ArnoNym Posted September 21, 2011 Posted September 21, 2011 For those who are searching for a cheap SD-card socket, maybe this is a solution: I've tested an Delock USB SD-card reader at reichelt.de (DELOCK 91667, 3,45EUR) and dismantled it, to unveil the secrets. There are some test-pads on the small PCB, where you can solder easily your ribbon-cable and fix it with hot-glue. See test-pad signal description in the attachment (the common SD card slot is on the backside, here only the slot for microSD can be seen): Of course you should not plug it into an USB slot, when connected to the MIDIbox core. You can for example desolder the USB connector at all... + cheaper then raw SD-slot + SD card can be changed + normal SD card as well as miniSD, microSD can be used - fiddly thing until all cables are connected - not so easy to fix into complete MIDIbox assembly (e.g. can not be screwed to housing, since PCB to small)
