drehher Posted May 16, 2004 Posted May 16, 2004 Hallowird das zweite display für den neuen seqenzer einfach parallel zum ersten geschaltet?grussandreas
Guest Zeikos Posted May 16, 2004 Posted May 16, 2004 Connectivity: Both displays have to be connected to the same data and control pins at J15, only the E (enable) input of the second LCD requires a dedicated output (pin C.4, J10:RC) which is not routed to J15 and therefore has to be soldered directly to the core module.Wiring Diagram: http://www.ucapps.de/mbhp/mbhp_2xclcd.pdf
