Rave Posted April 15, 2010 Report Posted April 15, 2010 Hi all, Thanks for reading. I have a problem of my own making, I have bought the sammich kit and in my eagerness to build it I had not noticed the temperature control on my iron was way to high and I have lifted a trace off the pcb. Is there any way I can get a new pcb? Thanks, Rave. :)
seppoman Posted April 15, 2010 Report Posted April 15, 2010 well as long as it's only one single trace that is damaged, you can always fix it with a piece of isolated wire. Just solder one end of the wire to the pin/pad where the damage occured, follow the trace to the next place where it goes into another pad, and solder the other end of the wire there. Another way of fixing ripped off pads is to scratch off the (red) solder mask laquer from the trace end for maybe 5-10 mm, apply solder to the copper of the trace, bend a short piece of wire or a leftover resistor leg that crosses the gap, and solder this piece between the pad and the trace. Buying a new PCB and starting all over is a bit of an overkill as long as you didn't kill half of the traces :) good luck, S
Rave Posted April 15, 2010 Author Report Posted April 15, 2010 Hi, True, i could bypass the holes and solder to linking components, but its a bit frustrating that way, and i would know its not perfect! I would like a new board preferably, but if its too costly or impracticle then i will just have to bite the bullet! :)
