Hello,
I build two MB-6582, working perfectly.
I have used psu option B and build my own psu with 5VDC und 9V AC (Tranformer 2x9V und 7805 with 3A max. )
Under full charge the 5V DC drops down to under 3V. I have tested this with 3 different power supply units (regulated power supplys)
For both MB-6582 I need a no-load voltage of 8V.
I am pretty sure there are no short-cuts etc. I did some current measurement and there are no uncommon currents.
Any suggestions? Maybe because of the 2200uF Elko directly after the power-switch. Is this Elko really required?
best regards
Posted (edited)
I have one MB-6582 with 4x8580 and 4x6582 so I need only 9V.
Second one has 4x6581 and 4x8580.
Today I changed the psu option B of the "9V" MB to A because the 7812 generated some heat for nothing.
But I got no change in voltage drop.
Currents are (5V rail): 1. No CS (no lcd), without 9V-Jumpers for SIDs, Fan pluged on 9V AC Line: 0,8A
2. 9V-Jumpers pluged in, no CS: 1A
3. with CS : 1,1A
Voltage drop increases with rising current. I need 7VDC so get a working MB with 5VDC in it.
For this measurements I use no DIY psus etc.
I did this with 3 no diy psus.
The same behaviour at both MB.
Edited by modulator
