tittualex Posted September 28, 2009 Posted September 28, 2009 Dear all,Iam new to this forum , and hence i dont know wether this is the right place to post this messege .I have got three keyboards with MIDI and I want to connect all the three to my 1X1 USB MIDI interface so that I can play a virtual pipe organ. for that I need to make a MIDI merge with 5 in and one out( I need to MIDIfy my pedalboard also.) Can any one please tell me how to make a MIDI merger (5X1) and MIDI board for Pedalboard and stop switches......thanks in advance.Alex.
clem! Posted September 28, 2009 Posted September 28, 2009 Hi alex,perhaps this little toy will fullfill your desires:http://www.ucapps.de/midi_router.htmlas an entrance read also this:http://ucapps.de/midimerger.htmlread - learn - buildBest regards,clem!
avogra Posted September 28, 2009 Posted September 28, 2009 if it is ok, to have 5 distinct midi-ports instead of merging them into one, you could also replace your 1x1 interface by this:http://www.ucapps.de/mbhp_usb_gm5.htmlsome interesting links:http://www.midibox.org/dokuwiki/doku.php?id=tk_gm5_bulkorderhttp://www.midibox.org/dokuwiki/gm5x5x5_pcb_bulk_orderhttp://www.midibox.org/forum/index.php/topic,13891.msg119474.html#msg119474that will only work for you, if your virtual organ can handle different midi-ports, of course.for a pedalboard and stop switches, i guess a midibox64 or midibox64e should be fine.cheers, Alex//edit: typos & replaced german words :)
jimhenry Posted September 29, 2009 Posted September 29, 2009 While you can build a MIDI Merge using the MidiBox, it is more cost effective to buy a MIDI to USB interface with the required number of inputs if all you need is the merge. BTW, 3 keyboards plus pedal is 4 MIDI In. If you can get by with 4 Inputs rather than 5, you will save quite a bit of money. If you need 5, then you probably should buy 4 and use your existing 1x1 USB for the 5th input.
tittualex Posted October 2, 2009 Author Posted October 2, 2009 Dear All ,Thank you for your replies . Alex.
