Guest Mr.Freeze Posted October 20, 2004 Report Posted October 20, 2004 I've been using some PIC16F876A µC's at work for one month now, with MicroChip's PICSTART Plus hardware & MPLAB software and PicAnt C2C compiler. Easy way but not for cheapskates... I'd like to find a low-cost solution for my own projects (including MIDIbox ones, that's why I'm here), running on Linux (and Windows if available), in C not ASM! When it comes to hardware, I've been thinking of C. Tavernier's or El Cheapo's designs. Should the SourceForge couple (SDCC & PP06) help handle that situation, PIC16F support seems to be on its earliest stage... Any replacement idea?
pilo Posted October 23, 2004 Report Posted October 23, 2004 I use GPASM (http://gputils.sourceforge.net) with SDCC and mios C wrapper, I post a makefile on another thread. It works great ;)
Guest Mr.Freeze Posted October 25, 2004 Report Posted October 25, 2004 I've found the aforementionned makefile on the topic "Status of SDCC evaluation" (for those who read posts silently on their own): project.hex: main.c gpasm -c mios_wrapper/mios_wrapper.asm -I mios_wrapper -o mios_wrapper.o sdcc -S -V -mpic16 -p18F452 --pomit-config-words --pomit-ivt -pleave-reset-vector main.c perl tools/fixasm.pl main.asm gpasm -c main.asm gplink main.o mios_wrapper.o -s project.lkr -o project.hex perl tools/hex2syx.pl project.hexI think I can guess how to remove occurences of the MIOS C Wrapper above as I ain't into MIOS programming for the moment. I'll still be notfied of updates on the other topic for future projects.Thanks!
pilo Posted October 25, 2004 Report Posted October 25, 2004 Here's a better one I think ;)project.syx: main.c mios_wrapper.o sdcc -S -V -mpic16 -p18F452 --pomit-config-words --pomit-ivt -pleave-reset-vector main.c perl tools/fixasm.pl main.asm gpasm -c main.asm gplink main.o mios_wrapper.o -s project.lkr -o project.hex perl tools/hex2syx.pl project.hex mios_upload.pl project.syx mios_wrapper.o: mios_wrapper/mios_wrapper.asm gpasm -c mios_wrapper/mios_wrapper.asm -I mios_wrapper -o mios_wrapper.o upload: project.syx mios_upload.pl project.syx
Guest Mr.Freeze Posted October 25, 2004 Report Posted October 25, 2004 Thanks again!When using Windows, it's more to be considered as a *.bat script than a makefile, isn't it?Why don't you use PP06 instead of GPASM?
pilo Posted October 25, 2004 Report Posted October 25, 2004 When using Windows, it's more to be considered as a *.bat script than a makefile, isn't it?Yes I think, but I don't know windows very well.Why don't you use PP06 instead of GPASM?PP06 is for programming the chip? gpasm is a pic assembler (needed because SDCC output asm). But I didn't know PP06, I will look after it now ;)
Guest XORNOT Posted October 30, 2004 Report Posted October 30, 2004 I use Pikdev for linux, works fine with the midbox design of the JDM. There is a decent open source C compiler in the works too, but I don't think it's done yet.And gvim for writing the source code, it has syntax highlighting for Microchip Assembly, cool!iain
pilo Posted October 30, 2004 Report Posted October 30, 2004 And gvim for writing the source code, it has syntax highlighting for Microchip Assembly, cool! kwrite has this feature too ;) (and emacs has got an asm mode too)There is a decent open source C compiler in the works too, but I don't think it's done yet. This is not SDCC?
Guest Mr.Freeze Posted November 9, 2004 Report Posted November 9, 2004 I haven't taken time to test it all... Haven't made my choice on the harware programmer either! Any fave here? The JDM module?
