hello again,
i was wondering if this 20x2 lcd would work with the midibox sid?
http://uk.farnell.com/jsp/endecaSearch/partDetail.jsp?SKU=5005000&N=401
also, can i install bright blue leds or will i need an additional resistor? i don't know much about the stats of the leds, but i seem to remember something about adding a resistor.
im just worried if i fill two douts with blue leds will it work correctly.
cheers,
Rowan
this everbouquet one is similar to the batron on the previous post.
http://uk.farnell.com/jsp/endecaSearch/partDetail.jsp?SKU=5005267&N=401
i dont know anything about lcd drivers and i tried comparing the datasheets with the hitachi one. but i didn't really know what to be looking for. the only thing i noticed was the pinouts are the same?
please could somebody advise on compatability as i am lost! :s
if neither are compatible, are there other blue/white alternatives?
thanks in advance! :)
Rowan Hall
Hmm.
I didn't check the datasheet - only "catalogue" info. online: "4/8bit interface" plus "standard" means HD44780 compatible controller - It's a Midibox ready!
And for the leds -  those have a current and a voltage drop rating . It's better to read:
http://www.kpsec.freeuk.com/components/led.htm
than trying to explain it - those blue ones need more power = smaller current limiting resistors.
I don't know if DOUTs can support that power -- Yes, I guess. ;)
Bye, Moebius
