scoubidoo Posted October 21, 2004 Posted October 21, 2004 hi,I'm going to use a MB64 with the PRO53 virtual synthesizer. To carry this function out :PRO53[iN] = Midibox[controlers] + external keyboard , do I need a second Core Module ( a merger ) ? Is it possible to do by software :Midibox[OUT] = Midibox[controlers] + Midibox[iN] ( external keyboard plugged on Midibox[iN] ) ? Thanks.
Sephult Posted October 21, 2004 Posted October 21, 2004 If your talking about using a musical keyboard rather than a computer keyboard. Your midi setup would be Keyboard---Midibox----computer----back to keyboardOne core module, but you will have to disable the midithru so you wont get feedback.I would set the midi thru off on the computer. (Echo in Sonar)That way you can play your keyboard through your controller so both can be recorded in the sequencer, but the sequencer stops the notes from playing back through it's outputs.
