adamjking Posted December 17, 2003 Posted December 17, 2003 Hi All.I'm new to uCApps and after reading through the many pages I am going to start on building a MIDIbox64, one module at a time.There is a lot of info on the site with different projects, chips, etc and I just wanted to check with everyone, to make sure that I have the steps 'round the right way. My initial plans are: I am going to start by building the JDM. Once built, I buy the chip (PIC18F452) and burn in the MIOS bootstrap loader using IC-PROG via serial cable. Once the other modules are built, i then upload the OS/apps via midi using MIDI-OX.I just want to check that this is the right way 'round to start - any info would be aprreciated.Cheers.
banneduser Posted December 17, 2003 Posted December 17, 2003 Meeshka, euhm yes, that's about it. but i suggest youmake a list of thing that you want to buildand the parts you require (jdm,core,din,dout) and then order them.if you built the jdm and then order the pic youwill be eating your heart out staring at the circuit !!! ;)much cheaper too unless you live near anelectronic warehouse.greetzVT**my2centopinion**
adamjking Posted December 18, 2003 Author Posted December 18, 2003 Thanks Voltrigger,I am still quite new to electronics/PICs/MIDI so I am happy to just build it one module at a time and learn as I go along. I work in the city, very close to two electronic stores so its not really a problem.I will take your advice on the PIC tho, I just wanted to check that the 18F452 is the recommended one to be using now.Thanks for the reply,meeshka
