Guest ShagWill Posted July 30, 2003 Report Posted July 30, 2003 Hi !I'm rather new to this board and I'll begin my own surface control.I did a lot of VB programming in the past... but I really don't know where to start in this project talking about programming...I want to build a 16 motorfader surface with 16 x 4 knobs/ledrings, a MTC display, a couple of bank shift buttons, a joggle and the play, stop, etc.. buttons. For this I think I'll need 2 CORE.I also think about adding 16 leds vu-meters (build like the ledrings) maybe on a seperate CORE/MIDI port to avoid too much MIDI messages.Could anyone give me some clues ? I'll order all the boards from Tim (SmatchTV).William
Sephult Posted August 6, 2003 Report Posted August 6, 2003 Hello!I believe you are headed on the right track :)2 cores (8 Mfaders each core)1 AIN (64 analog knobs)1 DIN (All button needs)(Encoder jog wheel)1 DOUT (LEDs and rings)You could also make it 2 on all and seperate the load on the cores.I am unsure yet of MTC on the MIOS, I have yet to build one myself.Have fun!_Sephult
