thats works:
FILE_DirExists("a");	// check for a Folder named a
get the warning: "warning: passing argument 1 of 'FILE_DirExists' makes pointer from integer without a cast [enabled by default]"
char directory = a
FILE_DirExists(directory);	// directory is a variable
is it possible to check for a Variable-Dir?
file.c says:
//! Returns 1 if directory exists, 0 if it doesn't exist, < 0 on errors
s32 FILE_DirExists(char *path)
  DIR dir;
  if( !volume_available ) {
#if DEBUG_VERBOSE_LEVEL >= 2
    DEBUG_MSG("[FILE_DirExists] ERROR: volume doesn't exist!\n");
#endif
    return FILE_ERR_NO_VOLUME;
  if( !path || !path[0] )
    return 0; // empty directory name - handle like if it doesn't exist
  return (file_dfs_errno=f_opendir(&dir, path)) == FR_OK;
Posted (edited)
i got it:
// change Folder Directory  -  letter loadet from previos loaded SYS-File
char Folder = 'a';
char path[8];
strncpy(path,  "a       ", 8);
path[0] = Folder;
statusDir 	= FILE_DirExists(path);	 		// ask file.c: exist a folder "a/" on the CARD? //
or:
char Folder = A’;
char path[8];
// Build File Path/0.t4      "
sprintf   (path, "%c/0.b4",Folder);
// ask file.c: exist a file "A/0.b4" on the CARD? //
statusFile_patch = FILE_FileExists(path);
and for delete all Files - and Directory(if all files are known and already deleted
// you need to delete each file on its own...
int c; for (c=0; c<256; c++)	{
						char remove[9];
 						 // make a new filename depending on the counter value
						sprintf   (remove, "%c/%d.b4",Folder,c);
						// Remove FILEs
						MUTEX_SDCARD_TAKE;
											FILE_Remove(remove);
						MUTEX_SDCARD_GIVE;
// Remove Directory (can only be done if it empty
	// build path
	char remove[8];
	sprintf   (remove, "%c",Folder);
	MUTEX_SDCARD_TAKE;
	MUTEX_SDCARD_GIVE;
whoud be interesting, how to delete a folder if the Files inside are not known?
Edited by Phatline
