Marxon Posted November 18, 2012 Report Share Posted November 18, 2012 Hi MidiBoxers, I am a little bit confused about the different ways to make button/led matrices. Which layout should i use to create a 128 button and 128 led matrix for the Midibox-NG? What dis/advantages do they have and why? Layout 1) SeqV4 wiring (64 buttons, 2x64 leds) + 2x DINX4 (64 buttons) Layout 2) Midibox 128V3 wiring (128 buttons) + ? Layout 3) BLM Scalar wiring with only 2 modules (128 buttons + 2x128 leds) Thanks for your advice! Best regards Marxon Quote Link to comment Share on other sites More sharing options...
TK. Posted November 18, 2012 Report Share Posted November 18, 2012 Hi, BLMs are very firmware specific, with BLM_SCALAR I'm trying to standardize this for controllers. Layout 1) SeqV4 wiring (64 buttons, 2x64 leds) + 2x DINX4 (64 buttons) A dedicated layout for MBSEQ V4 which I wouldn't recommend for controllers since it requires a special firmware handling. Layout 2) Midibox 128V3 wiring (128 buttons) + ? Only difference between this and Layout 1) and 3) is, that there are no LEDs! Layout 3) BLM Scalar wiring with only 2 modules (128 buttons + 2x128 leds) Recommended layout since it will be supported by MBNG Advantage: scalability is much better (therefore it's called BLM_SCALAR), also a PCB layout is more simple. Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Marxon Posted November 19, 2012 Author Report Share Posted November 19, 2012 Hi TK, thanks for your reply! Now i can make further considerations. Best regards Marxon Quote Link to comment Share on other sites More sharing options...
rvlt Posted November 19, 2012 Report Share Posted November 19, 2012 A dedicated layout for MBSEQ V4 which I wouldn't recommend for controllers since it requires a special firmware handling. Hi TK, just to be sure: Are you talking about this matrix? http://www.ucapps.de/mbhp/button_duoled_matrix.pdf Cheers Lars Quote Link to comment Share on other sites More sharing options...
ilmenator Posted November 19, 2012 Report Share Posted November 19, 2012 I'm not TK, but yes this is the BLM that is supported in the MB-SEQ, and that is not recommended for MB-NG based MIDI controllers. Just in case anyone needs a BLM for their MB-SEQ, have a look it looks as if I had one set consisting of PCB and buttons with caps left. Quote Link to comment Share on other sites More sharing options...
rvlt Posted November 19, 2012 Report Share Posted November 19, 2012 Thanks for making this clear, ilmenator. And yes, there is now definitely a PCB (and buttons) for sale from ilmenator. :whistle: Cheers Lars Quote Link to comment Share on other sites More sharing options...
