... core is working properly, send correct midi data but LCD doesn't diplay anything... when i set contrast to maximum, i see ONE line of black rectangles, not two..
have this 2 out of 3 times when programming a pic for the first time. Just write the firmware again until the LCD is working... If you are using the in-circuit programming connector, try to diconnect all other leads while programming.
Axel
