Gogmagog Posted February 4, 2009 Posted February 4, 2009 (Ebay item) http://tinyurl.com/aatafqI'm pretty sure the LCD would work fine since it uses an actual HD44780 controller. My question is, could I convince the MIDIBox core (PIC18F452) to use the four switch contacts as a DINX1? In other words, could I hook S1-4 up to J9 and expect good results? Anybody have any experience with this particular LCD module?Thanks,Michael
stryd_one Posted February 4, 2009 Posted February 4, 2009 Welcome aboard :)No need to use tracking sites like tinyurl here, the bbcode syntax allows you to hide the long URL if you want to:This: [url=http://www.somelongurl.com/long/long/long/long/long.htm]on ebay[/url] Looks like this:on ebayNo, that won't work, they're just switches. Depending on how they're wired (it's not clear in the listing, only one connection is given per switch, so maybe they just output 5V when held in?) you may be able to connect those switches to a DIN, or to J5.
Gogmagog Posted February 4, 2009 Author Posted February 4, 2009 Oops, didn't realize tinyurl tracks you. Didn't think to use bbcode either. :PAnyway, thanks for your input.
