaper, even with shipping
