mico Posted May 28, 2009 Report Posted May 28, 2009 Hey everyone,Is it possible to use the MB6582 CS with a regular MIDIBox SID kit?Would it be a simple task or a complex task?- mico Quote
Wilba Posted May 28, 2009 Report Posted May 28, 2009 Yes it's possible.If using module PCBs, you would need to use two DINx4 modules and one DOUTx4 module. These would connect to the bottom edge of the MB-6582 CS PCB, except for one DOUT module "port", which is inverted on the MB-6582 base PCB (the outputs go through BC547 transistors to sink the current of one "column" of the LED/switch matrix). However, it's possible to try connecting it without the transistors and inverting the outputs in software... if you're using fairly bright LEDs, it probably won't make a difference... if the LEDs are dim, you could then add the transistors on a small piece of board or even solder them to the DOUTx4 module.If you decide to do this, I can help you with the wiring, it's pretty simple. Quote
mico Posted June 3, 2009 Author Report Posted June 3, 2009 If you decide to do this, I can help you with the wiring, it's pretty simple.Thanks for the info and offer. I'll let you know when I get there. I'm still very early on in the project:I'm currently building my very first SID module. At this point I can still decide to order the mb6582 kit and go with that.Thanks- mico Quote
