philetaylor Posted January 5, 2009 Posted January 5, 2009 Hi.I have been compiling many many midibox apps but something must have happened today (not sure what) as everytime I try to compile any apps (whether my own or ones from ucapps.de) I get the following: C:\Midibox\dmx_controller>make rm -rf _output/* rm -rf _output rm -rf *.cod *.map *.lst rm -rf *.hex mkdir -p _output sh c:\midibox\mios_base\bin/mios-gpasm -c -p p18f452 -I./src -I c:\midibox\mios_ base/include/asm -I c:\midibox\mios_base/include/share -I c:\midibox\mios_base/m odules/app_lcd/dummy -I c:\midibox\mios_base/modules/iic_dmx -DDEBUG_MODE=0 -DS TACK_HEAD=0x37f -DSTACK_IRQ_HEAD=0x33f -I c:\midibox\mios_base/modules/mios_wrap per c:\midibox\mios_base/modules/mios_wrapper/mios_wrapper.asm -o _output/mios_ wrapper.o sh c:\midibox\mios_base\bin/mios-gpasm -c -p p18f452 -I./src -I c:\midibox\mios_ base/include/asm -I c:\midibox\mios_base/include/share -I c:\midibox\mios_base/m odules/app_lcd/dummy -I c:\midibox\mios_base/modules/iic_dmx -DDEBUG_MODE=0 c: \midibox\mios_base/modules/app_lcd/dummy/app_lcd.asm -o _output/app_lcd.o sh c:\midibox\mios_base\bin/mios-sdcc -c -mpic16 -p18f452 --fommit-frame-pointer --optimize-goto --optimize-cmp --disable-warning 85 --obanksel=2 -I./src -I c: \midibox\mios_base/include/c -I c:\midibox\mios_base/include/share -I c:\midibox \mios_base/modules/iic_dmx -DDEBUG_MODE=0 src/main.c -o _output/main.o c:/midibox/mios_base/bin/mios-gpasm modifies _output/main.asm, result in _output /main__mios-gpasm-tmp.asm 0 [main] sed 3844 open_stackdumpfile: Dumping stack trace to sed.exe.stack dump Error [125] Illegal condition (EOF encountered before END) make: *** [_output/main.o] Error 1 Can anybody shed some light on what I might have done to cause this and more importantly, what I can do to fix it ??? I have lots of disk space and have tried rebooting....EDIT: sed is version 3.02, make is version 3.81, sdcc is version 2.8.0, gpasm 0.13.6 beta and gplink is version 0.13.6 alpha...CheersPhil
philetaylor Posted January 6, 2009 Author Posted January 6, 2009 It looks like the install of the Raisonance build environment for CORE32 maxed-out my path!!!I have deleted a few entries from path and all now looks OK.CheersPhil
stryd_one Posted January 6, 2009 Posted January 6, 2009 Ahh, you too huh. OK I've been getting those errors - Error 1 and error 5, for some time now. It rarely showed the 'EOF before end' message, but that was the one that helped me to track it down with a file monitor (sysinternals filemon, BTW). That EOF before END is when the OS *thinks* it has opened the file, but can't buffer up the end of it, so it's like it's only opened the first half of your file, to compile it.They appear at random, and often just typing 'make' again will do the trick. I noticed that it happened more often (sometimes just always) if I launched the cmd.exe instance from late proceses... as in, if I did file...run... cmd.exe, it would be more reliable, than if I opened the prompt from say, notepad++ . A lot of research showed me that windows was failing to open the file for writing - either a disk or ram issue. But of course, any time windows fails to open a file, and lacks a definite reason, it blames RAM or disk by default... Doesn't help much!I'd tried to lock it down but I knew it was a problem with my machine, and figured it would not effect any one else, so I didn't mention it. Sorry!Firstly I'd like to ask - how'd you figure out that it was the path being too long?I decided to check if mine might be over the limits... First I needed to know what the limits are. Here are the goods:The System path has a maximum length of 1023 bytes, not counting the Path= characters.The user defined path is the lesser of 511 bytes or (1023 - SystemPath).By default the maximum PATH environment variable in Windows is 1023. There is a hot fix from Microsoft that increases the maximum length to 2046.To view the hot fix article, please go to http://support.microsoft.com/kb/832978/en-us Microsoft has confirmed that this is a problem in the Microsoft products that are listed in the "Applies to" section. This problem was first corrected in Microsoft Windows XP Service Pack 2.(so, you don't need the hotfix if you're running SP2 or greater)http://support.microsoft.com/kb/830473The box for adding a new user variable is shown below. Generally' date=' this is likely to be a directory that you use frequently but can be any string of less than 8192 bytes. The maximum total size for all environment variables, including variable names and the "equals" sign, is 32767 characters.[/quote']Now... this is all legal in my case... for windows at least.... My env vars total is 2247 and path is 617.But I can't say the same for MinGW. I'm starting to wonder if MinGW supports the same maximums as windows does now.... Maybe it has a 512 char limit on the path....Let me know how you found this out, maybe I can pin it down and make a bug report...
philetaylor Posted January 6, 2009 Author Posted January 6, 2009 They appear at random, and often just typing 'make' again will do the trick. I noticed that it happened more often (sometimes just always) if I launched the cmd.exe instance from late proceses... as in, if I did file...run... cmd.exe, it would be more reliable, than if I opened the prompt from say, notepad++ . A lot of research showed me that windows was failing to open the file for writing - either a disk or ram issue. But of course, any time windows fails to open a file, and lacks a definite reason, it blames RAM or disk by default... Doesn't help much!At least i'm not alone :)I had exactly the same problem, it started over Christmas as random failures when compiling from within notepad++. As I was really 'in the zone' I couldn't be bothered to do any diagnosis at this point as compiling from within a Command Prompt worked fine. I assumed that something had gone screwy and a reboot would fix it (I was wrong!)I was then forced to do something as yesterday I couldn't even compile from within cmd.exe >:(I noticed that my path variable was pretty long (definately over 512 bytes) so I decided to 'prune' it as there were lots of things in there that I didn't need (old software etc). Once I had done this everything (including compiling from within Notepad++) worked.Let me know how you found this out, maybe I can pin it down and make a bug report...Unfortunately it was trial-and-error and luckilly for me it was the first thing I tried.I did try running the MinGW "sh" and looking at the environment and it appears to be the same as the windows one, nothing was truncated but as everything else seems to work OK, I would also suspect MinGW.CheersPhil
stryd_one Posted January 6, 2009 Posted January 6, 2009 Unfortunately it was trial-and-error and luckilly for me it was the first thing I tried.That's great! :DThanks for sharing the answer mate, I'll chase this up and keep you posted.
