orbitalgun Posted January 9, 2013 Posted January 9, 2013 Settings for number of active ports is on the board, does the white dot represent jumpered? What is J8 for? Does the main led need to be populated to make the device work?
Digineural Posted January 10, 2013 Posted January 10, 2013 Its all here in the wiki. J8 is "Configuration Jumper. Closed (default): midibox.org configuration, open: ploytec.com configuration" No, you do not need the leds and if you dont want to use them you can leave a bunch of other parts out... also in the wiki. 1
orbitalgun Posted January 10, 2013 Author Posted January 10, 2013 It seems like so long ago that I read this, I forgot it. GM5x5x5 is now working all ports in and outs! Thanks for the response DIgi!
