hello,
I need your help.
i'm using KICAD 20100314 SVN R2460 version but I'm sure it doesn't matter with my
words here..
I have some problem with power components: some give me errors type 3
I tried to remove them, put another one, remade the connection to be sure... but
I still have some inconsistencies :-(
I tried to use another lib for that too.. for instance, Vcc & GND from sparkfun
library, or from the native one etc.
I have errors when I run ERC ...
I remove, I replace, I rerun ERC, it gives me the same error but at another place, not appearing at the first ERC etc etc
Should I remove all of them and use wire labelling instead of power objects ?
any ideas or tips would be appreciated!!
I've got no idea man, i've only used Kicad a little bit but i found fairly buggy
hello,
as I don't like cracked thing, if I used Eagle, I could only do very little board.
so kicad is a very fine alternative, not as buggy as you wrote :P
gEDA seems to be a nice alternative too...
I'm installing virtualbox for making a virtual machine linux in order to test it here.
i don't know if geda/kicad conversion are fully integrated
