adamjking Posted January 22, 2004 Posted January 22, 2004 Hi All,I was wondering, does anyone know if ALPS makes their linear slider pots (faders) in a 10K version? I was looking at the Farnel website and they only sell the linear ones in a 50K version.Does anyone know if/where you can get the 10K linears, or will the 50K be ok to use?Cheers.
cdigitaldetroit Posted January 22, 2004 Posted January 22, 2004 Yes they do. If your in the US, Mouser sells them.$7.00 - 100mm$8.00 - 60mm
arumblack Posted January 22, 2004 Posted January 22, 2004 Also , I was told by someone (Rogic i think) that 50k would work. came up because i had found some joysticks i was going to order.(never ordered them though, due to minimum order of 30 dollars, and they had nothing else i needed)
adamjking Posted January 22, 2004 Author Posted January 22, 2004 Doesn't the "B Taper" and "D Taper" mean they are logarithmic, not linear?
cdigitaldetroit Posted January 23, 2004 Posted January 23, 2004 The Mouser catalog that I have lists the taper as linear. You can download the catalog page from any of the two links above.
