Guest DavidChristopher Posted May 12, 2004 Report Posted May 12, 2004 Hi everybody;Is this something doable, and how can it be accomplished? I want to hang a lighted sign outside my studio (under construction) that says 'recording' anytime I'm recording. I suppose we could use MMC for the signal; This would be similar to the "On Air" light seen at radio stations and tv studios.Can a mios core do this? Any suggestions?Thanks :D Quote
uclaros Posted May 12, 2004 Report Posted May 12, 2004 Sure!You'll have to use a relay switch instead of a led on the dout module and assign it to the CC# used by the record button! Quote
