cimo Posted February 15, 2009 Author Posted February 15, 2009 buh it seems like i am not really able to get this stuff working as it should, light is a bit dim and slow if i go over 35W lamps
cimo Posted February 15, 2009 Author Posted February 15, 2009 Ok we are kinda desperate and will offer 30 EURO for a working circuit if sent within 24 hours, it has to trigger around 70W of power from DOUT to a 2n3055.I am looking for help locally so consider that i may find an answer here before sending me any offer.Simone
cimo Posted February 16, 2009 Author Posted February 16, 2009 Good news, using a 2n2222 instead of bc547 is giving far better results
cimo Posted February 17, 2009 Author Posted February 17, 2009 ok here you go in case somebody will need it:
stryd_one Posted February 17, 2009 Posted February 17, 2009 Thanks for sharing it cimo, and I assume this means you are having some success - Yay!Can I do the dance now? :)
cimo Posted February 17, 2009 Author Posted February 17, 2009 Thanks for sharing it cimo, and I assume this means you are having some success - Yay!Can I do the dance now? :)not 100%, i wanted to have the load between GND and EMITTER but it seems like i need a pnp transistor or some other kind of circuit. With this schem you have to isolate every single transistor cause the body (TO3) is COLLECTOR. Other little detail is that i have to connect the chassis to + and not to GND.Simone
stryd_one Posted February 17, 2009 Posted February 17, 2009 voodoo.Luck at you dude. Wish I could actually, yaknow, help.......
