igi Posted March 16, 2011 Report Posted March 16, 2011 Hi! I almost finished my MB SID V2 with four SID's, four SWINSID's, coplete CS an two LC Aout. So for so good, and my new beast working almost perfect. But there is is a few problems. - Led for LFO positive is not working (I turn it like SID L,SID R and meter mode witch is working) - I use a non detent encoders (bourns PEC 11) and they work a little strange. It's very hard to adjust precise data (E.G.for transpose), and sometimes value jump E.G.from 10 to 36 even if I turn encoder very slowly,or value is decrease for a moment even I turn un the right. For the menu I used same, but detent encoder (mode 3) and works perfectly. - C64 power supply is gets pretty hot. Is this normal? Thanks everybody for support!
Imp Posted March 16, 2011 Report Posted March 16, 2011 Hi, how did you get -12V for the Aout_LCs out of the C64-PSU? Either your encoders are quite bouncy, or there is something wrong on your DINs. I'd check the dins for soldering errors first. Have you tried changing the encodermode?
igi Posted March 16, 2011 Author Report Posted March 16, 2011 Hi! I was modify Aout_LC to operate with single power supply and relace TL072 with LM358. I need only 0 to 5V for controlling external CEM filters. My DIN's it's OK (I check), because detent encoder is woking fine and all other buttons works OK.I try all encoder modes, but other than non_detend is working even worse than only one non_detent mode. Best regards!
julienvoirin Posted March 17, 2011 Report Posted March 17, 2011 there is an application in the SVN to test the different modes of encoders
igi Posted March 18, 2011 Author Report Posted March 18, 2011 Hi! Tkanks, but I'm totally lost in SVN. What about LFO positive led? Tkank you for yours support!
Imp Posted March 18, 2011 Report Posted March 18, 2011 (edited) Are you sure, the LED works? You can use a battery with a resistor in series to test it in the circuit, but if you can, you should disconnect it from the Dout first. Did you add DOUT_ENTRY TMP5, 5, x, y ; LFO Positive LED below "CS_MENU_DOUT_TABLE" in setup*.asm? ( with x=number of shiftregister and y=pin, e.g. 6,3) Edited March 18, 2011 by Imp
igi Posted March 18, 2011 Author Report Posted March 18, 2011 HI! The LED is works! I try change "LFO positive" with "matrix mode" in the Dout and led for LFO+ was working (but not matrix mode LED). And yes, I add DOUT_ENTRY TMP5, 5, x, y ; LFO Positive LED in asm setup just like I did for SID L,R (with diferent x and y of course)LEDs witch is working fine. What else can be wrong? Thank you for your support!!!
Imp Posted March 18, 2011 Report Posted March 18, 2011 When do you expect it to turn on? Maybe you got that wrong? ;) In the LFO menu you have to set the Waveform to PSn,PTr,PSw or PPl... If this isn't the problem, i don't know what else to check. Maybe someone with a working LFO+LED can chime in?
igi Posted March 18, 2011 Author Report Posted March 18, 2011 HI! I expect: when LFO goes in positive value (any waveform) then LED should turn on. Or am I wrong? I try all waveforms, PSn,PTr.. too, but nothing happend. Thanks!
Imp Posted March 18, 2011 Report Posted March 18, 2011 No, it just turns on, when you select one of those positive waves...or at least it should ;) Without it, you can still see if you selected a positive wave, because then two of the LFO-Waveform-LEDs will be lit. Have you checked, if the used SR/pin isn't already in use by another function?
igi Posted March 19, 2011 Author Report Posted March 19, 2011 Hi! SR is not already in use. When I set waveform to PSn,PTr,PSw or PPl, then RND led with selected Waveform is lit. Here is my configuration: DOUT_ENTRY TMP5, 0, 5, 6 ; LFO Sine LED DOUT_ENTRY TMP5, 1, 5, 7 ; LFO Triangle LED DOUT_ENTRY TMP5, 2, 6, 0 ; LFO Saw LED DOUT_ENTRY TMP5, 3, 6, 1 ; LFO Pulse LED DOUT_ENTRY TMP5, 4, 6, 2 ; LFO Random LED DOUT_ENTRY TMP5, 5, 6, 3 ; LFO Positive DOUT_ENTRY TMP4, 7, 6, 4 ; sid R DOUT_ENTRY TMP4, 6, 6, 5 ; sid L DOUT_ENTRY TMP2, 2, 6, 6 ; meter DOUT_ENTRY TMP2, 3, 6, 7 ; matrix Best regards!
