avockley Posted February 8, 2011 Posted February 8, 2011 (edited) I have a 16x16 matrix that I need to control. I am using this to add a midi output to an old organ. It has one magnetic reed switch at each point. I believe the inputs work with 2 DOUTs and 2 DINs. For the sake of this post, I will assume the DOUTs are on the side and the DINs are on the bottom. In return for a button press in the matrix, you get a pin number and a value. Is the pin number counted left-to-right and then top-to-bottom in the matrix. Also, does the value return 1 for pushed and 0 for released or 0 for pushed and 1 for released? Finally, how do I specify what part of the matrix is connected to what DOUT or DIN Is any of this even close to correct, or am I way off base? Edited February 8, 2011 by avockley
findbuddha Posted February 8, 2011 Posted February 8, 2011 Have you read the schematics and the code: http://svnmios.midib...2Fblm_scalar%2F ? Also some more info here: :)
