JRock Posted May 2, 2010 Posted May 2, 2010 I had a little trouble locating the W04 bridge rectifier. I ended up ordering the one listed on SmashTV partslist (I think) for the SID module board. I ordered a W08 800v. Will that work? I had trouble finding the right one @Mouser cuz I don't understand exactly what qualities I'm looking for in a bridge rectifier. I mostly understand what they do but everything I've worked on so far has been DC. I'm still very much a beginner so If I screwed up please let me know and help me to understand what exactly to be looking for. Will the BR in the commodore work? Thanks
Wilba Posted May 3, 2010 Posted May 3, 2010 I think most bridge rectifiers have voltage/current ratings far higher than what you'll ever use for a MIDIbox. You should be OK using anything you can salvage from a C64, as it handles 9V AC 1A input. Just pay close attention to the pinout, as incorrect wiring might result in a diode "shorting" your input power.
JRock Posted May 3, 2010 Author Posted May 3, 2010 Thanks!!http://midibox.org/forums/public/style_emoticons/default/thumbsup.png
