protofuse Posted March 28, 2009 Posted March 28, 2009 hello,As I'll need around 100 buttons, 100 rgb leds, and 100 pots + 1 LCD, I began to design an architecture with 2 cores.after reading about multiple core hardware, some question remains.I understood that there are (at least) 2 kind of method to use multiple core when it is required:- via LTC module (here)- via midibox link (here)but...in my case, with 2 cores, I'm a little bit stuck.)) I'll use the LTC for midi in & out led purpose only)) I'll put 2 DINx4 + 2 AINx4 + 2 DOUTx4 on each core)) I'll use a character LCD handled by one corewhat is the more efficient link I can do between my two cores ?I'm able to read.. so if a link I didn't check is available, I just ... run to it :)thanks a lot for this site... and for the GREAT midibox framework!
stryd_one Posted March 28, 2009 Posted March 28, 2009 I understood that there are (at least) 2 kind of method to use multiple core when it is required:- via LTC module (here)- via midibox link (here)Nope, that's one way to connect the cores. The first pic just has an LTC added also.
