adamjking Posted February 12, 2004 Posted February 12, 2004 Hi all,I'm looking around at the moment for pushbuttons to use with my midibox hardware controller. I want to use momentary buttons as well as LED's, and was wondering if anyone sells momentary buttons with in-built LED's. I think the led would have to have seperate solder tags to the switch for the led to be controlled by MIOS. Does anyone know if such a product exists?
arumblack Posted February 12, 2004 Posted February 12, 2004 yes theese do exist. i was considering ordering some myself and marked the page in my Mouser catalog.of course there are many othersI'm sure.http://www.mouser.com/index.cfm?handler=displayproduct&lstdispproductid=362490&e_categoryid=142&e_pcodeid=01016there is a data sheet there. seperate pins for the led and switch. spst off(on) the (on) indicates momentary.
adamjking Posted February 12, 2004 Author Posted February 12, 2004 Ahh, thanks. I think this is what I want:http://www.mouser.com/index.cfm?handler=displayproduct&lstdispproductid=359509&e_categoryid=142&e_pcodeid=01007Round, momentary switch with built in LED - tho I can't tell from the datasheet (http://www.mouser.com/catalog/specsheets/0110105.pdf) whether there are seperate pins for the LED.
xsou Posted February 12, 2004 Posted February 12, 2004 Hi,you can maybe find whay you want with mec switches with led (which are quite good looking ) http://www.mec.dkYou can ask for some samples on their webiste (takes 1-2 weeks to get them)Farnell sell some of them and there must also be other shops (but have not found them yet!)Have fun, :DXsou
arumblack Posted February 12, 2004 Posted February 12, 2004 Meeshka: I think those are also seperate pins, though it is not as clearly stated as the other ones, there are five holes on the pcb layot, two marked + and - so i would assume those are the led, as a switch has no polarity.
adamjking Posted February 13, 2004 Author Posted February 13, 2004 arumblack: Yeah, I was thinking the smae thing with the + and - pins. Its just not clearly stated like it is on the datasheet of the ones you were looking at.Xsou, yes I saw the mec switches in the Farnell catalog. They look very cool but at about AU$ 11.00 each they are too pricey. How many do they send in a sample request?Cheers.
DriftZ Posted February 13, 2004 Posted February 13, 2004 fwiw: switches from mec that I gonna usehttp://users.pandora.be/DriftZ/Current%20Studio/LEDswitches.zipbest,D
adamjking Posted February 13, 2004 Author Posted February 13, 2004 Thanks DriftZ - I like the look of the transparent cap as well! Looking on the Farnell site, it looks as though they sell just the switch body for about AU$ 4.10 (Part No. 3FTL6). But when it comes with an LED, the price goes up to about AU$ $9.01 (eg Part No. 3FTL620).Couldn't I just buy the switch bodies, transparent caps and buy LED's seperately in bulk? The body (3FTL6) can still accept LED's can't it?
banneduser Posted February 13, 2004 Posted February 13, 2004 I'm thinking the same thing for the mute and solo state. But how is this wired? its a momentary switch, so assume MIOS has to tell the light when to be on and off.What will need to be actually done to get this working? Anyone...?
DriftZ Posted February 13, 2004 Posted February 13, 2004 Couldn't I just buy the switch bodies, transparent caps and buy LED's seperately in bulk? The body (3FTL6) can still accept LED's can't it?Yes you can, on the switchbody fit all different kinds of caps, if you choose for a transparent cap, you can fit in a 3mm LED of your choice (color/brightness), the switchbody has openings where the legs of the LED go through. You solder the legs of the LEDs on the PCB.I'm thinking the same thing for the mute and solo state. But how is this wired? its a momentary switch, so assume MIOS has to tell the light when to be on and off. The switch itself connects to the DIN(X4) module, the LED connects to the DOUT(X4) module.hope that explains,best,DriftZ
banneduser Posted February 13, 2004 Posted February 13, 2004 I wasn't going to use a DOUT module for mine. My plan is to use the AIN module for 32 switches, I may add another to get up to 64. I think this is correct but...
DriftZ Posted February 13, 2004 Posted February 13, 2004 I don't think you can connect switches to AIN modules.1 DINX4 lets you connect 32 switches.
