reboot Posted August 10, 2010 Report Share Posted August 10, 2010 (edited) hello i made some 6582 panels for me and friends so there's some spares 50e +shipping with 1,5mm aluminium laser cut , front and back thank you Edited August 20, 2010 by reboot Quote Link to comment Share on other sites More sharing options...
julienvoirin Posted August 10, 2010 Report Share Posted August 10, 2010 mets m'en un de coté selim j'vais recevoir une CS PCB d'ici qlq jours des news de mon panneau de M1000 controller ? ++ Quote Link to comment Share on other sites More sharing options...
Spazi Posted October 19, 2010 Report Share Posted October 19, 2010 Hey mate, You still selling one of these? Quote Link to comment Share on other sites More sharing options...
gtxdude Posted October 20, 2010 Report Share Posted October 20, 2010 if you are, i'll take one! Quote Link to comment Share on other sites More sharing options...
Rave-TZ Posted October 20, 2010 Report Share Posted October 20, 2010 Me too. Any more? Quote Link to comment Share on other sites More sharing options...
reboot Posted October 24, 2010 Author Report Share Posted October 24, 2010 (edited) hello if at least 10 persons need this panel i can order some more ... let me know . i'll post new pics soon reboot Edited October 24, 2010 by reboot Quote Link to comment Share on other sites More sharing options...
Kickflip Posted October 25, 2010 Report Share Posted October 25, 2010 May be interested in a set here too, wondering though, the LED holes don't appear to be drilled on the photographs in the first post? Quote Link to comment Share on other sites More sharing options...
ilmenator Posted October 25, 2010 Report Share Posted October 25, 2010 May be interested in a set here too, wondering though, the LED holes don't appear to be drilled on the photographs in the first post? The whole thing looks like being covered with a Lexan overlay? Where did you order that? Quote Link to comment Share on other sites More sharing options...
mrcam Posted October 26, 2010 Report Share Posted October 26, 2010 Hello, Intéressé aussi par 1 panel pour une MB6582. Merci ! Quote Link to comment Share on other sites More sharing options...
iZZE Posted October 27, 2010 Report Share Posted October 27, 2010 Hello.. I am from Austria/Europe..i am also interested.. I would only need the Frontpanel. Are the led holes cut out ? Thanks Patrick Quote Link to comment Share on other sites More sharing options...
ganchan Posted November 1, 2010 Report Share Posted November 1, 2010 probably interested in one, can you give use some more specs? Quote Link to comment Share on other sites More sharing options...
reboot Posted November 3, 2010 Author Report Share Posted November 3, 2010 (edited) hello sorry for the delay .... the lexan panels i had have a problem as i didn't checked my illustrator file . i will organise a batch next week . price will be around 80 euros max . the lexan will have a window included like this .. http://picasaweb.google.com/catchreboot/MBSID#5359182162824829698 not here http://picasaweb.google.com/catchreboot/SidPanels#5509422095551359858 i can fix the lexan on the panel for you and spacers if you need . ilmenator, you're right , the leds are not drilled , it's like opaque film . same technique : http://audio.chernis-grant.com/pictures/ebay/minimoog/DSC01863.jpg Ize , i an do a panel in 2mm alu anodized or 1,5mm metal or 1,5 inox a bit like mirror but it can have imperfections . your impressions are welcome thank you Edited November 3, 2010 by reboot Quote Link to comment Share on other sites More sharing options...
ganchan Posted November 6, 2010 Report Share Posted November 6, 2010 well, seems good but, the next batch will have that imperfection on the lexan? about the imperfection, do you mean the one in the photo where the lcd button's holes in the lexan are not in place with the metal panel's holes? i've noticed in the first post, left photo, the bottom left screw seems like had flex the panel like it is made of plastic or thin metal, can you explain? :) thankyou. G. Quote Link to comment Share on other sites More sharing options...
reboot Posted November 6, 2010 Author Report Share Posted November 6, 2010 hello ganchan, the next batch will not have the imperfection on the lexan , it concern just the laser cut . the flex you see is because i screw a bit too much , the lexan is like a thick sticker , i can cut the holes in 4mm or more . on the metal panel , the leds and buttons holes will be 4mm instead of 3 and 3,5mm , and window 1mm bigger. in this case it's impossible to see the panel after lexan fixed . pics very soon . Quote Link to comment Share on other sites More sharing options...
reboot Posted November 6, 2010 Author Report Share Posted November 6, 2010 the back panel can be changed also so ideas are welcome. thanks Quote Link to comment Share on other sites More sharing options...
ganchan Posted November 6, 2010 Report Share Posted November 6, 2010 i like to see the panel with a led lighting in the back if it possible. if you had screw too much and flexed the lexan i can assume that this is 2mm or more.. i've never see a sticker on meta flexed with a screw, is too thin :) Quote Link to comment Share on other sites More sharing options...
iZZE Posted November 6, 2010 Report Share Posted November 6, 2010 I already have a Aluminium Panel.. as i dont know exactly what lexan is, will i be able to fit it over my panel ? i have a red eloxated one, but i would like black, so can i just put a black lexan overlay on it ? How much would it cost. Thanks Patrick Quote Link to comment Share on other sites More sharing options...
reboot Posted November 9, 2010 Author Report Share Posted November 9, 2010 Patrick ,just the lexan ..40e it's very easy to fix it with water and soap . the lexan is 0,5mm (i suppose) thanks Quote Link to comment Share on other sites More sharing options...
iZZE Posted November 9, 2010 Report Share Posted November 9, 2010 Any pictures of the lexan in action ? Thanks Patrick Quote Link to comment Share on other sites More sharing options...
reboot Posted November 10, 2010 Author Report Share Posted November 10, 2010 i wait a screen from eio for 1,5 month...after i 'll receive and finish the sid , i'll send you pictures . Quote Link to comment Share on other sites More sharing options...
tb303orys Posted November 23, 2010 Report Share Posted November 23, 2010 i want a set too! Quote Link to comment Share on other sites More sharing options...
