alekzander Posted November 10, 2013 Posted November 10, 2013 Does anyone have experience using an LCD with an IST3020 driver? Googling Arduino and IST3020 does not come up with any hits. The chip is used in a EastRising 4.3" COG display with 192x64 pixels in a very slim frame. Two of those displays next to each other would be a nice, cheap ($9-$12 each depending on color) replacement for the very, very expensive 2x55 character displays used in the Logic/Mackie Control at the same width. Unfortunately, the connection is with a 36 Pins 0.50mm Pitch ZIF Connector but there are places which provide breakout boards with the ZIF connector. http://www.buy-display.com/default/192x64-dot-matrix-display.html
PsYcH Posted April 8, 2015 Posted April 8, 2015 Hello, I see that this post is almos 2 years old, maybe you found a solution? :) Really want to connect it to my arduino.
