banneduser Posted March 18, 2004 Posted March 18, 2004 Hi. I want to build midibox64e with 16 rotary encoders, 16 buttons and 16 leds. I have two questions:1. Can I use DINX3 for 20 buttons (16 buttons + 4 buttons for special functions), DINX4 for 16 rotary encoders and DOUTX2 for 16 leds ?2. Do it is necessary to change the firmware for this configuration or it will works without any changes.I am from Poland, sorry for any mistakes in my txt. Best regards.
DriftZ Posted March 18, 2004 Posted March 18, 2004 1. DINX1 (1SR) = 8inputsDINX3 = 24 inputs, so 20 buttons, yes.DINX4 = 32 inputs, you need 2 per encoder, so 16 encoders, yes.DOUTX1 = 8 outputs, so DOUTX2 for 16 leds, yeshowever, you could do this with DOUTX1 I think (4x4 matrix), will need some coding.2. Which firmware do you intend to use ?(you will probably need to do some changes in the settings, for encoder type, max number of DINs, DOUTs, but this isn't really writing code)goodluck
banneduser Posted March 19, 2004 Author Posted March 19, 2004 I want to use MIOS firmware. How can I change settings for number of encoders, buttons etc., where is this options. I see the example aplications in download section. Maybe my configuration will be working without any changes in settings???
banneduser Posted March 22, 2004 Author Posted March 22, 2004 here is a hintbuild the core then test it build 1 ain test itand so on...by doing this in a slow but sequential manner you will understand it a lot better.Plus you will work out which application/firmware you will need.
