Guest durak Posted January 21, 2004 Posted January 21, 2004 Hi!I want to use my midibox buttons the way you use ones in drum machines, tb-303 etc. So are there any vst drum machines with step sequencers or just plain step sequencers out there? And especially ones that have midi implementation on the buttons. (For example redrum in reason does not have :/)
Guest durak Posted January 23, 2004 Posted January 23, 2004 Anyone?There's gotta be some way to do it?When I have a row of 16 buttons with leds on top of them on my midibox it's just stupid if there is not. ;D
Nomical Posted January 23, 2004 Posted January 23, 2004 I'm sure there's software that has a step sequencing function, but i guess it's not that common. Since the days of music software we're getting used to programming visually. Allthough i like step sequencing, i also feel it's out of date and i guess a lot of software developers think the same. All VST compatible host software have graphic interfaces which provide a far more faster workflow and even simplified editing like a simple function as deleting notes. The step sequencer on the TB303 is hell compared to the the step sequencer of the SR-16. Some can't even go back the change your arrangement and you simply have to go to the end of the pattern and redo the sequence. With graphical interfaces there's no need for all this.But when i read your second post, i get the idea that you want the same (realtime) sequencing style as on a MC303/MC505/TR707/Electribe and similar machines, which is not the same type as used on the TB303.Maybe it's possible with Rebirth? I'm not sure though.You could also write the needed software yourself ;D
Nomical Posted January 23, 2004 Posted January 23, 2004 Although it's not supported anymore, maybe the old TechnoToys software can help you out like XG909 or SEQ-303 and software like those. Technotoys have quit making software, but if you look around for it you'll probably still find it. And i got it on cdrom somewhere with all the cracks and stuff like that. I guess it doesn't matter if you search for cracks and stuff like that for this particular software, because the software isn't supported anymore anyway.It's always worth to try...
Nomical Posted January 23, 2004 Posted January 23, 2004 Or maybe this one:Revolve 100mAdditional info: Harmony CentralQuote from Harmony Central: Both the 103 Bassline and 109 Drummer offer MIDI/Computer Remote ControlBut Revolve isn't supported anymore either like the Technotoys software. But once again it's still around there on the internet and maybe i have it on cdrom too if i start digging betweeen my cdroms ;D
Nomical Posted January 23, 2004 Posted January 23, 2004 simple Google search resultsHere's software that's still supported:http://algoart.com/softstep.htmhttp://www.discointellect.org/stepwerk.htm
Guest durak Posted January 23, 2004 Posted January 23, 2004 Thanks! I'll check out all of them.Just a word of warning for everyone else maybe interested in these, executing that stepwerk program messed up my w2k totally.
DrBunsen Posted January 30, 2004 Posted January 30, 2004 Ok, so does anyone have a suggestion for a good one to run on classic MacOS? (OS 8.1 or below preferably)
