I've had my SEQV4 up and running for some months now, and I realise my usage of it is now being limited through an incomplete understanding:
A pattern consists of 4 parallel tracks (1,2,3,4).
Each track has it's own properties including port, channel, length, direction, resolution, etc.
The pattern is known by a designator A1..A8, through to H1..H8 ( 64 patterns)
There are 4 track Groups.
Each group has it's own set of patterns (A1..H8)
This gives rise to 4*64 patterns stored in (the 4 bank files of) a session?
I'll pause here, please pull me up if I've stated anything wrong...
Hi Duggle,
your statements are not completely correct. :smile:
From the manual:
"...a session stores 256 patterns, 128 mixer maps, 64 songs!..."
and
"A single session contains:
MBSEQ_B1.V4 .. MBSEQ_B4.V4: four banks. Each bank stores 64 patterns and is usually assigned to the appr. track group G1..G4, but can also be shared between the groups"
-Patterns can be shared between tracks
-they are enumerated from A1-H8 and a1-h8
Marxon
EDIT:
Stop... Now I am also confused:
A1-h8 = 2*64 = 128 Patterns
So are there 128 or 256 Patterns available?
Edited by Marxon
Hi Marxon,
thanks for your input.
I thought I had a viable explanation for how the 256 patterns were organised: 4*64=256
On the Grp. Save Pattern page the "to Target" can have values 1:A1 to 1:H8 to 2:A1 to 2:H8 etc, to 4:H8
That would be the 256 patterns?
Now in the "Pattern Screen" part of the manual it says there is lowercase designators a..h providing another 64 patterns, though I can't activate them by pressing the left GP buttons twice. It also talks about accessing Bankstick which seems a bit old.
Still not clear....
I think you can copy (the pattern contents) material from one track group to another?
Hi again,
Hi Marxon,
-Confirmed
-me to, lowercase letters are not available.
I did not tested this before :(
Still not clear....
EDIT
-OK i did not express myself very well. Not single tracks can be shared but "set of tracks" for example
from Group 4, Track 13-16
into Group 1, Track 1-4
This can be done with encoder 3, 7, 11, 15.
So "categories" = "banks"... little bit confusing
Edited by Marxon
