jwrigh10 Posted June 5, 2009 Report Posted June 5, 2009 I have a Core with 4 DINS for a Midio128 project. These dins primarily run the pistons/buttons on the organ. However, one set of pistons is dupilicating the other set. For example, when I press the Pedal Pistons I get: TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT 00093034 3 -- 94 15 7F 5 A 0 Note On 00093101 3 -- 94 15 00 5 A 0 Note Off 000933C8 3 -- 94 14 7F 5 G# 0 Note On 000934A5 3 -- 94 14 00 5 G# 0 Note Off 00093604 3 -- 94 13 7F 5 G 0 Note On 000936C8 3 -- 94 13 00 5 G 0 Note Off 00093858 3 -- 94 12 7F 5 F# 0 Note On 000938F7 3 -- 94 12 00 5 F# 0 Note Off 00093AD0 3 -- 94 11 7F 5 F 0 Note On 00093B6F 3 -- 94 11 00 5 F 0 Note Off 00094295 3 -- 94 10 7F 5 E 0 Note On 00094333 3 -- 94 10 00 5 E 0 Note Off These are connected into DIN #1.When I press another set of buttons, which are plugged into DIN #4 I get several duplicates. Here is what I get: TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT 000BBBEB 3 -- 94 14 7F 5 G# 0 Note On 000BBC39 3 -- 94 14 00 5 G# 0 Note Off 000BC6C6 3 -- 94 13 7F 5 G 0 Note On 000BC800 3 -- 94 13 00 5 G 0 Note Off 000BCB29 3 -- 94 12 7F 5 F# 0 Note On 000BCBE9 3 -- 94 12 00 5 F# 0 Note Off 000BCBFD 3 -- 94 12 7F 5 F# 0 Note On 000BCC12 3 -- 94 12 00 5 F# 0 Note Off 000BCF03 3 -- 94 11 7F 5 F 0 Note On 000BCF7B 3 -- 94 11 00 5 F 0 Note Off 000BD221 3 -- 94 10 7F 5 E 0 Note On 000BD238 3 -- 94 10 00 5 E 0 Note Off 000BD24C 3 -- 94 10 7F 5 E 0 Note On 000BD2A3 3 -- 94 10 00 5 E 0 Note Off 000BD5E3 3 -- 94 6F 7F 5 Eb 8 Note On 000BD601 3 -- 94 6F 00 5 Eb 8 Note Off 000BD615 3 -- 94 6F 7F 5 Eb 8 Note On 000BD698 3 -- 94 6F 00 5 Eb 8 Note Off 000BD6AD 3 -- 94 6F 7F 5 Eb 8 Note On 000BD6C1 3 -- 94 6F 00 5 Eb 8 Note Off 000BDCAF 3 -- 94 15 7F 5 A 0 Note On 000BDCEE 3 -- 94 15 00 5 A 0 Note Off 000BDD03 3 -- 94 15 7F 5 A 0 Note On 000BDD17 3 -- 94 15 00 5 A Note Off 000BDFE2 3 -- 94 16 7F 5 Bb 0 Note On 000BE05B 3 -- 94 16 00 5 Bb 0 Note Off I have reloaded the sysex file and checked the .ini file, but cannot figure out why I am getting these duplicats. Could this be a short int he board? Any thoughts?Thanks
stryd_one Posted June 6, 2009 Report Posted June 6, 2009 Does it do this with the default configuration, or only with your ini file?
