ganchan Posted July 4, 2012 Report Posted July 4, 2012 (edited) any one have try to fit in the aluminum desktop case? :) G. Edited July 4, 2012 by ganchan
orange_hand Posted July 11, 2012 Report Posted July 11, 2012 Hi, are you talking about the Heidenreich case ? Or which case are you referring to ? As far as the Heidenreich case is concerned the LPC17 does not fit, this was stated in another thread ... cheers orange
flip Posted July 11, 2012 Report Posted July 11, 2012 (edited) Quoting TK on this: Meanwhile I think that it should also be considered to slightly increase the case size for the new MBHP_CORE_LPC17 module, especially if you want to plan with future buyers. The LCD connectors of this module are touching Wilba's Frontpanel, because the board is larger than MBHP_CORE_STM32. With the current case this can be fixed by removing the top of the IDC connectors, and by squeezing the cables (alternatively don't use sockets but solder the LCD cables directly), but this isn't a perfect solution for such an expensive case, and would only be acceptable for a small number of real DIY people. Edited July 11, 2012 by flip
ganchan Posted July 13, 2012 Author Report Posted July 13, 2012 many thanks to both of you. i had read that post but many time ago and i didn't find it again. G.
