Marxon Posted March 21, 2015 Posted March 21, 2015 (edited) Hi all, I like to use a 40 segment led bargraph and connected it like a 8x5 matrix. To control it with one single CC, i use five events with different ranges. DOUT_MATRIX n=10 rows=8 sr_dout_sel1=26 sr_dout_r1=25 EVENT_LED_MATRIX hw_id=149 type=CC chn=1 cc=66 range=0:24 led_matrix_pattern=2 EVENT_LED_MATRIX hw_id=148 type=CC chn=1 cc=66 range=25:50 led_matrix_pattern=2 EVENT_LED_MATRIX hw_id=147 type=CC chn=1 cc=66 range=51:76 led_matrix_pattern=2 EVENT_LED_MATRIX hw_id=146 type=CC chn=1 cc=66 range=77:102 led_matrix_pattern=2 EVENT_LED_MATRIX hw_id=145 type=CC chn=1 cc=66 range=103:127 led_matrix_pattern=2 LED_MATRIX_PATTERN n=2 pos=0 pattern=0000000000000000 LED_MATRIX_PATTERN n=2 pos=1 pattern=1000000000000000 LED_MATRIX_PATTERN n=2 pos=2 pattern=1100000000000000 LED_MATRIX_PATTERN n=2 pos=3 pattern=1110000000000000 LED_MATRIX_PATTERN n=2 pos=4 pattern=1111000000000000 LED_MATRIX_PATTERN n=2 pos=5 pattern=1111100000000000 LED_MATRIX_PATTERN n=2 pos=6 pattern=1111110000000000 LED_MATRIX_PATTERN n=2 pos=7 pattern=1111111000000000 LED_MATRIX_PATTERN n=2 pos=M pattern=1111111100000000 LED_MATRIX_PATTERN n=2 pos=8 pattern=1111111110000000 LED_MATRIX_PATTERN n=2 pos=9 pattern=1111111111000000 LED_MATRIX_PATTERN n=2 pos=10 pattern=1111111111100000 LED_MATRIX_PATTERN n=2 pos=11 pattern=1111111111110000 LED_MATRIX_PATTERN n=2 pos=12 pattern=1111111111111000 LED_MATRIX_PATTERN n=2 pos=13 pattern=1111111111111100 LED_MATRIX_PATTERN n=2 pos=14 pattern=1111111111111110 LED_MATRIX_PATTERN n=2 pos=15 pattern=1111111111111111 I know it is not possible to spread 40 leds perfectly over a range from 0 to 127. But somehow the led distribution is very uneven. Here is a diagramm to show what happens. Does somebody know where the problem is or what i´m doing wrong? Thanks for your help! Best regards Marxon Edited March 21, 2015 by Marxon
Marxon Posted March 21, 2015 Author Posted March 21, 2015 After i had recap the issue, I remembered having a similar problem in the past. The solution is that each dout_matrix has always 16 entries. Hence it does not make sense to use all of the 16 pattern positions in my 8x5 matrix. So i changed led pattern. LED_MATRIX_PATTERN n=1 pos=0 pattern=0000000000000000 LED_MATRIX_PATTERN n=1 pos=1 pattern=1000000000000000 LED_MATRIX_PATTERN n=1 pos=2 pattern=1000000000000000 LED_MATRIX_PATTERN n=1 pos=3 pattern=1100000000000000 LED_MATRIX_PATTERN n=1 pos=4 pattern=1100000000000000 LED_MATRIX_PATTERN n=1 pos=5 pattern=1110000000000000 LED_MATRIX_PATTERN n=1 pos=6 pattern=1110000000000000 LED_MATRIX_PATTERN n=1 pos=7 pattern=1111000000000000 LED_MATRIX_PATTERN n=1 pos=M pattern=1111000000000000 LED_MATRIX_PATTERN n=1 pos=8 pattern=1111100000000000 LED_MATRIX_PATTERN n=1 pos=9 pattern=1111100000000000 LED_MATRIX_PATTERN n=1 pos=10 pattern=1111110000000000 LED_MATRIX_PATTERN n=1 pos=11 pattern=1111110000000000 LED_MATRIX_PATTERN n=1 pos=12 pattern=1111111000000000 LED_MATRIX_PATTERN n=1 pos=13 pattern=1111111000000000 LED_MATRIX_PATTERN n=1 pos=14 pattern=1111111100000000 LED_MATRIX_PATTERN n=1 pos=15 pattern=1111111100000000 Now all leds are scaled linear over the hole controller range. But one problem remains: There are still "gaps" at the cc values 26, 52, 78 and 104. Any ideas?
