"forever" because of errors or just slow to upload?
Post screenshot after the upload, it should show the speed at the end.
It couldn't possibly be slower than my M-Audio Delta 1010LT.
Posted (edited)
just wrapped up, says there was 1 ignorable error solved.
hour & 24 min is forever to someone impatient like me. :)
Edited by space6oy
OK something is wrong. It only takes 82 seconds for me.
For the upload to work, both the PC and the PIC must be running their serial comms at the same speed, so it's not an issue with that... i.e. each BYTE is being sent and received OK, but there must be massive delays between bytes. The problem would therefore have to be at the PC end, since there's nothing at the PIC end that could slow down an upload.
What kind if MIDI interface are you using? Perhaps there's a conflict with other USB devices or it expects to be in a USB 2.0 port or some other issue.
that's a possibility... i'm at work on a PC w/ a USB midi cable. should head home & try it w/ my TM-1 (if the software will recognize a firewire connection instead?)
MIOS Studio only uses MIDI ports.
TM-1 should work, but not in any turbo mode, only standard MIDI baud rate.
Let's assume that since you did upload successfully, the sammichSID MIDI Out should be working and unlikely to have suddenly stopped. Therefore it's probably a setup issue. You should be able to do a loopback (PC MIDI In connected to PC MIDI Out), play some notes on the keyboard and see events in the MIDI In window.
  • 3 weeks later...
