ilmenator Posted January 14, 2011 Report Posted January 14, 2011 Hi, I have this typedef struct prog_list_tag { u16 index; u16 bank_number; char file_name[4]; char bank_name[16]; } prog_bank_list_t; // each entry represents one available PROG bank on SD card prog_bank_list_t prog_bank_list[100]; and this: extern char current_prog_bank_name[16]; How can I copy the bank_name in the struct (e.g. the one in the second entry of prog_bank_list) into the array current_prog_bank_name? I think I got a mental block right now...
TK. Posted January 14, 2011 Report Posted January 14, 2011 #include <string.h> ... int bank = 0; memcpy((char *)current_prog_bank_name, (char *)prog_bank_list[bank].bank_name, 16); [/code] Best Regards, Thorsten.
ilmenator Posted January 14, 2011 Author Report Posted January 14, 2011 I definitely had a mental block! Thanks!!
Phatline Posted January 2, 2015 Report Posted January 2, 2015 I also want to "memcpy" C, 8Bit Core, 18F4685: #include <string.h> int MtxLoad0[8]; //Destination Array int Mtx0Part0[8]; //Source Array if(pin == 0 && pin_value == 0){memcpy(MtxLoad0, Mtx0Part0, 8);} give me this error: error: missing definition for symbol "_memcpy", required by "_output/main.o" where do i have to define "memcpy"?
TK. Posted January 2, 2015 Report Posted January 2, 2015 memcpy() isn't available, copy it with a for loop... Best Regards, Thorsten.
Phatline Posted January 2, 2015 Report Posted January 2, 2015 ok thankz i made this: #include <string.h> int MtxLoad0[8]; //Destination Array int Mtx0Part0[8]; //Source Array int LoroCount; //counter 4 "for" loop -LoadRoll... if(pin == 0 && pin_value == 0) {for(LoRoCount=0; LoRoCount<8; LoRoCount++) {MtxLoad0[LoRoCount]=Mtx0Part0[LoRoCount];}}
