I am new at my midibox mb6582 build.All was working well ,until I took it apart and re loaded  the setup_8580 file into the core 0,1,2,3 4685 pics.Now i have a non
responsive mb6582.i used my midi cables that i origionally used.I am wondering if i am uploading setup_8580 and changing the jumper at core 0 to 1 , 2 , 3 respectively and changing the device id at the studio 2 page
is this correct?The presets say that they are getting stored but arent changed with the menu dial.The firmware is not loading or i am making a mistake.I had everything
operating great at one point.When i removed the cover 4 of the lcd wires came off.I resoldered them,after carefully checking order and display is displaying e002 pint ld chn.1 1---lLead patch.None of the encoders or buttons will comply or respond at the control surface.any help would be appreciated....----scottsober 6-24-2016
