Hey all,
So i ordered some resistors that i need for my MB-SEQ CS PCB (for the LED's), and I made a bit of a gaffe... I ordered 5% resistors instead of 1%, and I'm not sure if they will work. I ordered quite a few so that I could use them with my MB-808 also. Can someone let me know if they are okay? Not sure how I ordered the wrong ones, as I got the Mouser #'s from an old order of mine that was definitely the correct resistors...
FYI: These are the really small resistors, which is what first caught my attention...
I meant to order:
1k OHM http://www.mouser.com/search/ProductDetail.aspx?R=MF1%2F4DC1001Fvirtualkey66000000virtualkey660-MF1%2F4DC1001F
220 OHM http://www.mouser.com/search/ProductDetail.aspx?R=MF1%2F4DC2210Fvirtualkey66000000virtualkey660-MF1%2F4DC2210F
470 OHM http://www.mouser.com/search/ProductDetail.aspx?R=MF1%2F4DC4700Fvirtualkey66000000virtualkey660-MF1%2F4DC4700F
I ordered:
1k OHM http://www.mouser.com/Search/ProductDetail.aspx?R=CFS1/4C102Jvirtualkey66000000virtualkey660-CFS1/4C102J
220 OHM http://www.mouser.com/Search/ProductDetail.aspx?R=CFS1/4CT52R221Jvirtualkey66000000virtualkey660-CFS1/4CT52R221J
470 OHM http://www.mouser.com/Search/ProductDetail.aspx?R=CFS1/4CT52R471Jvirtualkey66000000virtualkey660-CFS1/4CT52R471J
Thanks!!!
grizz
For LEDs, this should be no issue. I don't think that you'll see a difference in LED brightness.
Cool, thanks.
I ordered 100 1k, and 50 each of the 220 and 470, so I wanted to make sure before using any in case it made sense to return them.
