Guest NickUK Posted December 10, 2003 Posted December 10, 2003 Hi,I've just finished my MB, it's got 16 Pots, 8 buttons and works great with the test software ain64_din128_dout128_v1_3.zipHowever my problem comes when I upload the MB64 software: When I move the faders the LCD shows the relevant Pot is being moved, however the MIDI output does not show the fader data, i.e. Both sets of data are always 0.Timestamp IN PORT STATUS DATA1 DATA 2 CHAN Note EVENT00006b01 1 -- B1 00 00 2 ----- CC: Bank MSBI've tried modifying the software so that only 16 pots and 8 buttons are used but this has the same results. All unused inputs are tied to ground.Am I missing something really simple?? TIANick Saundersp.s Photos to follow.
uclaros Posted December 10, 2003 Posted December 10, 2003 have you set the faders to a perticular CC# with vmidibox? (or with the built in fnction in MB64v2)
Guest NickUK Posted December 10, 2003 Posted December 10, 2003 No, Do i do that via SYSEX?Will give it a try :D
Guest NickUK Posted December 11, 2003 Posted December 11, 2003 I've tried this, I still get not response from the POTS.I've set up faders 1 through 16 as CC # 0 through CC #15When I move the faders in V midibox The display moves on the LCD. However When I move the Faders on the MB the Display does not change on the Vmidibox.On the Midibox, if I look at the Edit Events Menu, each pot entry is blank I can not enter any data i can only move the cursor by pressing the Snapshot button. Left and right have no function.Could there be anything else?TIANick
uclaros Posted December 11, 2003 Posted December 11, 2003 After setting the pots in vmidibox, you have to send the sysex to midibox.After that you should see on the edit events menu the CC#s of each pot.
Guest NickUK Posted December 12, 2003 Posted December 12, 2003 Hi,I've done that, the labels are now next to each POT, however the edit events menu , each pot entry is blank.CheersNick
Guest NickUK Posted December 12, 2003 Posted December 12, 2003 All Fixed Now !! ;DI reprogrammed the PIC with the bootloader and uploaded MIOS. Uploaded My Application and Hey Presto One Working Midi Box!!!!!Thanks for the HelpHere is the Picture :P
