hello all
are you tired of drilling all those holes when making a midibox.
I have been thinking about going surface mount components for chips,resistors,capacitors.
if i use the large smd components i dont think tiny soldering will be too hard.
obviously the boards will need to be changed somewhat
like a mirror image of the ones we are using now.
I believe I will start on one of the smaller/less complex boards like the dout/din/ain.
any of these should be easy to make into sm and wont require any holes at all
(unless you like to use some for connectors).
I would like to know if anyone is keen on this idea.
so i will share the boards (after they are tested or befor if you want to help).
Boards will be stored as a zip WITH a help file saying that size/style all of the components
as to avoid confusion.
Hopefully this will be of benifit to other midiboxers
not just a vent for my frustrations on breaking so many drills yesterday ;)
Sounds cool...
LOL   :D
Indeed, very interesting idea.
This would help reducing significantly the size of the boards.
Why not then make an ultra-slim sequencer/SID that can fit in a small suitcase  ;D
If you go for it, maybe you can look at alternative chips (if they can easily be found in shops) that work in 16-bits instead of 8. I found some on the web for AIN, DIN or DOUT I don't remember. That would also help reduce the size.
Best regards,
Lall
I have also been looking at some chips that contain a series of parallel resistors on them obviously for the din/dout boards.
after another look at the board desighn i think it will be a total redesign of the boards i think.
am i right in thinking that this would require some coding.
coding is definatly my weak spot  :-[
but then again this is a concepts board, so fire away
keep the concepts coming.
