Guest Henchman Posted October 12, 2004 Report Share Posted October 12, 2004 How hard would it be to exchnage the faders on a BCF2000 to be touchsensitive? Quote Link to comment Share on other sites More sharing options...
Screaming_Rabbit Posted October 12, 2004 Report Share Posted October 12, 2004 ... this might be pretty hard. Since you propably don't have the source code. :-/Greets, Roger Quote Link to comment Share on other sites More sharing options...
Guest Henchman Posted October 13, 2004 Report Share Posted October 13, 2004 Yeah. But I was thinking more along the lines of using the BCF as a starting point. possibly gutting it, replacing the faders, use the existing remaining encoders and buttons, and add new electronics to control it.For those of us not wanting do build our own case etc. They're so cheap.Hmmm. maybe I'll open mine up to see what kind of faders they sued. Quote Link to comment Share on other sites More sharing options...
Guest Henchman Posted October 13, 2004 Report Share Posted October 13, 2004 If that's not possible, being able to add an LCD display above each channel that would give you a channel numbr or trackname would be cool. Quote Link to comment Share on other sites More sharing options...
Screaming_Rabbit Posted October 13, 2004 Report Share Posted October 13, 2004 I think that they have the Alps N-Type faders... you have to check the type and/or have to measure the resistance.You propably can't use the original PCBs for the encoders and switches... I could imagine, that they implemented one big PCB for everything... perhaps you can customize it ???I also think, that you don't have enough space inside to pack the MB-Boards into the case.... and why would you wanna take the original Behringer case? - It looks so cheesy ;DGreets, Roger Quote Link to comment Share on other sites More sharing options...
bosone Posted October 15, 2004 Report Share Posted October 15, 2004 knowing what behringer did in the past... are we REALLY sure that inside the behringer midi controls there is not a PIC 18f452? ;D Quote Link to comment Share on other sites More sharing options...
moebius Posted October 15, 2004 Report Share Posted October 15, 2004 Well, I wouldn't be so worried 'bout Behringer, they just use fairly common business practices ;D, but Do(p)epfer - known to rip DIY designs :P(Yes - I do encourage NOT supporting do(p)epfer in any way, even not to buy their cheap trafos.) Quote Link to comment Share on other sites More sharing options...
Steven_C Posted October 25, 2004 Report Share Posted October 25, 2004 knowing what behringer did in the past... are we REALLY sure that inside the behringer midi controls there is not a PIC 18f452?from memory, I think the ledrings on the behringer units have more than 11 led's, so no, not a mios ripoff. (unless they did a bit of their own customising!)Shame the BCF has no scribble strips, they are so cheap! (I also thought about using these units for parts... but I didn't realise that they had no touch sensor...) Quote Link to comment Share on other sites More sharing options...
Steven_C Posted January 8, 2005 Report Share Posted January 8, 2005 Back to the original question... (I hope its not too late!)How hard would it be to exchnage the faders on a BCF2000 to be touchsensitive? I am sure that the output of a simple midibox (core and a din module) could be merged with the output of the BCF to add a touch function. But this would have to be implemented by adding buttons at the bottom of each fader on the BCF2000, that you press when you want to activate the 'touch'.This just leaves one problem... no LCD to tell you what is going on... maybe a midi thru box (easy to make) between the PC (or mac) and the BCF2000, with one of the outputs going to the midi in of a midibox LC core, with just the LCD(s) connected.Possibly a cheap and slightly easier way of getting an LC (though with a few less buttons, functions)...Steve Quote Link to comment Share on other sites More sharing options...
cheater Posted January 8, 2005 Report Share Posted January 8, 2005 Shame the BCF has no scribble strips, they are so cheap!What's a scribble strip? :) Quote Link to comment Share on other sites More sharing options...
Screaming_Rabbit Posted January 8, 2005 Report Share Posted January 8, 2005 What's a scribble strip? :)... the strip on the bottom of the faders to name the channels (Example: VOX,HH,Guit,Keys...) Quote Link to comment Share on other sites More sharing options...
