loziniak2 Posted April 29, 2009 Report Posted April 29, 2009 Hello. I've noticed a strange track buttons behaviour. When I click TRACK2 buttton just after a power-up, the track changes, but when I change back to TRACK1 and again TRACK2, buttons behavior changes and now I can only "checkbox" tracks, not change it, and I cannot "uncheck" track 1. The result is that I havee track1 checked all the time, and I can add any combination of other tracks in group.Suprisingly, only TRACK1 button behaves strange. The rest works just as described in manual (click to select, hold to select multiple), so when after a power-up I select any other track and NOT select track 1, everything is fine...Is it a kind of bug, or is it something wrong with my hardware? I had seq3.4a firmware earlier, with the same effect... Quote
stryd_one Posted April 29, 2009 Report Posted April 29, 2009 Sounds like a faulty switch or wiring to me... Have you tried swapping the switch out with a spare? Quote
loziniak2 Posted April 30, 2009 Author Report Posted April 30, 2009 It haven't sound like this to me, but it was wiring (short between two legs of switch). I was misled by the fact that first click after power-up was ok. Thanks very much. Sometimes simple things are most hard to understand ;-) Quote
stryd_one Posted May 1, 2009 Report Posted May 1, 2009 I was misled by the fact that first click after power-up was ok.Yeh, that occurred to me too! Strange machines.... :PGlad it's working! Quote
