hi
i want to make the midibox sid so bad i love the emulations of the sid chip i've heard and used in songs as software plugins and i want a hardwarte trophy!!!
but, i cant seem to understand the article on it and i want to use four chips and things like that. should i wait till the version is updated and when it does is there an order i'm supposed to read? cause i've read page amoung page and i really dont understand where i''m supposed to learn how to make it.
all i get is just general information about it.
and other than that the tools i will need..
can you tell me? like how powerful should my soldering iron be(the watts?) and what other tools will i need??
i'd really apreciate your  help. ;D
Pretty much all of the info you need is already there, you should study the different modules of the mbhp, once you understand what each module does you'll understand the basics of the sid.  If you want a 4 chip sid, you'll need 4 cores, 4 sid modules, and if you want to control it, you'll need som dinx4 modules or ainx modules depending on what sort of control you want over it,
as for the soldering iron, between 15 and 30 watts is the way to go, nothing more than that...
