petonx Posted January 22, 2010 Posted January 22, 2010 Can I use hd44780 based LCD?(I haven't any other) Where connects CS pins?(are they important?) If I need a special driver?
philetaylor Posted January 22, 2010 Posted January 22, 2010 The HD44780 is about as standard as you can get. It is fully supported by MIOS8 and MIOS32 (in fact it is the default driver - clcd) Have you looked at ucapps.de? This page will help: http://www.ucapps.de/mbhp_lcd.html You should be able to find wiring information in the above link as well. Cheers Phil
