*Solved* MB64e: Assign Leds to selected group trouble
Hello,
I feel almost sorry to bother you with basics, but i can´t figure out how to assign 8 LEDs to display the selected Bank (for a controller with no lcd).
In the ini file i changed the dout mapping like this:
LED_SR1 = 10
Unfortunately there seems to be something missing, it´s not working...
Connections are checked, LEDs are working.
Would be nice if someone has a hint for me.
Here is the section from the ini:
# LED Map: assignes the LED shift registers to the Button Shift
# registers or special values
# Currently following values are supported:
#    0     Default Setting (see Map below)
#    1     Button Shift Register 1 (Button ID #1-#8)
#    2     Button Shift Register 2 (Button ID #9-#16)
#    3     Button Shift Register 3 (F1-F4 and Navigation Buttons: ID #17-#24)
#    4     Button Shift Register 4 (Button ID #25-#32)
#    5     Button Shift Register 5 (Button ID #33-#40)
#    6     Button Shift Register 6 (Button ID #41-#48)
#    7     Button Shift Register 7 (Button ID #49-#56)
#    8     Button Shift Register 8 (Button ID #57-#64)
#    9     Selected Group (1 of 8)
#   10     Selected Bank (1 of 8)
#   11-15  reserved
#   16     MIDI Status received for Button ID #1-#8
#   17     MIDI Status received for Button ID #9-#16
#   18     MIDI Status received for Button ID #17-#24
#   19     MIDI Status received for Button ID #25-#32
#   20     MIDI Status received for Button ID #33-#40
#   21     MIDI Status received for Button ID #41-#48
#   22     MIDI Status received for Button ID #49-#56
#   23     MIDI Status received for Button ID #57-#64
#   24-31  reserved
[LED_MAP]
   LED_SR1 = 10    # (Button ID #1-#8)
   LED_SR2 = 2    # (Button ID #9-#16)
   LED_SR3 = 3    # (F1-F4 and Navigation Buttons: ID #17-#24)
   LED_SR4 = 4    # (Button ID #57-#64)
   LED_SR5 = 5    # (Button ID #25-#32)
   LED_SR6 = 6    # (Button ID #33-#40)
   LED_SR7 = 7    # (Button ID #41-#48)
   LED_SR8 = 8    # (Button ID #49-#56)
Edited by jrp
